Switch on from Mains blue light comes on for seconds.Press the Channel button as soon as the blue light appears and it will come on. BUT will not switch OFF.
  • 3,828 Answers
My blue light stays on when the tv is on
always has
tv works great
standby light is red
Posted on Apr 28, 2017
Tip
Chevrolet service light 1991-01
Camaro
1998-01
To reset the "OIL CHANGE" light, press and hold the "TRIP/OIL RESET" button on the instrument panel for 12 seconds. When the light flashes and then goes out, the system is reset.
Corvette
1997-01
To reset the monitor after an oil change, turn the ignition on. Press the "TRIP" button so that the "OIL LIFE" percentage is displayed. Press "RESET" and hold it for two seconds. The word "RESET" should appear on the monitor, then "OIL LIFE 90%".
Impala,
Monte Carlo
2000-01
Turn the ignition to ON without starting the engine. Fully press and release the accelerator three times within five seconds. If the CHG OIL SOON lights two times, the system is resetting. Turn the key to OFF, then start the vehicle. If the CHG OIL SOON light comes back on, the system has not been reset, repeat the procedure. Follow this procedure to reset the GM Oil Life System using the DE 100 Series Radio. Turn the ignition to ACC or ON and the radio off. Press and hold the DISP button on the radio for at least five seconds until SETTINGS is displayed. Press the SEEK up or down arrow to scroll through the main menu. Scroll until OIL LIFE appears on the display. Press the PREV or NEXT button to enter the submenu. RESET will be displayed. Press the DISP button to reset. A chime will be heard to verify the new setting and DONE will be displayed for one second. Once the message has been reset, scroll until EXIT appears on the display. Press the DISP button to exit programming. A chime will be heard to exit programming. A chime will be heard to verify the exit.
Impala,
Caprice
1994
To reset the "CHANGE OIL" light, turn the ignition switch to the run position with the engine off. Access the reset button on the end of the instrument panel by the fuse block. Press the switch and hold it for at least 5 seconds.
Lumina,
Monte Carlo,
Impala,
Caprice
1996-00,
1996-99,
1995-96,
1995-96
To reset "CHANGE OIL" light, turn the ignition switch to the run position without starting the engine. Fully depress and release the accelerator pedal 3 times within 5 seconds. The light will flash and go out.
Corvette
1990-96
After an oil change, or when "CHANGE OIL" appears on the Trip Monitor, with the ignition on and engine off, press the "ENG MET" button (located on trip monitor) once. Press the "ENG MET" button again within 5 seconds. Within 5 seconds, press and hold the "RANGE" button (1990-1994) or "GAUGES" button (1995). The light will flash. When it stops flashing and goes out, the system is reset.
Chevrolet Suburban,
GMC Yukon XL,
Chevrolet Silverado,
GMC Trucks Sierra
2000-01,
1999-00
Turn the ignition key to the RUN position. Fully push and release the accelerator pedal 3 times within 5 seconds. If the CHANGE OIL SOON light flashes 2 times, the system is reset. However, if the light comes on and stays on for 5 seconds, the system did not reset. Repeat the procedure if the system does not reset.
Silverado, Sierra Trucks
1991-93
To reset the "CHANGE ENGINE OIL" message, turn the ignition key to the run position. Press and release the accelerator pedal three times within 5 seconds. If the light flashes for 5 seconds, the system is reset. Repeat procedure as needed.
on Dec 07, 2009 | Chevrolet Camaro Cars & Trucks
Tip
Cadillac service light 1989-01
Eldorado
2000-01
Turn the ignition to ON. Press the TRIP button on the driver information center (DIC) switch to view various menu choices and stop on OIL LIFE REMAINING. A message will display the percentage of oil life remaining. Press and hold the RESET button on the DIC switch for at least 2 seconds. A message will display the percentage of oil life remaining as 99 percent. The engine oil life monitor is now reset. Turn the ignition OFF.
DeVille,
Eldorado
1999
To reset the service Oil Life Indicator, display the
"OIL LIFE LEFT" message by pressing the "INFORMATION SKIP" (skip info) button. Press and hold the "RESET NO" (no info reset) button until "100% OIL LIFE" is displayed.
Deville,
Seville
2000-01
Turn the ignition to ON, Press the INFO button on the driver information center (DIC) to display ENGINE OIL LIFE. Press and hold the INFO RESET button on the DIC until the display reads 100% ENGINE OIL LIFE. The engine oil life index is now reset. Turn the ignition OFF.
Deville,
Seville,
Eldorado
1997-98
Display "ENGINE OIL LIFE" by pressing the "INFO" button. Press and hold the "INFO RESET" button until the message shows 100.
All Models
except
Fleetwood
1994-97
Press the "INFORMATION" button until "OIL LIFE LEFT" is displayed. Press the "RESET" button until "100" or "0.0 OIL LIFE LEFT" is displayed.
Fleetwood
1994-96
All Models,
Seville,
Eldorado
1993,
1994-95,
1994-95
The automatic transaxle message can be reset through the following procedure. If "CHANGE TRANSAXLE FLUID" appears on the Information Center, press and hold the "OFF" and "REAR DEFROST" buttons until "TRANS FLUID RESET" appears.
DeVille,
Fleetwood
1991-93
When "CHANGE OIL SOON" light is illuminated, press and hold the "RESET" and "RANGE" buttons on the Fuel Data Center for 5 to 60 seconds. When the buttons are released, the light will flash four times if it has been reset. If the light comes back on for more than 5 seconds, repeat the procedure.
Allante
1989-93
When "CHANGE OIL SOON" appears on the Driver Information Center, press the "RANGE" button until "OIL LIFE INDEX" shows on display. Then press and hold "AVG SPEED" and "RESET" (or "RANGE" on late models) buttons until display shows "100".
Seville,
Eldorado
1992-93
Press "INFORMATION" button on the Driver Information Center until "OIL LIFE INDEX" is displayed. Press "STORE/RECALL" until "OIL LIFE INDEX" resets to 100.
Seville,
Eldorado
1989-91
When "CHANGE OIL SOON" or "CHANGE ENGINE OIL SOON" appears on the Driver Information Center, press "ENG-DATA" button until the "OIL LIFE INDEX" appears. Then press the "ENG-DATA" button and the "RANGE" buttons at the same time until 100 displays (about 5 seconds).
on Dec 07, 2009 | Cadillac Eldorado Cars & Trucks
Accidently changed something and not able to get antenna tv now - do not ahve cable here at work
I am unable to see at a glance how to correct this but it is between its menu, channel and volume buttons to alter the settings it may be worth to run through the re-tune sequence below?
To preset a channel or to change a preset channel, follow the procedure below.
1) Press the POWER button to turn on the TV.
2) Press the MENU button so that the menu display appears
on the TV screen.
3) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
Then, press the VOL(ume) ? button.
4) Press the CH(annel) ? or ? button to point to "AUTO PRESET CH".
The tuner scans and memorizes all active channels in your area.
? The TV distinguishes between standard TV channels and cable channels.
? When AUTO PRESET CH action is completed, the lowest memorized channel reappears on the
screen.
? When you press the CH(annel) ? or ? button after selecting "AUTO PRESET CH", the tuner
will stop at the memorized channels only.
? The TV may recognize TV channels to be CATV channels by the receiving conditions. In this
case, try AUTO PRESET CH action again in the fine receiving conditions.
? When AUTO PRESET CH is activated where there is no TV signal input,"NO TV SIGNALS"
will appear on the display after the completion of channel scanning.
[ADD/DELETE FUNCTION]
1) Press the MENU button so that the menu display appears on the TV screen.
2) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
3) Press the VOL(ume) ? button so that "ADD/DELETE" is selected.
4) Use the CH(annel) ? or ? button to select the
channel you wish to put into memory or to erase from memory.
Note: The menu will disappear in about 10 seconds.
Perform "ADD/DELETE" function while this display appears on the
screen.
? Press the VOL(ume) ? or ? button to light up the channel number
in LIGHT BLUE if you wish to add the channel into memory.
in LIGHT RED if you wish to erase the channel from memory.
5) Press the MENU button to exit the menu.
Hope this helps.
Jun 29, 2015 | Durabrand DWT1304 13" TV
Sky box green light on permanent
Sounds as if the software is corrupt. Try a forced software update...
1) Switch the digibox off at the mains power, so no lights are displayed on the unit
2) Press and hold the BACK UP button on the digibox (not the remote control)
3) Whilst holding, switch the digibox back on at the mains power so the red standby light is displayed
4) Wait approximate. 10-20 seconds for the remaining 3 lights to display, at which point you can release the BACK UP button
5) Allow the digibox to download the latest software, which can take 10 minutes before returning to standby
6) Leave 60 seconds then power up as usual
A software update/refresh will leave your recordings intact. You won't lose anything.
If this doesn't solve your problem, then the next step is more drastic. It's a Full System Reset and Planner Rebuild. Be advised though: Your recordings are at risk!
1) Switch your digibox on
2) In sequence, press on your remote 'SERVICES > 4 > 0 > 1 > SELECT' (this will access the hidden menu)
3) Select the relevant option (usually the bottom two) and follow the on-screen prompts (note that it's likely your digibox will reboot between processes)
Applies to Sky+HD Digiboxes only, running latest EPG
1) Press Services on your remote control. 'Options' in the Top Menu will be highlighted in orange.
2) Press the Right arrow once to highlight 'Settings' in the Top Menu.
3) Now press the Down arrow once to highlight the 'settings' tab in the Middle Menu.
4) Press 0, 0,1, Select on your remote in quick succession. The 'Setup' tab will then be highlighted within a hidden menu.
5) Select the relevant option and follow the on-screen prompts (note that its likely your digibox will reboot between processes)
Sky Digibox Planner Rebuild / Full System Reset (if stuck in standby)
Applies to Sky+ and Sky+HD Digiboxes only
Same as above, but applies if your digibox is stuck in standby and you cannot get to the hidden menu:
2) Press and hold the 'right and left arrow' buttons on the digibox (not the remote control)
4) Wait approximate. 30 seconds for the blue Sky+ ring of lights to display, at which point you can release the 'right and left arrow' buttons
5) Press 'SELECT' on the digibox (not the remote control)
6) Now the system will format the hard drive, the blue Sky+ ring of lights should spin backwards
7) Allow the system to format, which can take 10 minutes before returning to standby
8) Try to power up!
Sep 02, 2014 | Televison & Video
No sound on iplayer on tvonics z500hd
Workaround procedure to get this to work 1. Go to BBC1. 2. Go to the Guide and select channel 200 - BBC Red Button. Press OK. 3. Exit the Guide and wait. You should see a notice about the BBC Red Button Service. Wait a few seconds. 4. Press the RED button - the display switches to BBC1 and shows the standard (Text) Red Button Index. 5. Press the BLUE button to close the Index. The display shows the BBC1 video and sound. 6. Press the RED button to get into the Red Button Menu. 7. Wait a few seconds and then select the BBC iPlayer. I gained access to the iPlayer once this way yesterday and twice so far today but when I went straight to the iPlayer from BBC1 I lost the sound. I've just shutdown and then re-started the HD500 and successfully accessed the iPlayer using the above method. Note, that if it doesn't work then just switch your box into standby, wait 15 minutes or until the Hard Disk stops and then you can switch it on again. No mains power-off or reset is required.
Mar 29, 2013 | TVonics Televison & Video
Turn on tv blue light comes on then when i press a button to put a channel on blue light re appears
What you see is a protection mode. Change input device to some other like a DVD player. Switch off TV, switch off power, remove plug and wait for 48 hours and retry. If problem persists, call in a qualified service technician.
Aug 03, 2012 | Televison & Video
Where is the auto convergence button
Hello
From it menu option, suf through and come to automatic convergence display option and press Ok button on the remote control.
The List & Labels part of the setup lets you edit your channel list and choose or create a
personal six-character label for each channel.
Note: Changing List and Labels can be time consuming. You can change these at a later time by accessing the
Setup menu.
1. Press the left or right arrow to scroll through the available channels and choose the
channel you want to edit.
2. Press the down arrow to highlight the In channel list option. Press the left or right arrow
button to add (the box is checked) or remove (the box is unchecked) the channel from the
list.
3. Press the down arrow to highlight the Channel label option. Press the left or right arrow
button to scroll through the available list of 25 most common labels. The last option in
the list allows you to create your own six-character label for the channel (the first letter of
the label is highlighted).
4. Press the 1 or 2 number button to change the first letter of the label.
5. Press the right arrow to highlight the second letter, then press the 1 or 2 number button
to change the second letter, etc...
6. When you are finished creating your label, press OK. For model D34W20, your TV tunes to
the last channel available in your channel list. For models D40W20 and D52W20 only, the
Auto Convergence menu appears next.
Auto Convergence (for models D40W20 and D52W20 only)
Your TV's picture tubes might have been disturbed during delivery or after you moved the TV,
causing the color in your TV to be out of alignment. The colors adjust by starting auto
convergence.
1. Press OK to begin auto convergence.
2. When the auto convergence is complete, the Red center convergence menu appears. The
cross in the middle of the screen should be yellow. If it is not, use the arrow buttons to
move the red cross to overlap the green cross. Press OK when adjustments are complete.
3. The Blue center convergence menu appears with a cyan cross in the middle of the screen. If
it is not, use the arrow buttons to move the blue cross to overlap the green cross. Press OK
(the TV tunes to the last available channel in the channel list).
Ok
Mar 16, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
CHANNEL INDICATOR WON'T CLEAR
This is a setting in the menu set-up somewhere or simply press the display button on the remote control unit.
Jan 21, 2008 | Televison & Video
Blueish screen
Follow these steps to solve the problem... Make sure that the moniter power button is off. Unplug monitor from mains ( the auto exit button should flash red after about five seconds and you hear a popping sound.) plug monitor back in mains. hold down + and - on the monitor now hold down power button on monitor let go of power when power button when the green led lights up let go of + and - buttons wait a few seconds and press menu, a hidden menu will appear in the top right use the + and - buttons to move the highlighted option over the auto colour option in the menu push the menu button.
Jun 08, 2007 | iiyama ProLite E434S 17" LCD Monitor
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
