Screen overlay how to turn off - Computers & Internet
I am unable to turn off screen overlay. I tried doing so in app settings by turning off all permission. It is still on, how do I remove it. ZTE 798BLi
Hope this help.
1. From your home page go to Main Settings by pulling down the Notification Bar and clicking on the Settings icon at the top right of the screen. (it's gear shaped)
2. Scroll down the Settings menu, and click on Applications under the Phone section about two thirds down the page.
3. At the top of this new menu click on "Applications Manager".
4. In the top right corner of the Applications Manager menu click on "More"
5. Now a click on "Draw over Other Applications"
6. Scroll down this menu and find the offending application, in this example "Facebook"
7. Click on the button to the right of your offending application to deselect it.
8. Close out of the Settings menus.
NOTE: Alternately, deselect all the applications under step 8 except those you know pop up over other applications such as messaging, for example.
Feb 04, 2018 | ZTE Cell Phones
How do I turn off screen overlay
What do you mean by screen overlay?
Nov 13, 2017 | Televison & Video
What does screen overlay detected mean with android phone?
Step one: "Screen overlay detected" fix
Find you what apps have permission to draw over the screen. On a non-Samsung smartphone, follow these steps:
  • Open the Settings
  • Tap the magnifying glass at the top right
  • Enter the search term "draw"
  • Tap Draw over other apps
  • Alternative route: Apps> [gear icon]> Draw over other apps
For Samsung users:
  • Open the Settings
  • Then Applications > Application manager
  • Press on More > Apps that can appear on top
Step two
You will find yourself in front of a list of apps that have permission to use floating buttons or other screen overlays. Now you need to identify the problem app and temporarily deny it permission to draw over the screen. Here is are some pointers on how to identify the app that's causing trouble:
  • Do you see an app bubble on your screen? If do, this app is almost certainly the cause. Either you hide the app bubble or disable the app in the list
  • Do you have an app installed that changes the colors on the display or adjusts the brightness?
  • Reportedly, Clean Master can be a trouble maker. If you see Clean Master in the list, disable it
  • If there's no obvious cause, disable everything
Step three
Now you can try launching the app again, and it should request permissions without the "Display overlay detected" error getting in the way.
For Samsung users: We have also received a report that suggests the one-handed keyboard setting could be the root cause. Deactivate it by going to Settings> Advanced features > One-handed operation.
Step four: reactivate screen overlays
In order for the app(s) that you have disabled in step two to work again, you need to re-enable its overlay permissions. If you turned off all apps, it might be worth considering only reactivating those apps that you actually use.
This is a rather inelegant workaround, but it's the best we have until Google makes the necessary changes to prevent app overlays from interfering with permission dialogues.
Has this guide helped? If you are still experiencing the error after following our guide, leave a comment, so we can try and address the problem.
Oct 20, 2016 | Android Cell Phones
Oct 20, 2016 | Office Equipment & Supplies
Won't open the overlay screen
You must have a heading sensor input for radar/chart overlay. (i.e. PG500)
Jun 19, 2010 | Furuno NavNet vx2 1934CBB/NT GPS Receiver
Hello- My 332c will not show speed. It worked before.The spinner wheel is not damaged.Speed just flashes 0.00 mph Thanks, Jeff
Try setting up the speed in the overlay data menu again:
1. Press MENU, arrow down to OVERLAY DATA and press ENT
2. Highlight the option for speed (WATER SPEED or GROUND SPEED) and press ENT
3. Highlight the REMOVE button and press ENT
4. Highlight (PRESS ENT TO ADD) and press ENT
5. Arrow down to SONAR DATA and press ENT
6. Arrow down to WATER SPEED and press ENT, a check will be displayed in the box
7. Press EXIT twice
If the speed is still flashing, the data is still invalid. Try resetting the unit completely:
1. Turn unit off
2. Press and hold the PAGES and POWER key until the "DO NOT RELY..." alarm appears
3. Set up the overlay data for speed again: 1. Press MENU, arrow down to OVERLAY DATA and press ENT; 2. Highlight (PRESS ENT TO ADD) and press ENT; 3. Arrow down to SONAR DATA and press ENT; 4. Arrow down to WATER SPEED and press ENT, a check will be displayed in the box; 5. Press EXIT twice
If the speed is still flashing, good chance the speed sensor is bad even though the wheel still spins. Install the latest LMS-332 updates from and set up the overlay data again.
If it turns out that the speed sensor is bad, just use speed from the GPS. This can be set up from the overlay data menu as GROUND SPEED.
(note: the overlay data must be set up for each page individually. So if you set up speed to be displayed on the map screen, it will not also be set up on the sonar page)
Jul 12, 2009 | Lowrance LMS-332C GPS Receiver
Screen turning pink
If the pink overlay goes away gradually, you could have weak picture tubes (CRT's) If the color jumps in after warming up, it could be a bad solder connection. If you haven't had a good picture to watch for a long time, I would be tempted to put the money towards a new HDTV set as those older Mitsubishi Rear Projection TV's had a Lot of bad solder connections in the past, and by fixing one problem another could crop up in the near future.
Apr 12, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
