Question about Craig Car Audio & Video
Have a 48 Watt how do i hook it up - Craig Car Audio & Video
Does anybody know what watt this is. it's sosed to be a 2400 watt and why does it have 2 ports on each side to hook up speaker wire And what's the best way to run it with a 800 watt Rockford fosgate
dual voice coil subs hook up mono on amp, from amp - from right side + from left side of amp run to sub n then jumper wires from one side of sub to the other side goes negative jumps on positive and positive jumps on negative
Apr 03, 2015 | Rockford Fosgate Car Audio & Video
Where can I get the 48v 500watt bushless motor for my e wheel E36 3 wheel electric mobility scooter
500 Watt 48 Volt Electric Scooter Motor
This link shows a 48 v. 500 watt motor, but you should contact them to make sure the motor fits your particular scooter. I hope this helps.....
May 01, 2014 | Health & Beauty
Fluro tube
fluro tubes are rated in watts and they are connected to the length of the tube. ie 20 watt 20 inches---30watt 36 inches and 40 watt 48 inches. Some makers have a triclor fluro that have a higher lumens value but the wattage will be the same.. You will have to compare tubes in the lighting shop.
May 29, 2013 | Home
Cf-48 I need nic drivers to hook to internet
http://www.toughbookdrivers.com/drivers/cf-48/ check this out. . .
Oct 22, 2012 | Panasonic Toughbook 48 Notebook
My stereo in 1997 chevy caviler is turning off and on when turned up to a high volume. I have a sony xplod 52 watt by 4 channel radio. With two 6x9 sony xplod 50 watt rms and 300 watt peak power in the...
Most likely cause is heat. The clearances behind the radio are often not sufficient to provde the proper air coolling that the higher power radios need. The heat sinks on the rear of the radio require a certain amount of air flow to dissipate the heat generated under high load conditions. If you add summer heat to the equation, you can have the radio going into thermal cutout to protect it circuity.
May 27, 2011 | 1997 Chevrolet Cavalier
Audio problems connecting ps3 to bose lifestyle 48 system
audio has to connected seperatly.vs 2 is for video connection only..Bose is a ripoff.... u pay all that money and you need a seperate audio connection plus all those wires..it isn't worth it and regret i bought it.
Jun 14, 2009 | Bose Lifestyle 48 Series III System
How do I fix the problem so they work again.?
A 1000 WATT AMP HAS PROBABLY GONE INTO PROTECTION MODE BECAUSE YOU ARE TRYING TO RUN 1600 WATT SUBS COMBINED
Jun 08, 2009 | Car Audio & Video
Need to hook up to a 4000 watt amp
Why would you hook up 4000 watt amp to a speaker that has only 1000 watts. Try a 800 watt amp instead unless you just dont want the spealers.
Apr 13, 2009 | Theater Research TR-9500 Car Subwoofer Box...
1000 watt amp sony xplod
how do you have your system hooked? What speakers do you have? There is a lot more too it then just wattage.
Jan 23, 2007 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
Car Audio & Video Logo
Top Craig Car Audio & Video Experts
xxxxxx xxx
Are you a Craig Car Audio and Video Expert? Answer questions, earn points and help others
