Question about Seiki Televison & Video
So my seiki se50fy28 so it will turn on but it has no picture an it makes a popping/clicking noise that comes from the back what I'm asking is how to fix this and what parts are needed please?
STEVIE_N_24
  • 147 Answers
SOURCE: popping noise during turn
Bad CV Half shaft on right hand side.Replace axle shaft assembly to cure problem.
Posted on Mar 29, 2009
  • 37 Answers
SOURCE: clicking/popping noise from rear a/c-heater unit
It's the temp blend door actuator.
Posted on Apr 14, 2009
  • 205 Answers
SOURCE: Popping Noise coming from wheel well.
it sounds like a loose or faulty strut
Posted on Oct 17, 2009
  • 4134 Answers
SOURCE: My son was playing his wii on our 40" Seiki SE421TT when he heard a popping noise which blanked the screen. There is no picture and no sound although the blue power light works. Do you have any sugges
A popping noise is generally consistent with a capacitor exploding. This is common on power supplies since manufacturers tend to use the lowest value, lowest quality capacitors they can find on these units. A blown capacitor is easy to spot, and you may see others that have swelled and are ready to burst as well. Replacement of these with better quality capacitors often restores operation. Some skill at soldering is required. If you are not familiar with electronic repair procedures, it is advisable to get someone who know how to do it for you.
Posted on Dec 25, 2014
Testimonial: "Would replacing the Power Supply unit suffice? Would you say the T-Con Board and Main Board were not affected?"
  • 6702 Answers
SOURCE: Honda wont start, makes clicking noise,but radio and lights come on. What part do i need to fix this?
check battery, check fuses, check cabling, also where the cabling is fastened. Check if all connections are good. just to name a few of the thousands possibilities.
Posted on Mar 16, 2015
Seiki tv SE50fy28, stand bye light is on until powwer botton pushed then i get only s black screen
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Aug 31, 2016 | Seiki Televison & Video
SEIKI SE50FY28 !! Tv powers on to a blue light but has no picture !!
I would try the TV inputs. Tv/Video or the Source button on your tv remote. Select each input to see if picture comes on. If you have checked all cables and Inputs, I would check the wire from the TV to the cable box.
Jul 30, 2016 | Seiki Televison & Video
Hi i have a seiki SE50FY28 led tv that has no sound or picture. i did the flashlight test and i do see the menu appear. what part do i need to replace??
sounds like a backlight failure (fluorescent tube that illuminates the display element)
can be a little tricky to replace as requires significant disassembly
Jan 28, 2016 | Seiki Televison & Video
How to reset Seki tv when it goes off and will not come back on
Seiki hard reset tv factory settings Flat Panel Televisions ...
www.fixya.com > ... > Flat Panel Televisions
Seiki flat panel televisions hard reset tv factory settings related questions and answers. Ask your Seiki questions. Get free help from flat panel television experts.
How to reset a seiki hd tv that keep reading no signal? - The ...
www.askmefast.com > Family & Relationships > Singles & Dating > Signal
To reset your seiki hd tv you just need to press on the menu: 0000 The TV will ....Getting to factory settings seiki tv ..... "How to reset seiki tv that reads no signal?
FAQ's ' seiki
Dec 19, 2015 | Seiki Televison & Video
I have TV Seiki model SE50FY28 when we turn on the TV, it works for a minute then the screen goes black, we still have audio and the flashlight test shows a faint image, what may the problem be?
Probably the back light inverter is faulty . Before going to buy a new inverter board tey to check the power supply. Which the bellow added video to know how to check a power supply board. You have to check the 24V power sto the inverter board from the power supply. if its not there then the problem is with power board. If its ok then you have to go for a new inverter board. Also try to replace the electrolytic capacitors in the power supply board. some times bad electrolytic capacitors can lead to back light failure.
www.electro-medical.blogspot.com
Testing LCD TV Power Supply BoardsSTEP BY STEP
Oct 31, 2015 | Seiki Televison & Video
My pros can ps56670 makes a popping noise when I turn it on but won't come on no picture
I just answered this for someone else; this sounds like a power control board problem. Basically something has short circuited and if you're hearing popping from the back and not the speakers it a power problem. If you're hearing it from the speakers but no picture then you need to replace your control board.
Jun 07, 2015 | Televison & Video
My son was playing his wii on our 40" Seiki SE421TT when he heard a popping noise which blanked the screen. There is no picture and no sound although the blue power light works. Do you have any suggestions...
Dec 25, 2014 | Seiki Televison & Video
Samsung HLS5086WX/XAA made popping noise and shut off, then made whirring noise.
When my TV did this in the past it ended up being the color wheel. I had someone replace it and it worked fine. I asked it if had to be calibrated after it is installed and he said no. Also make sure the door switch is pushed down when you install the back bulb door. Sometimes this switch can go bad as well.
Jan 10, 2013 | Samsung HLS5086WX/XAA
Panasonic PT-61LCX65 61" Television Set Popped, Now Left with a Cicking Sound
Your problem more than likely lies in your lamp. The whirring noise you hear is the ballast trying to fire up the bad lamp. The lamp part # for your set is TY-LA1000 and can be purchased online at vance baldwin. This is something you can easily replace yourself and your owners manual will give you instructions. Hope this helps
Mar 31, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Televison & Video Logo
23 people viewed this question
Top Seiki Televison & Video Experts
Andrew Taylor
Andrew Taylor
shaun taylor
Are you a Seiki Televison and Video Expert? Answer questions, earn points and help others
