SOURCE: the cursor moves by itself during typing.
I have found this is usually the small button in the middle of the keyboard (mouse button) I have tried some software to remove this problem but it did not on my laptop I ended up carefully removing the key board and disconnecting the two wires that go to the button My cursors kept moving across the screen
SOURCE: cursor moves while typing to another place
If this is an IBM WW it sounds like the L. margin is changing. If so try putting a few drops of WD40 on the silver shaft thatthe carrier slides on.
DickyO
SOURCE: Acer Keyboard Cursor moves without my knowledge
Someone has remote assistance to your computer. Go into Control panal and turn "Remote Assistance" off
SOURCE: cursor won't stay where I move it with the mouse
Hi, your first problem (and possibly second problem) sounds like it's the "Insert" function on your keyboard. I've seen this a lot. Find the Insert key on your keyboard. It's normally off to the right side with the Home, End, Page Up, and Page Down keys. When you have the problem, press the Insert key and then keep typing. It should toggle between the cursor moving with typing, and not. If this was helpful, please rate my response. Thanks!
SOURCE: automatically cursor jumps
I have a Thinkpad T40 that's had this problem for around a year. I've completely disabled the Touchpad, so that's not the cause. I use only the TrackPoint "button" in the middle of the keyboard, and the cursor jumps when it's not being touched.
I have Avira anti-virus working actively (often too actively, since it updates twice a day or more!), and run anti-malware programs from time to time, so I don't think that's the answer either.
HELP?!?
