Question about The Computers & Internet
How to solve the next 6 winning numbers - The Computers & Internet
Next winning numbers
Of course no one can predict the lotteries winning number, but there are ways to improve your odds. If you were track all of the past lotteries winning numbers, you will see that certain numbers seem to keep coming up more than the rest. There are software programs you can download that allow you to keep track of lottery number. And there are websites that also track and allow one to download these numbers. No guarantees of course, but it may improve your odds at hitting three of four number wins.
Jun 16, 2017 | Computers & Internet
Picking the winning numbers
Impossible. It is a game of chance with a 14 million to 1 chance of picking 6 numbers from 49. If you want to win big money if you do win, pick all number that are higher than 12, or higher than 31. The reason for this is that people use birthday and ages. Birthdays a constrained by 12 months and 31 days. If you pick numbers outside these, if you do win, you won't have to share.
Remember the main thing though.....
You have to be in it to win it!
Good luck.
Jan 25, 2017 | The Computers & Internet
Mark, jayne and sara like playing cards together. they always play last card, snap and cheat .they have kept a record of the results of their last 50 games. MARK Wins : LAST CARD - 5 SNAP - 7 CHEAT-4 JANE...
a). No. of ways in which 12 Last card is played in the last 50 games is 50C12. For the last game to be last card, 11 games of last card must be played in first 49 games and this can be done in 49C11 ways.
So, the probability in this case = 49C11/50C12 = 12/50 = 6/25..
b). No. of ways in which Sara can win 21 of last 50 games is 50C21. Probability of Sara winning the first game = 1C1 * 49C20. = 49C20.
So, probability that sara won't win the First game = 1 - (49C20).
Hope this one solved your problem. If you have additional doubts, please come back to us.
Regards
Sunny.
P.S: If the solution is helpful, please accept the solution.
Jul 09, 2011 | Computers & Internet
I erased all the files on my memory card and when i put it in my camera it says the card is still full
Solution overview: You need to "clean" the SD card by using the clean command in Diskpart and then format the card in Disk Management. This solution will show you how to accomplish this.
1. Plug the SD Card into the computer.
2. Press Win+R to open the Run command.
3. Type "cmd" into the dialog box and press enter to open a command prompt.
4. Type "Diskpart" into the command line of the command prompt to start Diskpart. Wait for Diskpart to load.
5. Type "List Disk" and press enter.
6. Take note of the number of the disk that's associated with your SD card.
7. Type "Select Disk X" where X = the number of the disk that's associated with your SD card and press enter. Make sure the command prompt reports that Disk X is selected.
8. Type "Clean" or "Clean all" and press enter. Clean will be faster but might not solve your problem. If using the clean command doesn't solve your problem, then repeat steps 1-8 and type "Clean all".
9. Wait for Diskpart to complete the cleaning operation - this may take some time so wait until it's completed!
10. Close command prompt.
11. Press Win+R to open the Run command.
12. Type "DISKMGMT.MSC" into the dialog box and press enter. Wait for Disk Manager to load.
13. In Disk Manager, scroll down and select the SD Card.
14. Right click and select "New Simple Volume".
15. Select Next, Assign Drive Letter, and select "Next" again.
16. Select "FAT32" for File System and "Default" for Allocation Unit Size. Fill in whatever you want for the Volume Label. Make sure "Perform quick format" is checked and click OK.
17. Wait for formatting to complete and remove SD card from computer.
18. Plug SD card into camera to see if the problem is solved.
Good luck and thanks for using FixYa. Post back if you have any questions or problems.
Mar 23, 2011 | PNY 4GB microSD High Capacity Mobile Media...
I have been using my PNY OPTIMA HC 4gb memory card to upload pics for months and all of a sudden it will not read or allow me to upload
Solution overview: You need to "clean" theSD card by using the clean command in Diskpart and then format the card in DiskManagement. This solution will show you how to accomplish this.
3. Type "cmd" into the dialog box and press enter to open acommand prompt.
4. Type "Diskpart" into the command line of the command promptto start Diskpart. Wait for Diskpart to load.
7. Type "Select Disk X" where X = the number of the diskthat's associated with your SD card and press enter. Make sure the commandprompt reports that Disk X is selected.
8. Type "Clean" or "Clean all" and pressenter. Clean will be faster but might not solve your problem. If using theclean command doesn't solve your problem, then repeat steps 1-8 and type "Cleanall".
9. Wait for Diskpart to complete the cleaning operation - this may take sometime so wait until it's completed!
12. Type "DISKMGMT.MSC" into the dialog box and press enter.Wait for Disk Manager to load.
16. Select "FAT32" for File System and "Default"for Allocation Unit Size. Fill in whatever you want for the Volume Label. Makesure "Perform quick format" is checked and click OK.
Good luck and thanks for using FixYa. Post back if you have any questions orproblems.
Mar 15, 2011 | PNY 4GB Secure Digital High Capacity...
Not Instol Form win 7
To Download:
1 Go to hp.com 2 Click on Support and Drives 3 Enter your product name or number, in this case just type in Officejet 8500 All-In-One 4 Hit go 5 Choose your operating system 6 Hit Next 7 Click on the link that says Driver - Product Installation Software 8 Save it to your desktop
Feb 03, 2011 | Office Equipment & Supplies
Multipication distributed to find 6 x 19
I am unsure of what your question is? You want to know how to do multiplication of two digit numbers? Or are you looking for the answer to your question of what is 6 x 19?
I will answer both ways in hope that it solves your question at hand.
To do multiplication of two digit numbers, take the number with two digits and write it down like this:
19
Then write the next number under it like this:
19
x 6
____
Take the number 6 and multiply it by the number 9. You get 54. But you can't write 54. You write the 4 and carry the 5 and put it above the number 1. Then you multiply 6 x 1 which is 6 and add the number 5 carried above which becomes 11. It looks like this:
5
19
x 6
______
114
Your answer is 114.
I hope this answers your question?
Dec 06, 2010 | YouTube Videos
1111 base 2 + 1010 base 2 my answers are either 20 or 30
You can solve this the same way you solve regular base 10 addition. In base 10, if you add two numbers and the result is greater than 10, you carry a 1 to the next column to the left. So 6+3=9 (no carry), but 6+5=11 (we carried a 1 to the next column).
In base 2, there are only 2 digits to use (0 and 1) and we carry when the result is greater than 2. So in base 2, 1+0=1 (no carry), but 1+1=10 (carry to the next column).
So to do your addition:
In the 1's column, 1+0=1, no carry
In the 2's column, 1+1=0, carry 1 left
In the 4's column, 1+0+1(the carry from before)=0, carry 1 left
and so on.
It's easier than base 10, with only two digits to deal with.
Feb 03, 2010 | Mathsoft StudyWorks! Mathematics Deluxe...
Computers & Internet Logo
41 people viewed this question
Top The Computers & Internet Experts
Ap12
Ap12
MonsterByte
Level 1 Expert
Kelley Hopper
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
