Fi 5120C only scans on one side (the reverse side)
3 Suggested Answers
mohanchennai
  • 490 Answers
SOURCE: fi 5120c will not scan sheets that have different color entries
Check the software settings in the scanning software. Try running scandisk in the OS. Check if the scanner is working with any other comp. If it works, may be your OS is corrupted.
S. Mohan, Chennai
Posted on May 30, 2008
  • 15 Answers
SOURCE: fi=5120c conflict with another scanner
Check in the order as i had written.
1. Is both the scanners are connected in usb, then this problem will arise. Connect fujistu in scsi and check it. And connect only the cannon and check. because there is a chance of usb port or usb cable problem.
2. Then it depends up on the driver you are selecting. whether you may be selecting fujitsu and giving scan .
3. Check is the driver for cannon is properly installed and also have a check in the device manager is there is any question mark is showing in the driver for particular scanner.
4. If you are using any certain application like scandall application you can select the scanner whichyou want it to scan by selecting the SELECT SCANNER.
5. Is your driver is a new version. If new version is available then update the driver and check it out.
If you have any other problem you can contact me .Regd. the fujistu i can help you.
My mail id is : ramanathanr@integramicro.com.
Posted on Nov 11, 2008
Fujitsu fi5120c scanning every other page
hi, it sounds like the scanner is multifeeding, and as you have it set to A4 once that length is scanned, its just getting rid of the rest and starting the new page. Try cleaning or replacing the separation pad, or to prove the fault, hold the 2nd sheet until the 1st is scanned and its trying to pick thyen 2nd.
hope that helps, let me know how you get on.
Jan 18, 2012 | Fujitsu fi-5120C
Fi 5120c scanner - Vertical Line left of Center
It is the GLASS. Line up your paper to see where the lines came from (check front side and back side). Open the scanner by pushing the Blue Button on the right. Look for the glasses at the bottom of the scanner at the spots making the lines. Clean it and re-scan.
Oct 11, 2011 | Fujitsu ScanPartner fi-5120C Pass-Through...
5120C does not retain settings betwen scans. I tell it to skip blank pages and it does it on the 1st scan but not subsequent scans.
unfortunatly these settings are only temporary. If you go to the main settings you just may be able to set it permanitly (if i spelt that right...)
Feb 23, 2010 | Fujitsu fi-5120C
Fi=5120c conflict with another scanner
Kindly reply back immediately once you get my email.
Nov 04, 2008 | Fujitsu ScanPartner fi-5120C Pass-Through...
Multi scan
it is only made and set up for a single scan at a time. i thought the same thing when i had one.
Jun 27, 2008 | Fujitsu fi-5120C
Fi 5120c will not scan sheets that have different color entries
S. Mohan, Chennai
May 29, 2008 | Fujitsu fi-5120C
Fujitsu FI 5120C pop up error for paper jam
Please clean the separation pad and the pick roller.
If this don't help change them.
The Fujitsu sparepart numbers:
pad PA03289-0003
pick roller PA03289-0001
How to scanning double sided document in fujitsu 5120c scanner
You may want to try using Laser Fiche. This scanning software allows you to select "Duplex" which allows you to scan double sided document
Oct 23, 2007 | Fujitsu fi-5120C
FI-5120c
Invalid orientation/long scan combination. Check the KScan ScanDirectionCap and ScanContinuousCap properties and set ScanDirection and ScanContinuous accordingly is for error 20080 and for 20090 means Peripheral stopped by user. Stop button was pressed.
Jul 31, 2007 | Fujitsu ScanPartner fi-5120C Pass-Through...
26 people viewed this question
jasbo
jasbo
