Question about Juki Sewing Machines
My juki g210 is loud when I sew. its 2 months old. I cleaned under plate and bobbin, put in a new needle, and its still loud. what else should I try
  • Juki Master
  • 3,828 Answers
Put some felt or rubber mat under the machine
online reviews dont say they are noisy during operation
While sewing on this machine, I heard very little in terms of machine noise. The motor is almost whisper quiet. There is no vibration.
My juki g210 is loud when I sew.  its 2 months old - index-n3tzgjtvihckmmjcgghducoc-3-0_1.jpg
Posted on Apr 28, 2017
My Juki HZL F300 bobbin case is making a terrible noise. It sounds like the bobbin is going to spin right out of it. This noise is SO loud! Do I need to oil anything? It is not even a year old.
Try installing a brand new needle. Sometimes a bent or dull needle will cause lots of racket.
You should consult your owner's manual for maintenance--cleaning and oiling instructions. Most sewing machines do require oil--some more frequently than others. Most machines also need frequent oiling in the bobbin/hook area. Be sure to use only good quality sewing machine oil for your machine--NO 3-in-1, WD-40, cooking oil, or old brown stinky oil.
If it continues to make the noise, you should probably have it serviced. Since it is less than a year old, it might still be covered under warranty, so don't delay.
May 31, 2016 | Juki Sewing Machines
Baby lock pro BL40, bobbin thread tangles, tried new bobbin, cleaned under plate, needle is straight, what to do?
make sure the bobbin is turned the correct way in the bobbin case
make sure the top thread has not come off the thread take up lever
could also be a timing problem
Jul 28, 2014 | Sewing Machines
I just brought home a Juki 8700. The needle went down and now I can't get it basck up. There is thread stuck in the bobbin. How do I get the bobbin casing off
Cut the thread above the needle eye and rock the handwheel back and forth sharply to cut the thread with the sewing hook. If that doesn't work pretty promptly, undo the needle clamp and turn the handwheel, which should raise the needle bar. Then get into the bobbin case area and try to remove the bobbin case, cutting any threads you can. Keep rocking the handwheel and trying to pull out the needle (pliers help!), and eventually everything will loosen up.
Next, clean and lubricate the area under the needle plate and the shuttle, and reassemble. Put in a brand new needle, right way around and fully up in the machine. Load the bobbin case with a well-wound bobbin, and rethread the top of the machine and you should be good to go.
Jan 28, 2014 | Juki DDL-8700
Thread presser foot juki serger
try a new needle
rethread the machine top and bobbin
make sure the bobbin is not warped or damaged
make sure the bobbin is inserted in to bobbin case correctly
clean under the needle plate and in the bobbin area for lint
if the problem still happens,, then it would be a good idea to have the machine checked for a timing problem
Sep 28, 2013 | Sewing Machines
Juki DDL 227 top needle keeps breaking
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Oct 08, 2012 | Juki Sewing Machines
Needle won't pick up bobbin thread tried cleaning new needle new bobbin thread upper thread..
did you clean the bottom bobbin area thoroughly? Remove the cover plate and bobbin reel, look for debris. Any left over cotton will cause problems, after you clean it spray some wd-40 on all moving parts.
Thanks
Adam
please leave me some feedback
Feb 18, 2011 | Juki TL-98Q
I have a Juki DU 141NH industrial sewing machine. I just had it serviced. I had to put a new bobbin in and now the needle is not catching my bobbin thread. Please help!
Be sure you have the proper needle - it is longer than standard needles, plus be sure that you put the needle in from left to right - not...front to back.
Oct 07, 2010 | Juki DDL-8300
Janome Memory Craft 9500 Troubleshooting
Have you tried a new needle?
If re-threading, changing the brand of thread, etc. does not work, then it's likely your machine is out of time. Search for sewing machine timing or take it for service.
May 24, 2017 | Janome Memory Craft 9500 Computerized...
Loud noise while sewing
Could you let us know which machine this is.....
In the meantime....the damaged bobbin is not good, replace it/them........if you have a top loading drop-in bobbin, check for needle damage on the plastic bobbin case (remove needleplate to access).
If there is evidence of needle strikes, if mild, you could try to use very fine wet & dry emery paper to smooth, if severe, buy a new bobbin case.
There may be a load of lint under and around the bobbin case too, remove and clean up this area. If very dirty, use methylated spitit on cloth or cottonbud (QTip) to remove grime (don't soak)
Bargainbox
Jan 27, 2008 | Sewing Machines
Sewing Machines Logo
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
