Question about Lands Phones
How can i make a conference call with model c61 and addittonal handset
How to change silent mode from on to off?
you have to go to settings., and from there, profiles section to change the mode silent to general model.
Nov 18, 2014 | Uniden DECT1560 DECT 6.0 Single-Line...
The KX-TGA401 is the handset. The greeting is controlled by the answering machine. What model answering machine do you have on your phone line?
Oct 03, 2013 | Panasonic KXTGA401B KX-TGA401B KX TGA401B...
How can i do two way on panasonic 5.8ghz
These directions are for the KX-TG5451, KX-TG5452 and KX-TG5453.
If you want to use the intercom feature, you need to know the handset number for the unit you want to contact. The base is zero. The handset number is set when you register the handsets. So to communicate with the base, press Intercom on the handset followed 0. The base will ring until someone presses Call to answer it (or one minute whichever comes first). (Alternatively, you can use the up/down arrows to select H1, H2, H3 or Base. Then press the right arrow key.)
To communicate between two handsets, press Intercom and then 2 (from handset 1 or 3 to connect with handset 2). Again the handset will ring for one minute or until the person with handset 2 answers. (To answer, they can press the phone, speaker or intercom button.)
If someone at the base wants to use the intercom, they need to press Select until the appropriate handset number is displayed. Then press Call.
To transfer a call, press Intercom and then select the desired handset. When the intercom message is picked up, indicate that a call is being transferred and press Off at the handset or base that initially answered the call.
For a conference call, initiate the call then press Intercom and select the handset to join the conversation. Once that person picks up, then press Conf. (I believe that Conf is a softkey so check the display.) This is only possible with the handset. (Another handset can join the conference by pressing the phone or speaker button on that unit.)
The manual for the KXTG5453 is available here: .
If you have a different model of the Panasonic 5.8 GHz phone, please add a comment with the model number and I'll try to give the directions for that unit.
I hope this helps.
Aug 11, 2011 | Panasonic KX-TG5453PK 5.8 GHz DSS Cordless...
Cannot make conference call does my phone has that facility model #CS6229-2
The VTech CS6229-2 - cordless phone has a two handset systems provide the convenience of operating two handsets using only one phone jack and one base station. The second handset simply needs an electrical outlet to plug into. These systems also allow you to transfer calls, conference an outside call or use the intercom feature between handsets.
Here's an online instruction manual for your guide:
Jun 28, 2011 | Vtech i5866 Cordless Phone
How to make conference call
To make a conference call, simply make your first call. Then put the first call on hold and dial the next number. To conference, scroll through the handset menu and select the conference feature. Now your calls are connected. To invite another person, follow the same steps again.
Feb 19, 2010 | Nokia E63 Cell Phone
Conference calls
this will be threw your service provider to set up more than a 3 way calling plan
3 way should be standard service with only 3 people at time anything extra needed the service provider can set up the extra 3 waying +
on the phone handset if your just looking for in home conference calling to others just click the conference button find the handset you want to talk too or all the handsets this is conference calling
Jun 01, 2008 | Uniden Cordless Phone
"Line on Conference" hand set inoperable
Maby i can find us manaul should tell us what to do for this model what model do u have thx nick.
Feb 04, 2008 | Uniden Cordless Phone
RE TRU 9480-4 I have this system and it quit working
Sounds like it had not released from a conference call. Try pressing to off or hang-up buttom on these sets.
If this does not work try removing the batteries from those sets for atleast 5 minutes and then replace the batteries.
If you have more than one handset, up to four people can participate in a conference call. A four-way conference call consists of an outside line, two handsets, and the base speakerphone. You can easily join a call already in progress.
Press [/flash] or [] on the handset or [] on the base to join the call.
To hang up, return the handset to the cradle or press [] on the handset or [] on the base. The other party will still be connected to the call.
) 2) • • ) 2)
Dec 22, 2007 | Uniden TRU9480 Cordless Telephone
Uniden DECT 6.0 cordless phones
Here are some steps that should help. I don't think that you can Conference call You can hold a 3-way conversation (conference call) between your handset, an external caller and another internal handset user. During an external call: 1 Press . The external caller is put ?on-hold?. 2 Press or to select name, number or the handset you want to have a conference call with and press or key. The called handset will ring. 3 When the called handset answers, press to start your conference call. 4 Any handset can press at any time to leave the conference call. It looks like you can use the multiple system sets together, but the system is not designed to do what you are asking for. Please repost with any other comments or questions. Please rate this solution through fix-it. Thank you.
Jun 30, 2007 | Uniden DECT1080-2 Phone
Lands Phones Logo
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
