Question about Home Security
How to install wireless cctv camera - Home Security
I have a wireless surveillance system, 4 chanel. came with 2 cameras. have purchased additional camera. How do I get the system to accept camera?
I am going to write a short discussion because I feel this subject is best handled by a person that knows what they are doing. There are plenty of Youtube videos that shows you how to install a CCTV system. As you didn't mention what type of CCTV camera it is, can this topic become very lengthy.
Please look at this tutorial on youtube,
The old systems is not difficult to do it yourself if your technical minded, although the newer systems will require some IT background. I recommend a certified installer to assist you, you can damage the camera if you don't know what your are doing.
Get the correct cabling and connectors.
The easiest are the pre-crimped cabling for DIY and it is plug and play. No setup is usually required for the CCTV recorder to work unless the recording on the CCTV was disabled. Any other setup will require special tools.
You get 2 kinds to wired CCTV camera systems.
The old tech is analogue with a thick data cable and set of wire for power.
The professional installed cabling will require a technical person to crimp the CCTV cable with a special BNC crimping tool. The
The old systems needs to have
The newer systems uses LAN cables.
The newer systems requires an IT/CCTV tech person to set it up.
Sep 19, 2017 | Came Home Security
Outdoor Digital Wireless 2 CCTV camera System 7" LCD monitor DVR Record to SD TF but recorded playback poor what can I do please I am 81
Try recording in a higher quality than standard and see 2hatcthe results are.some of those are low resolution cameras and you won't get a wonderful image out of them.
Jun 28, 2015 | OUTDOOR Home Security
No PTZ control when moniot is connected to CCTV camera
PTZ CCTV camera enabling wide area coverage and gives details of area in night vision also. Your PTZ camera not monitoring well . Have you checked the setup you have installed is correct?
You can find setup instructions for configuring the PTZ camera from the Expert Security System provider.
Aug 08, 2013 | Dome 4 CCD CCTV Camera Surveillance...
What Are The Benefits Of A Wireless Cctv Camera?
The use of a wireless CCTV camera has its specific benefits. One is that the wireless CCTV systems can be used anywhere since there is no cabling required. They are also easy to install and are flexible. In addition, owing to the fact that there are no cables and that they are easy to install, wireless cameras also feature lower cost.
Apr 24, 2013 | Home Security
Rear view camera instalation
Mount the camera on the back and the monitor in the front. Run the necessary wires and connect it to the power supply.
Feb 24, 2013 | Rear View Safety Rear View Night Vision...
We are currently installing wireless cctv and using alvarion access.We are encountering connection lost and sometimes got still pictures.What causes this problem? Thanks,
is it a PTZ camera or Fix? how many cameras? You need to look at the type of capacity (MBPS) & (PPS) , minimum latency and Jitter your camera manufacturre is recommending. Not all wireless devices offer low latency, Low Jitter, High MBPS and PPS needed for higher end cameras.
Feb 22, 2011 | Alvarion Computers & Internet
How to save file at cctv camera
First of all you install camera software (net sink) it’s free on net, in this installation you give destination path where you want to save the data.
And after this installation you can able to save file at CCTV camera
Thanks& Regard
Abhay Singh
Nov 19, 2009 | Computers & Internet
Installed wireless cctv in horse stables 4 mt x 6mt dont seem to
the gain is turned up to much this is washing out the camera
another possible cause is the auto iris lens is either not set properly or stuck open.
if you are using a "bullet" camera that may not be adjustable without opening it up and removing the camera from the aluminum housing.
its usually a tiny screw that you turn up or down. could also be that the CCD or cmos image chip is dying
Mar 11, 2009 | Ktl Cctv CFB2056IR Black and White...
My PC Not Work With my CCTV Systems
what kind of error display
which card use 4 channel , 8 ,16
Feb 26, 2008 | Intel Motherboard
Home Security Logo
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
