Handset ON/OFF/Mute buttons Do not work. Batteries OK. Can get TV on from mains when blue light appears for seconds + CH button. Cant switch off. 81 and confused can you help?
2 Suggested Answers
andrewjumba
  • 78 Answers
SOURCE: Handset ON/Off buttons do not work. Standby will not come on. Switch on from mains blue light on for seconds. Push CH button when light appears TV comes on. BUT can't switch it OFF.
Take your TV for servicing
Posted on Apr 28, 2017
How can I set the channel BACK to CH 3 from CH 4
1) Set your TV to channel 3.
2) Insert a pre-recorded tape into this unit.
3) Press the OUTPUT button on the DVD/VCR so that the VCR OUTPUT light is lit.
• If noise appears on the TV screen, press the VCR/TV button on the remote control.
4) Press the PLAY button once.
5) After a few seconds, press the PLAY button on the DVD/VCR for 3 seconds.
• The RF output channel will change to channel 3 from channel 4 and you will see a playback picture.
• When a picture does not appear on the TV screen, repeat step [4].
6) Press the STOP button to stop playback.
Nov 17, 2007 | Emerson EWD2004
Replaced power supply and reset still on light no sound just a flashing green light
Remove Mains Plug and press Standby switch from LED Panel for 30 sec.
Press Input & Ch Down Switch from LED panel and plug in and start LED
LED will start and "K" will appear on screen
Press Ch Down & Vol Down switch at same time
You will get 1/10 page on screen
Go to 9/10 page by pressing left & right button from remote
Select EEP and press Ok button from remote
After 30Sec remove main plug and restart LED.
Dec 13, 2015 | Sharp AQUOS LC-32D44U 32 in. LCD TV
After replacing power supply and resetting tv still only have green flashing light
Remove Mains Plug and press Standby switch from LED Panel for 30 sec. Press Input & Ch Down Switch from LED panel and plug in and start LED LED will start and "K" will appear on screen Press Ch Down & Vol Down switch at same time You will get 1/10 page on screen Go to 9/10 page by pressing left & right button from remote Select EEP and press Ok button from remote After 30Sec remove main plug and restart LED.
Accidently changed something and not able to get antenna tv now - do not ahve cable here at work
I am unable to see at a glance how to correct this but it is between its menu, channel and volume buttons to alter the settings it may be worth to run through the re-tune sequence below?
To preset a channel or to change a preset channel, follow the procedure below.
1) Press the POWER button to turn on the TV.
2) Press the MENU button so that the menu display appears
on the TV screen.
3) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
Then, press the VOL(ume) ? button.
4) Press the CH(annel) ? or ? button to point to "AUTO PRESET CH".
The tuner scans and memorizes all active channels in your area.
? The TV distinguishes between standard TV channels and cable channels.
? When AUTO PRESET CH action is completed, the lowest memorized channel reappears on the
screen.
? When you press the CH(annel) ? or ? button after selecting "AUTO PRESET CH", the tuner
will stop at the memorized channels only.
? The TV may recognize TV channels to be CATV channels by the receiving conditions. In this
case, try AUTO PRESET CH action again in the fine receiving conditions.
? When AUTO PRESET CH is activated where there is no TV signal input,"NO TV SIGNALS"
will appear on the display after the completion of channel scanning.
[ADD/DELETE FUNCTION]
1) Press the MENU button so that the menu display appears on the TV screen.
2) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
3) Press the VOL(ume) ? button so that "ADD/DELETE" is selected.
4) Use the CH(annel) ? or ? button to select the
channel you wish to put into memory or to erase from memory.
Note: The menu will disappear in about 10 seconds.
Perform "ADD/DELETE" function while this display appears on the
screen.
? Press the VOL(ume) ? or ? button to light up the channel number
in LIGHT BLUE if you wish to add the channel into memory.
in LIGHT RED if you wish to erase the channel from memory.
5) Press the MENU button to exit the menu.
Hope this helps.
Jun 29, 2015 | Durabrand DWT1304 13" TV
My new amino remote only works on my tv and not on my aminorouter. If a switch from tv to stb I can still use the vol button but the ch. button does not work. I cant change the channels on the amino...
Try re-coding the remote. Hold down STB and OK for a few seconds. Then when the red light is steady on the STB button you put in the code 000. By doing this you have reset the remote control. Also a good trick is to remove the batteries and put them back in. With that you are basically turning the remote off and on again. The good old restart.
Mar 22, 2010 | Philips PM3S Remote Control
GE DECT 6.0 Phone Light Blinks
First thing to try is to pick up handset or place on speaker. On the answer machine itself without trying to call your cable providers voice mail service...press the message button to ensure all messages have been heard or erased.
Second, unplug your phone power from the wall and wait two minutes before powering on the phone.
Last replace batteries in the phone if you have batteries in the phone now...may be low battery signal.
May 29, 2009 | Uniden Cordless Phone
Cannot program, menu stuck on Spanish, cannot access main menu from mute/ok button
I know this should be a MUCH more techie answer, but have you tried just asking a nearby Mexican to help you? Just a thought.....
You say you cannot get to the menu from the mute/ok button?
What happens instead?
FROM DA BOOOK looks pretty clear to me.
Handset Setup
1. Make sure your phone is OFF (not in TALK mode).
2. Press the mute/menu OK button to go to the main menu.
3. Press CALLER ID-VOLUME ( 6 or 5) button to scroll to HANDSET SETUP.
4. Press mute/menu OK button to confirm and you may program the following items: Language, Handset Name, Ringer Tone, Ringer Volume, VIP Melody, Key Tone, Set Day/Time, Equalizer, Area Code, Tone/Pulse, Registration, Deregistration and Default Setting.
NOTE: During programming, you may press the END/cancel button at any time to exit the sub-menu and return to the menu.
Language
From the Handset Setup Menu:
1. Press the CALLER ID-VOLUME ( 6 or 5) button to scroll to the SET LANGUAGE sub-menu.
2. Press mute/menu OK button to enter the menu. SET LANGUAGE 1ENG 2FRA 3ESP shows in the display.
3. Use the touch tone pad on the handset to select 1ENG, 2FRA, 3ESP, or use the CALLER ID-VOLUME ( 6 or 5) button to scroll to the desired language. English is the default setting.
4. Press the mute/menu OK button to save your selection. You will hear a confirmation tone and the selected language shows in the display.
Apr 29, 2009 | Uniden Cordless Phone
PHILIPS ID937 phone.
Fixed:) Ok so I bought 2 extension handsets from different people off of Ebay, both new. First one wouldnt register or would say incorrect pin (0000). So I tried the second one, same thing. Here is what I did: When attempting registering, make sure the handset is physically on top of the main base station, IE charging. Start the registration process on the handset and press-hold (dont let go) the locate handset button instead of press and hold for 3 seconds (like the manual says to). If that didnt work, I removed the batteries and tried pressing and holding the same button for 3 seconds, then release. Wait 10 seconds, then press and hold for 3 seconds. Repeat. If the handset timed out and went back to the main unregistered instruction screen. I took the batteries out and tried again. It was a bit of trial and error but each cycle I removed the batteries to reset the handset. First extension handset took 20 minutes of head scratching, the second 2 minutes. Hope this helps someone. The build and sound quality on these units are great, the tech support....not so much.
Apr 02, 2008 | Uniden Cordless Phone
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
