Question about MTX Terminator TN400/4 Car Audio Amplifier
MTX Terminator Amp...Red light comes on when it should be green.
I have a solid ground and i'm getting power but the light glows red when i turn on my car. speaker wires are double checked and everything. any ideas?
  • 103 Answers
Its just a power light to let you know its on
Posted on Jul 25, 2009
5 pin harness has the following wires on a Realistic radio cassette car player: 1. Red - Power 2. Black - Negative ground 3. Green - ? 4. Yellow - ? 5. White - ?
Hi Marc,
What you have is a "common ground" car stereo which means all speaker negatives will be chassis (earth) ground. The following is a common wiring diagram for vintage aftermarket car stereo.
Constant 12V / Memory Keep Alive - yellow
Accessory - red
Ground - black
Right front speaker(+) - green
Left front speaker(+) - white
Even though I am 99.9% positive this is correct, please use at your own risk as I cannot be responsible if you fry your unit.
Good Luck!
~Rich G.
Feb 11, 2018 | Cars & Trucks
I bought a mtx terminator amp model no TNA251 600 watt and two subs installed. It works good for few days but now its not cranking up proper bass and sound. It always has three solid red lights everytime....
does it do this all the time when you turn it on? any sound at all?
provide more information, but my guess its that the amp is blown. replace it or sell it for parts.
Nov 11, 2013 | Car Audio & Video
Tc 8001 red light
on some amps there is a duel light. red and green usually. red means it is in protect mode or you didn't hook up your remote wire. if in protect mode, it could mean a number of things. did you hook it up with speakers and everything?
Mar 01, 2012 | MTX Thunder® TC8001 Car Amp
I recently purchased the mtx terminator amplified bass system and wired everything in, but the amp seems to not be working, i checked the power and the wires going in are a good circut but none of the...
If none of the lights are coming on for the amp then the amp is not getting power and/or ground. Check the connections. Check the fuses. Or the amp is no good.
May 05, 2011 | MTX Car Audio & Video
I just replaced my old terminator 12" subs with two new 12" jl audio w3 4ohm subs and the mtx terminator amp keeps shutting off and flashing red. I kept everthing the same from my original mtx...
You may have touching speaker leads going into the amp. Make sure the tinsel is not touching across the speaker inputs on the amp. Also check your ground. It should be solidly connected to the vehicle chassis in a paint-free location. Finally, make sure there are no exposed speaker wires touching the vehicle chassis.
Mar 09, 2011 | MTX Terminator TN400/4 Car Audio Amplifier
I have hooked up my subwoofer and amp to my factory stereo in a 2011 camry. My power wire is hooked directly up to my battery, my ground to the chassis and my remote to my fuse. I have my RCA wires (RCA on...
Rewire your stereo cables as such:
Red- positive - battery
Black - ground - chassis
Remote (Yellow) - ignition switch
The "LINE OUT" should go to your SUB-WOOFER.
The while-lined wires paired with the solid colored wires are either your Front LR and/or Rear L/R.
Jun 14, 2010 | MTX Thunder 4500 T4510-04 Car Subwoofer
Mtx terminator 250 stop workind and red light is on
check the ground make sure its not loose from the frame of your car thats why the red light comes on.
Jun 03, 2010 | MTX Terminator TN400/4 Car Audio Amplifier
I have an eclipse cd5425. the unit shuts off as soon as i turn up volume. then comes back on. how can i keep unit on? thank you.
sounds like you have a speaker problem. Disconnect the wiring harness from the eclipse and check the speaker leads with an multi-meter. Each speaker should read something close to 4 Ohms resistance. If 1 or more of the speakers read 2 Ohms or less, the radio is going into protection when you turn it up. You would need to replace the speaker/s. The only other thing I can think of is the power connections. Double check that the yellow and red wires are a solid connection to 12 volt power (yellow=constant, red=switched). Also be sure that the radio's black wire is going to chassis ground, there may not be a ground in the harness or it may be only getting ground through the antenna connection. Good luck
Mar 02, 2010 | Eclipse Car Audio & Video
I bought a MTX Terminator amp and the light is red when I turn it on, but it works. Red usually means protect mode but it works fine. Should the light be red or green?
all depends on that amp... if there was an issue it wouldnt work, and the light would be by a protect symbol... if its just red next to the power symbol i say no issue.
Feb 18, 2010 | Car Audio & Video
Can't get my amp to work right
Recheck each and every wire connected to the amp. If everything is wired correctly, then you either have a shorted speaker, or a shorted pair of speaker wires, or one of the speaker wires is touching another grounded location, or the amp is blown.
That's about as far as you can take it, unfortunately.
Double and triple check all you wiring. EVERY wire! Don't assume anything about any single wire.
Nov 16, 2009 | Power Acoustik PS2-820 Car Audio Amplifier
MTX Terminator TN400/4 Car Audio Amplifier Logo
960 people viewed this question
Top MTX Car Audio & Video Experts
hoyzee1
Mark Skinner
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
