Stoage full. How do i download and store my recordings so i can record more. I donot have a computer
  • 78 Answers
Hi, if it has a CD drive, you can burn the copies to a cd/ dvd disk thus freeing up your space by deleting the copied info.
Posted on Apr 28, 2017
Hi the play button on my olympus digital recorder will not play. The memory says full, however I am unable to delete also.
Plug the recorder into your computer and download your files to a drive or folder.then delete old files from Olympus device.
Dec 07, 2016 | Olympus Audio Players & Recorders
I can not record video, please i need help
Check if your memory is full either phone memory or your memory card and check if where your recorded video will be stored after recording. either the phone memory or memory card if any of them is already low in memory space you really can't start video recording if you don't have enough memory for you to store the video you want to record..Hope it will help you.
Jul 09, 2011 | LG KS20 Smartphone
My WS 100 says FULL and won't either let me put it
The recorder should be formatted only by using the internal FORMAT function found in the recorder's Menu. Using a computer to format the recorder may corrupt or delete system files needed to run the recorder, so formatting via the computer is not recommended.
Individual files can be deleted from the recorder while it is connected to a computer without negative effects.
Feb 04, 2010 | Olympus WS-100 Digital Voice Recorder
Recording from sky planner to dvd
Yep all you will need is a DVD recorder Philips do a good low cost version DVDR 3380 and a Philips DVD+RW ( this is the type that you don't need to finalize before you can use it in your PC)
All you have to do is make a connectiion to the video out of the Sky box using the suitable connection normally a SCART lead in to the EXT1 or EXT2 of your DVD recorder.
Play the Sky program in your planner and hit record don't forget to select the time you require 1 (HQ) 2,4 or 6 (SLP) hours. It will take as long as the program take to run to record it.
The best way to get the DVD-Video into your PC is to use the excellent TMPGEnc v4.0 Xpress from Pegasys use the Souce Video Wizard.
Then select the DVD-VR button this will read in the DVD content and then allow you to edit it and re-encode to almost any format.
If you select over 4 hours or recording most DVD standalone recorders will revert to Half D1 this equates to 360x576 instead of the Full D1 resolution of 720x576 (standard PAL for DVD-Video) you will need to use this filter to convert the half to full download it here Half D1 to Full D1
LOL
Sep 28, 2009 | Compaq Presario 5000 PC Desktop
Erasing
I had the same problem. I downloaded the instruction pamphlet at http://www.olympus.co.jp/en/support/imsg/vtrek/download/manual/ws/man_ws100_ws200s.pdf and reformatted the recorder. It seems to work fine now.
Formatting the Recorder (FORMAT)
If you format the recorder, all function settings will return to their defaults.
All files stored in the recorder will be deleted.
If you have important files that you want to save, connect the recorder to a computer and
transfer those files from the recorder to the computer before formatting the device.
1 Press the MENU button.
2 Press the FF or REW button to choose “FORMAT”.
3 When the PLAY button is pressed, “nO” is displayed.
4 Press FF or REW to select “yES”, and press the
PLAY button.
After “ARE yOU SURE” is displayed, “nO” will be displayed.
5 Press FF or REW to select “yES”, and press the
PLAY button.
“DONE” displays when formatting ends.
s It may take up to several tens of seconds to finish the initialization. Do not remove the battery or detach
the battery compartment from the recorder during that time. Otherwise data may be damaged.
s Never format the recorder from a PC.
s When the recorder is formatted, all the stored data, including locked files, are erased.
Sep 20, 2008 | Olympus WS-200S
I get a "full" message but it is not full
Try this:
4 Formatting the Recorder (FORMAT)
PLAY button.
PLAY button.
May 28, 2008 | Olympus WS-100 Digital Voice Recorder
Ws 200s deleted files but still full
PLAY button.
PLAY button.
Mar 20, 2008 | Olympus WS-200S
"full" message
I had the same problem; see earlier post about record times. The "format" solution worked for me.
Dec 19, 2007 | Olympus WS-100 Digital Voice Recorder
Recorder says "PLEASE DOWNLOAD FILES," but there are no files to download
The DS-2 has a format option in the menu under submenu. After you choose start you will see a progress bar and it should return to full record time. Use on a MAC seems to cause the reduced record time more often than on a PC.
Dec 11, 2007 | Olympus DS-2 Digital Voice Recorder
 Grubhead
Grubhead
