Question about Husqvarna Sewing Machines
My Husqvarna Viking 990S has seized up due to another person forcing sewing over jeans seam, what can I do
  • Husqvarna Master
  • 10,732 Answers
May be best to take it for service. Who knows how the machine was affected during the denim sewing project. It could very well be out of time.
Posted on Apr 28, 2017
How do i oil viking 150 sewng machine ?
have an authorized Viking repair dealer do it for you, there are not any user oiling locations on your machine. Use of the wrong lubricant on certain bearings can cause them to seize up.
May 12, 2014 | Husqvarna Viking 1
Viking 990S turns on and then shuts down right away any ideas of what I might do?
the machine may have powersupply or other electrical/ electronic problems. Take it to an authorized Viking repair dealer to discuss repair/ replacement options.
May 04, 2014 | Husqvarna Sewing Machines
Where can I find parts for a Viking 990S?
Most Viking dealers or repair shops should be able to get parts for you. Some that I know of that are available online are: http://www.sewingpartsonline.com/viking-990-sewing-machine-parts.aspx
Ron Anderson at A1 sewing is someone I've known for about 20 years on the net... he's always been helpful to DIYers on the usenet group "alt.sewing", and has a good reputation as a source of parts: ron@a1sewingmachine.com -- I'd try him if you don't have a good local repair shop.
IIRC, the 990 is electronic, and you may not be able to find boards for it anymore.
And FWIW, I mostly sew on a Juki F-600; like the old Vikings, it just works.
Apr 29, 2014 | Husqvarna Sewing Machines
I'm trying to sew jeans hem and stitches are uneven on top and loops are showing underneath. Also the foot and needle will not sew over cross seams and thread keeps getting snarled up underneath. Tha
a lot of machines struggle with denim because it is such a heavy and dense textile. Many domestic machines won't stitch it at all due to this. Things you can try however:
  • Denim needle, this has a deeper groove at the back and is a heavy gauge needle, or use size 110 if you don't have denim needle.
  • Bash the side seams with a hammer in the area you will be stitching, to soften up the fibres.
  • Use a seam jumper, this is a piece of plastic to put in back of the presser foot as you approach a cross seam to help keep the presser foot pressure even across the fabric. Sometimes called a "thingy-a-jean" or similar.
  • Don't bother trying to use the heavy gauge yellow jean thread unless you put it through the bobbin and sew with the right side down. But even then, many machines can't handle having this heavy thread underneath and the regular 50 cotton on top, my Janome 1600 won't do it.
  • put your machine on slowest speed if you have a variable setting and turn the flywheel to assist it through the heavy side seams.
Personally, I never bother with the twice turned hem on denim if shortening, I just overlock the raw edge, turn up 1 cm and stitch around in a matching blue thread so it is seen as little as possible.
Feb 03, 2014 | Elna Sewing Machines
When piecing a quilt top, my Husqvarna 550 lily Sewing Machine will not plow through seams or double thick fabric. It gets stuck. Help
You need to give it a helping hand over the thick seams. There is a gadget called a jean-a-ma-jig which could help.
Or sew up to the seam, leave the needle in the thread, lift the pressure foot, then insert a thick piece of card from behind to make the foot level with the seam, lower the pressure foot then sew.
The idea is to make a level surface instead of a bump to sew over. Improvise any way you can.
Dec 20, 2010 | Husqvarna Lily 540 and 550
I own a Viking Husqvarna 6440 sewing machine. I
The feed dogs are not working in conjunction with needle because of the bulk. The bulkiness especially at the seams causes a shift under the pressure foot and the bobbin spins off excessive thread. When you get to the seam, you need to raise the presser foot so it goes over the seam evenly. Get a jeanajig or use something that will level off the presser foot as it goes over and as it comes off the seam. Also trim some of the bulk off before you fold the hem over to sew it.
Mar 27, 2010 | Husqvarna Sewing Machines
In the middle of sewing a seam this #1 plus machine faded out on power (like it ran out of gas). I cannot turn back on and is "dead". Any suggestions would be greatly appreciates as I have a deadline to...
Sorry to hear that. Sounds like the power supply went out. suggest you take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Nov 16, 2009 | Husqvarna Viking 1
Machine speens but not the needle...
Sounds like the motor belt has come off the machine. It needs to be serviced by an authorized husqvarna viking service technician. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Nov 15, 2009 | Husqvarna Viking 1
I have a Husqvarna Viking quilt 870 sewing
The overload message is usuall due to a bind in the mechanical function of the machine. When the motor has an extra "load" caused by something like a tight belt or dry bearing, it "overloads" the motor and the error message is displayed. It is doubtful your problem is computer related. Either way a trip to your service tech is required. If you continue to sew with it, you do run the risk of possible damage to some other parts of your machine. The computer portion of your Husqvarna is guaranteed for 5 years and the mechanical parts carry a 20 or 25 year guarantee depending on when you purchased your machine. A copy of your bill of sale from a Husqvarna Viking dealer or a stamped warranty card is the proof of purchase needed to obtain warranty replacement of parts. Labor is only guaranteed for 1 year.
Sep 26, 2009 | Husqvarna Viking 1
Viking 990s sewing machine
take needle back out hit the reset and this should realign back to center some machines have a 3 needle setup this is also a make sure that needle is positioned in middle
3 needle setup is for the thicker decrative sowing
May 15, 2008 | Husqvarna Sewing Machines
Sewing Machines Logo
27 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
