Question about The Office Equipment & Supplies
How do I check how many points I have?
The scan number is 3081 4720 0195 818
94 corvette rough idle new plugs and fuel filter no check engine light
Dirty injectors maybe , or throttle plate carboned up , IAC - idle air control problem , EGR valve carboned up . Could be a number of thing's . Hooking up a scan tool an checking engine sensor data may point to the problem .
Nov 09, 2017 | Cars & Trucks
What's your question? my konica minolta c451e printing machine showed me an error code p21, what could that mean and it is not printing any image but black-green shade
P-21 - Color regist test pattern failure
• The number of points detected in the main scan direction is more or less than the specified value during main scan direction registration correction.
• The number of points detected in the sub scan direction is more or less than the specified value during sub scan direction registration correction.
P-21: Color regist test pattern failure
Relevant parts:
• Transfer belt unit
• PH unit
• Printer control board (PRCB)
Step/Action:
1/ Wipe clean the surface of the transfer belt with a soft cloth, if it is dirty.
2/ Change the image transfer belt unit if the transfer belt is damaged.
3/ Change the PH unit.
4/ Change PRCB.
(See Service Manual, pages 599, 603):
http://www.imcopexamerica.com/service-books/Bizhub/Color/bizhubC451_C550_C650FieldSvc.pdf
See also here:
Konica Minolta Bizhub c451 Reparacin de Fotocopiadoras YoReparo
Thread Problemas na C451 7 21
May 31, 2015 | Konica Minolta Office Equipment & Supplies
Check engine light car shaking
have check engine light checked most auto stores will scan for codes for free ur problem can be any number [100s of trouble codes] of problems .the code will give you a starting point to correct your problem
Aug 15, 2013 | Jeep Cars & Trucks
My scanner will only scan bank 1 and 2
When your scanner is scanning normally (in only banks 1 and 2 at this point) just hit the number for the banks you want to scan. To remove a bank push that number again. Make sure it the scanner is actually scanning when you do this.
Regards, Tony
Apr 22, 2011 | Radio Shack Pro-82 Scanner
Check engine light. fixed but did not pass smog. light came back on
Get the code scanned again.
If it is the same code, the problem was not fixed.
Could also be another problem that came up while fixing the 1st code ( i.e. knocked a vacuum line off ).
If you do not have a code scanner, Autozone will scan the code for free, get the actual code number and post a comment back to this problem, or start a new one with the code number, and what you have done to this point ( include the 1st code and what you did in what order when attempting to fix that one ).
Feb 16, 2011 | 1998 Ford F150 Regular Cab
1994 jeep cheokee sport 4.0 check engine light comes on and off wht could it be?
You really need to have a code scan done. Any number of sensors can be out of range causing the light to come on. Code scan (free at most major parts stores) will point you in the right direction, then you will need to test using a digital multi-meter to check individual components ( haynes or Chilton manuals have instructions and test values) Also check sensor wiring to make sure it's not grounding on the engine or a hot pipe.
Test...don't guess.... if you do it can get really expensive really fast.
You can do a basic test for codes by turning the key on and off three times, leaving it on the third time (without starting it) The light will flash in sequence, each group is a number eg: three flashes is the #3. numbers will be in groups of two with a pause between. (code 33 would then be three flashes, three flashes then a pause then the following number. Ignore code 55 as that tells you when it's finished. (you will still need the book to know what the codes mean)
Apr 13, 2010 | 1994 Jeep Grand Cherokee
Number 5 piston misfiring
It could be caused by a lot of different things, including a fuel injector, spark plug, spark plug wire, low compression, but in most cases it doesnt get to deep. I would start with checking the spark plug wire to cylinder number 5, then the spark plug. Moisture can cause a misfire so make sure the metal contact points are dry.
Jan 28, 2010 | 1999 Chevrolet Astro
I just scanned some documents onto a genealogy program and photoimpression ''took'' them and now I don't have them on the gen. program!! how can I stop it from doing this??? its very frustrating!!
You should see if your genealogy application can be pointed to scans in a specific folder on your machine. The scan into that folder (give the files friendly names) and point to that folder. When scanning, some scanners "prompt" you for a location for your resulting scan...check this too. One other thing is to see if there are scanning options for a efault "scan to" location.
Apr 24, 2009 | Computers & Internet
Check gauges prob
Hello
Welcome to RY
Sounds like i would run a scan on the ecm
engine control Mogul
there could be a number of problems this scan will pin point it. most auto parts store can do this.
RD
Jan 11, 2009 | 1999 Jeep Wrangler
21 people viewed this question
Top The Office Equipment & Supplies Experts
thetraveler
Level 1 Expert
Folusho Adeyanju
Folusho Adeyanju
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
