Electric scheme waxiba xb - 781c
Transformer power supply defective device. What voltage does it have in the secondary?
SOURCE: MS9700 secondary voltage
I am working on the same situation. DId you first check to see if it isn't the fuse that has blown? Radio Shack has a 4 pack of 2 amp fuses for $2.49 which I think will work. Their catalog number is 270-1064. These as 5x20mm in size (the 1-1/4 x 1/4 inch is way to large) and they are slow blow - designed for this type of household equipment to protect from short circuits and power surges. If you are lucky maybe it is just the fuse. Since I can find no other information about this unit - especially the transformer - I'd check eBay for a working one. If you can get it cheal and it works test the power output with a VoltOhmMeter (VOM) and once armed with the info you can let me know too what the output is . You can then get a new transformer - have 2 working units - can keep or sell one to recoupe your eBay purchase. Just a thought. Hope it is only the fuse.
Posted on Dec 08, 2005
  • 68 Answers
SOURCE: power supply (transformer)
You should have just one supply voltage on an AM type dishwasher. Find the data plate in one of these places - frame behind RH door, on the control box, under the front cover. The required voltage and phase (1 or 3) will be listed there.
What is the problem with the unit?
Posted on May 25, 2008
SOURCE: Kenwood RXD 501
Do you already check the thermal fuse on the primary side of the transformer
Posted on Oct 01, 2008
  • 441 Answers
SOURCE: power supply problem.no secondary output voltage
I would stick to replacing the whole power supply rather than bits and pieces.
http://store.richspsxparts.com/pl2posubov4.html
The website above sells PS2 power supplies.
If you want to try and replace bits and pieces, you can probably find individual components at Radio Shack... but you would have to be good at troubleshooting and soldering.
Posted on Oct 20, 2009
j2easy
  • 152 Answers
SOURCE: Pioneer SX-203 power transformer ATS1526 secondary voltage???
just a question.1st.. if you don't know what you should have... then what are you going to do... if it's lower or higher ... seems like you should have a print before you go looking...go check at the off and on switch for the standby .. 9v more or less to trip the relay to turn the sys. on... now get a print...or go backwards to the transformer to see if it's blown. or something in between is open
Posted on Dec 11, 2009
Model "KOT-152UW" The
well inside the unit check for any burn fuses on the power supply area, and into the control board. fuse basically the one will tripped if power surged occurred..
Jun 27, 2008 | Microwave Ovens
I need to know the secondary output voltage of power transformer.
If the primary of the transformer has failed it doesn't follow that the main power supply parts are also faulty. However since the transformer is a safety part you need to replace it with the same thing.
However it seems from this website that transformers are not expensive compared to a new deck, so a look around here might solve the problem.
Mar 10, 2014 | Numark ttUSB Turntable
Power supply output for Yamaha p4500 secondary output for the power supply so that i could check the voltage
Hi Joel, although we've sourced detailed schematic for this P4500 amplifier, there are no many voltage details on it for manufactures sake. Anyway, mine findings are. Secondary winding on main transformer should supply no less than 2 x 75 volts which makes after rectifying and filtration no less than 2 x 90 volts on capacitors with amplifier without input signal. Also transformer has to be very "hard" , otherwise amp will start clipping before reaching stated wattage on output.
Oct 17, 2011 | Yamaha P4500 Power Amplifier 2-Channel
My transformer is burned.Now I need to know what the secundairy voltages are
Transformers USUALLY don't get burned as they are usually protected by a fuse. This one supposedly uses a 3 amp fuse which should have protected it from getting burned. If you can find a schematic or if you can find the specs on the output amp power supplies we can probably calculate the voltage of secondary. We know only that it is supposedly 120 Watts and uses an 8 ohm speaker. The RMS voltage should be about square-root 120*8 = sqrt 960 = 31V*1.4 = approx 44 volts peak... so you will need to get about +/-45 volts out of the supply for headroom... which will need approximately 34 volts AC given diode drop and droop of filter caps. These are really rough educated calculations from the tiny bit of info we have.
Finding a transformer to replace this matching these requirements will be near impossible without getting device from the original manufacturer OR having your rewound.
I would first verify the transformer is bad (only plausible cause is somebody over-fused it or a winding shorted)... Remove all the secondary loads. Put a 3 amp fuse in AND put a 60 Watt light bulb in series with teh power cord to act as a limiting device to test the transformer... Note that transformers DO have a bit of odor as they are usually impregnated with a varnish...
Jan 11, 2011 | Hartke Kickback 12 Bass Amp Warehouse...
Hi i m sanjay i m having sony colour television kv-2782me7 i found some problem in power supply section i m geting low voltages frm secondary output i want 135 ,25 ,8 , and -33dc voltages bt i m geting...
there is a possibility of a shorted turn of the flyback transformer. To test. short B-E together on the horizontal output transistor and connect 60W globe across C-E. measure voltage across lamp - if it comes up to 135v then you have a short either in the horizontal circuit or secondary circuit off the flyback transformer or even the transformer itself.
Aug 10, 2010 | Televison & Video
What is the secondary voltage of power transformer
The schematics do not show the actual voltage.
From the design, the phantom power secpndary should be around 35 to 45 volts AC.
The 16 volt supplies would require a secondary winding that will be around 26 to 32 volts center tapped.
Transformers are quite reliable and unless a voltage is missing, the transformer is likely OK.
The most suspect items are the electrolytic filter caps if the voltage is not the design 16 plus and minus values.
Jun 16, 2010 | Mackie 1202vlz3 12 Channel Mixer
What are the secondary voltages off the transformer supposed to be?
The secondary voltages of a transformer are stepped down voltages. For example a transformer might be stepping 120 volts AC down to 25 volts AC in the secondary. Which then would be rectified by a bridge rectifier in the power supply and converted to DC Voltage which would be used to bias transistors or tubes and other electronic components. The amount of voltage that is output for use is determined and calculated by the engineers designing the amplifier or pre-amp.
Aug 26, 2009 | Audio Players & Recorders
Kenwood RXD 501
Oct 01, 2008 | Audio Players & Recorders
My Pioneer Receiver Shuts Power OFF within 10 seconds I put it on.
Hi Sharad! Do this maybe of help. Turn the power off. Wait about 10 seconds, then power up again. Get close to the reciever and listen for a click-not from the speakers,from the recievers itself.If you hear a click, you can assume that the power supply is ok for that circuit.This does'nt eliminate the power supply problem but it will do for now.You would have to check both the positive and negative voltages from the power supply to see if both are present or if one or both are missing. This would be dc voltages and the positive voltage must be equal to the negative voltage ,if one is higher than the other, the regulator transistors in the power supply maybe defective. The transformer can be checked for AC voltage before the power supply.You know that the secondary is good because the dial lights. For this kind of problems you better change the regulator transistors with desame number.
Jun 14, 2008 | Pioneer Audio Players & Recorders
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
