Question about Standard Health & Beauty
Hey guys I was wondering if anyone new a possible reason why my digital pocket scale is not calibrating with like a standard 100g scale weight? It just flashes for ten seconds then shuts down!
    Top Expert:
  • Standard Master
  • 48,486 Answers
Batteries are going bad probably
Posted on Apr 28, 2017
Testimonial: "MM that's what I thought, got some brand new ones still not working though ):"
  • 1 more comment
  • ray gallant Apr 28, 2017
    then it is totally junk , needs replaced
  • Sai Pittard
    Sai Pittard Apr 28, 2017
    yeah right I've been thinking that hey it was $7:50 on ebay from china. Lasted me through a good few ounces at least! Thanks for the help bro hey could I ask you one more question since you seem knowledgeable? So, luckily I have a back up except it's 0.77g off and when I try calibrate this one it just says full. Would you have any idea what this error code means?
  • ray gallant Apr 29, 2017
    sorry I do not know the error codes
Need to recalibrate weighmax scale with a 100g weight
You can easily buy 100 gram individual calibration weights for 6 bucks. and complete sets of calibration weights up to 100 gram for about $10 or less, if you need to check you scale periodically.
https://www.amazon.com/s/ref=nb_sb_ss_c_1_21?url=search-alias%3Daps&field-keywords=100+gram+calibration+weight&sprefix=100+gram+calibration+%2Caps%2C230&crid=H1MWENJABXEV
Jan 21, 2018 | Measuring Tools & Sensors
What does it mean when my us-magnum 1000xr pocket scale says rCAL and keeps flashing 500.0
You need to send it out to the manufacture and have it recalibrated. Hence the code RCAL.
Feb 24, 2017 | Pocket Health & Beauty
HOW DO I CALIBRATE POCKET SCALES
zero the display after removing and replacing batteries. place an object with a known weight on the scales to check it. There is no means to adjust it if the reading is wrong.
Sep 27, 2014 | Computers & Internet
My digital gram scale does not work. the screen has some kind of word. Please help
Try recalibrating it by turning it on while holding the "tare" or "mode" button. It should show a raw data from the sensor then. Press the tare button again and it should calibrate the empty weight. Then it will show a specific weight you should put on, usually 100g. It should automatically finish calibration now. Hope this helps. The words before calibration on my scale was OUt2
Sep 24, 2014 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
How to calibrate 1000xr us-magnum digital scale
magnum 1000xr pocket scales turns on calibrates goes to different modes but wont show the weight when object placed on the scale,a lock appears in top left of window, is scales broke or do i have to make lock symble dissappear?
May 28, 2011 | Kitchen Appliances - Others
When i turn on my digiweigh dw 100ax scales F--H appears on the screen how do i fix that and calibrate the scales when done
I thought the scale was just completely broken, I was able to fix by doing the following.
1. turn unit off
2. hold down the on/off/tare AND the MODE button.
3. The unit will come up with a bunch of numbers on the screen. Release the buttons
4. Press MODE once, you will see "100" flash on the screen. if you don't press the button a second time.
5. place 100g of tare weights on the scale.
6. Press MODE button again. After this my scale said PASSED and shut off.
7. remove tare weights and turn device on. It should now register properly.
In my case. the scale was misregistering the 50g weights as 75. I shut it off. I pulled up ever so slightly on the scale plate on the hinge side of the plate are repeated steps 1-7.
I have no idea why they don't have a 3 part calibration on these.
It is working like a charm now!
Sep 04, 2009 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
Scale displays OUT2
you need just to recalibrate it:
The procedure is standard for semi-all models of pocket scales, but the way how to get to calibration mode differs from model to model (or vendor to vendor).
In brief:
1.While turn-on get to the calibration mode (by pressing and holding the ON button, or holding TARE while turinig on) You should hold this "magic" combination until the LCD will show a number (large number - it was more than 2000 in my case). This number is a raw data from the sensor.
2.Now release the "magic" button.
3.Press it one more time, the display will show 2Ero and then 100.0
4.Now put calibrated weight of 100 grams on the scale and wait 3 seconds.
5.Press "magic" button again.The display will show CAL and then PASS.
6.Now remove the weight and turn off the scale.
7.Thats all - now you can use your scale as usually.
Jul 26, 2009 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
F--H APPEARS WHEN TURNED ON AND FREEZES
that dosent work in the case of an f--h display at least in my case i think the f--h stands for f**king hopeless
Jun 17, 2009 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
Mini digital scale displays out2
I just had this problem on set Salter scales (says 3309 on label on back so assume that's model no) which came up OUT2 solidly after hadn't been used for a while.
Looking on WWW this means on other scales they need to be recalibrated. There are only 2 buttons on ths model ON/Zero and 2nd is mode for grams, oz etc. Discovered by trial and error have to hold down the on button and repeatedly click the measure button as it powers up, screen says err2 press on button again and says 5000g, put 5000g weight on scales, press on button again display says CAL press on button and it at first came up with EEEE and failed but next attempt it said PASS and it all worked again. I used 2 x 1.5kg bags flour and 2 x 1Kg bags sugar to make 5kg with bit tipped out of one to make exact and checked on another set scales. So trick appears to be finding how to get your scales in to calibrate mode and what the weight it expects is.
Jun 15, 2009 | Balance Health & Beauty
Health & Beauty Logo
41 people viewed this question
Top Standard Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Standard Health and Beauty Expert? Answer questions, earn points and help others
