Question about Sony Televison & Video
Sony 2007 Bravia Full HD 1080 has sound echo
2007 Sony Bravia sound issue - has an echo
arclight1217
  • 208 Answers
SOURCE: my sony model is dsc-h7 full hd 1080 15x optical zoom 8.1 megapiksel
I CHECKED SOME DIFFERENT SITES FOR SOLUTIONS AND FOUND ONE THAT PROBABLY MEANS MORE TO YOU THAT ME, NOT BEING FAMILIAR WITH YOUR CAMERA. IT STATED THAT TO RESET THE ERROR ONE NEEDED TO GO TO THE CLOCK SET MENU, TURN OFF THE CAMERA AND THEN REMOVE THE MEMORY CARD. THIS WAS SUPPOSE TO RESET THE ERROR CODE. I HOPE THIS HELPS YOU. WISH I HAD ALITTLE MORE TO GIVE YOU, BUT IF THE PROBLEM IS STILL THERE REPLY AND I'LL SEE WHAT ELSE I CAN FIND. GOOD LUCK!
ARCLIGHT1217
Posted on Nov 04, 2008
  • 4 Answers
SOURCE: can i convert sony bravia 46" V-300A HD RADDY INTO FULL HD 1080P
no you cannot change the HD to 1080p . if you could why would there be any 1080p sales???? most people cant see the differance between 720 and 1080p and most sat./and cable HD is only 720p anyway
Posted on Jan 31, 2009
  • 150 Answers
SOURCE: I have a 4 month old sony bravia 1080 120mhz Sony
Not common but electronics are electronics , we can have failures right out of the box. Generally Sony is reliable and I must say that you should not have to worry about cost , Is it not under warranty - its only 4 months old !!
Posted on May 13, 2009
  • 9 Answers
SOURCE: make my wicked system WICKED. Sound hd issues palit hd4850
try these options:
1. try adjusting the main volume of your digital output(tab) under your hd audio manager.
2. try changing your cable(s).
Posted on Apr 09, 2010
hmerchant110
  • 7191 Answers
SOURCE: Seeking instruction manual for(1) Sony
Hi Denis,
You can download and print the instruction manual for Sony NEX-5 in PDF format by clicking this link.
Also, please let me know the exact model number for the Sony full hd 1080 120gb handycam so that I can provide you with the specific manual.
Adobe PDF Reader is required to view this manual. Click here to download the latest version of Adobe Reader.
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Posted on Oct 07, 2010
Sony 1080 full hd on the screen a pop up says the projction lamp is out, do i need to take it to a shop or can i replace the lamp myself
Please understand that the TV does not have a lamp. The lamp is only available in rear projection TVs. The issue seems to be odd. I suggest that you unplug the TV for more than 5 minutes to perform a power resetting and check if that helps.
Jun 15, 2011 | Sony BRAVIA XBR46HX909 46 in. 3D HDTV
I have a Sony Bravia kdl-32s2020 LCD with MPEG-2 DBV-T. Are there any possibility to upgrade them to DVB-C MPEG-4. This model is also HD-ready. Haw can convert them to FULL-HD (changing SD receiver with...
This tv have the capabillity for the Full HD max resolution 1080i or 1080p.The problems u have is not the tv capabilities.The tv incomming broadcasting signals are vary like DTV,SD,480i,720i low end HD.Max HD resolutions are 1080p or 1080i.
Dec 01, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
On Sony Bravia KDL-S40A12U screen occasionally turns black for a couple of seconds. Only happens on the HDMI channel. Sound still works, but no picture?
Possibly source issue(Box/Satt). Some HD boxes do not have very good HDMI processors or the actual program source feed may be faulty. HD sources are still not 100% efficient
Dec 03, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Switching between a 720 hd channel and a 1080 hd
The unit has an auto detection circuit to determine what signal is being input, it then processes it, however if the signal is altered (different channel) the TV will at times try to process it through the wrong resolution circuit causing problems. Change the input of the TV and then change it back and it will redetect the 720p instead of the 1080i and display it properly. Check with Sony for possible updates.
Crampy
Nov 28, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Make my wicked system WICKED. Sound hd issues palit hd4850
try these options:
Jul 06, 2009 | Palit Microsystems RADEON HD4850, PCI...
May 13, 2009 | Sony BRAVIA KDL-40V3000 Television
Can i convert sony bravia 46" V-300A HD RADDY INTO FULL HD 1080P
Jan 31, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Screen goes dull at times
The dulling picture really sounds like a lamp failing. You would need the sony lamp xl-2100u
The ghost image may be easier to fix, sometimes as lcds age you will get a slight shift in a color. deep in the sony menu there is a parameter (menu-setup-imageshift) that will give you 3 levels of correction, this may solve this issue.
Dec 04, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Bravia
I have purchased KLV-40W400A Full HD but I am not satisfied with the picture quality. When the issue was raised sony is putting blame on Tata Sky and vise versa.
Kindly suggest.
Jun 19, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Televison & Video Logo
26 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
