Question about Dryers
Down lights 6998 requires 200mm clearance and non combust.lining I have only 150mm. Alternative?
Steel plate or a modern equiv.to asbestos board above the ceiling? Faithfully Ed Hamish Irving,The Barn NE44 6EG
4 Suggested Answers
  • 4348 Answers
SOURCE: Replacing rear ceiling AC blower motor.
Usually the fan is located at the left rear of the inside of the vehicle.Then ducts run to the roof...
Posted on Jun 28, 2010
  • 3238 Answers
SOURCE: What is the minimum clearance required from the
iwould google the make and model etc and down load a manual from there site to be sure of the clearance
Posted on Aug 11, 2010
  • 10 Answers
SOURCE: I want to paint epoxy
You can eliminate streaks by bead blasting the substrate to create a footing for the paint to ad hear to. Sanding will create scratches.
Posted on Jun 17, 2011
I need a clutch disc and lift cylinder for a gray market Sato ST 2000. What will fit or where can I find parts for this tractor please. Thanks
clutch disc or clutch plates are determined by several things
over haul diameter
spline size
no of splines
solid center;
spring loaded center light 4 spring of light spring material
spring loaded center heavy---6 or 8 springs of thick spring material
full face linings --asbestos or like material
button linings --normal a brass compound
So now knowing all of this all you have top do is take the existing plate along to a specialist brake and clutch shop and they will be able to match up a replacement plate as equipment manufacturers use generic clutches suitable to their engineering requirements
best advice is to always replace the clutch as an assembly because there is high heat generated in a clutch operation and that affects the tension quality of the spring steel used in the springs of the pressure plate
as for a lift cylinder , any professional hydraulic engineering shop will be able to repair/replace or manufacture what you want
again your cylinder as a sample is a big advantage when replacing something
Sep 18, 2017 | Cars & Trucks
Where is model number located on regency wood stove
Hi chery;
There should be a plate or decal on the back of the stove.
It will have the make, model, serial #, and clearances required from combustibles.
Oct 24, 2015 | Home
I am building a box to grow vegetable in I am heating with 60watt light bulb the box is made of plywood. I would like to how I can put light bulb to the plywood without starting a fire?
You should NOT use combustible material around electric light bulbs or other heaters the way that you're describing. Use only non-combustible materials such as steel, stone, etc. Gypsum board (aka "sheetrock") is a "fire rated" combustible - based on its thickness. After the amount of time on it is exposed exposed to fire, it burns (as determined by the fire rating).
Feb 27, 2015 | Garden
D2C01 error code
It's a non-critical shutter release error. It's nothing to worry about, and can be cleared and ignored. It happens sometimes when the camera is powered off (or the battery runs down) when it's still trying to do something.
Mar 24, 2014 | Olympus E-620 Digital Camera with 14-42mm...
We were given an 87" stainless steel propane patio heater. Our deck ceiling is 96". Will that be enough clearance?
Had a look at the manual on a BFX750 patio heater and the distance required is 50cm above (18") and 60cm to the side (24"). If its the same type with around 13kw or 44,000BTU/h of power then this is the clearance is needed for air and heat.
Dec 31, 2012 | Stainless Garden Sun Steel Propane Patio...
I have an old Efel Kamina wood stove that I want to install in a new structure that does not have a chimney. I need the manufacturer's specifications to determine the distances from combustible materials...
From an insulated wall - 30 inches. Not insulated - 38. We have one as well and are trying to find out information about it.
Southport Stove Inc. Serial # F90309 ICBO 3 500 Another number: 079-66 It's a Kamina.
Any information would be great!
Sep 14, 2010 | Heating & Cooling
We installed a Woodchief wc 100c woodstove and i
Hello, I have the same model. The plate on the back say's,install with min installation clearance's side and rear wall 18 inches fire door end 36 inches front 48 inches above 51 inches flue pipe 18 inches install on non combustible and non conducting base of 9/32 inch min thickness that extends 6 inches beyond the sides and 18 inches beyond fire door side. circulating fan type FF-100
Feb 23, 2010 | Heating & Cooling
Is it safe to put the heater on carpet?
I would say no to be on the safe side....some units are Zero clearance but I would check the manual first for clearance to combustibles....it's always safer to haqve it on a non combustible floor surface
Oct 20, 2009 | Heating & Cooling
Clutch dragging on ktm 450 2008
there should be an adjustment on the clutch handle or cable.
Jul 05, 2009 | 2008 KTM 450 EXC-R
Gas range building codes
that wall needs to be of fire proof construction
so ceramic tiles up to the underside of the cabinets
use a base sheet of asbestos fibre sheeting or like material on which to glue the tiles and keep the spacing close
under the cabinets should have a sheet of stainless (.05mm) as well to prevent flames from igniting the cabinet material as well as making the under side easier to clean
Jul 01, 2017 | Stoves Kitchen Ranges
Dryers Logo
27 people viewed this question
Top Dryers Experts
