Question about Sewing Machines
Owners manual for a supreme industry sewing machine
Need manual for supreme industry sewing machine, for the way it is to be threaded or list of all parts . also I have a number I'm thinking its the seral number but not sure #19821053. can you help me?
SOURCE: threading a sewing machine
What do you mean you are unable to pull the bobbin thread through, elaboration would help solve the problem...
I suspect I'm having the same problem with you if it's anything to do with the top thread looping around in the bobbin holder.
Damn machine!
Posted on Feb 26, 2008
SOURCE: I have a Consew 230
www.sewusa.com can provide a manual
Posted on Oct 09, 2008
  • 5 Answers
SOURCE: Brother DB2-B755-3 industrial sewing machine
I have the manual in pdf form here
http://myweb.tiscali.co.uk/stitches/BROTHER-DB2-B755-MKIII-MANUAL.pdf
Posted on May 12, 2009
SOURCE: I just got a used juki ddl-5550-6 sewing machine.
PLEASE CHECK FIREST TIMMING BETWEEN NEEDLE AND HOOK
OR GO TO WWW.JUKI.COM U WILL FOUND USER GUID ALL LOCKSTICH MACHINE SAME ADJUSTMENT WITH DDL SERIES
BEST REGARDS
Posted on Oct 31, 2009
  • 139 Answers
SOURCE: how to thread & what needles for singer 660 A2 sewing machine
You can download a manual here:
http://parts.singerco.com/IPsvcManuals/
Posted on Apr 07, 2010
Adele Industrial sewing machine...I need to know how to thread it.
GO TO YOUTUBE TYPE YOUR REQUEST AND TYPE OF SEWING MACHINE THEN PRESS ENTER YOU WILL SEE PICTURES AND VIDEOS ON HOW TO THREAD THE SEWING MACHINE PICK A CHOSE TRY A FEW PICKS,REMINDER IS VERY IMPORTANT FOR YOU TO KNOW HOW TO POSITION THE NEEDLE. GOOD LUCK,
Feb 04, 2018 | Sewing Machines
How to thread the singer 20u33? The tension assembly is new, don't know where the wire is sposed to be...
When you thread the top thread, the thread will drop down on the right side of the tension mechanism and go around the bottom (clockwise) and up the left side. Grab the thread somewhere above the tension mechanism with your right hand and then pull the toward the right (as though you are going to close the circle around the tension disk. The thread should pull on the metal wire (spring) and your thread should pop into the correct position of the tension disk. When you release the thread, the wire spring should pop back to the left. Then you will continue threading through the remaining thread guides and the take-up lever.
Here's a service manual for your machine (in case you need one):
Singer 20U31 Service Manual
Threading video:
Threading Singer 20U 20 33 industrial sewing machine
Singer 20U Industrial Sewing Machine Tutorial
Bobbin winding on the Singer 20 33 or 20U
this video shows threading the tension disk:
How to Thread Singer Industrial Sewing Machine
Aug 11, 2017 | Singer Sewing Machines
My fabric keeps puckering.
The first thing I would check is the threading. Remove the upper thread completely. RAISE the presser foot and rethread from the beginning making sure it follows the correct thread pathway. Sometimes thread will "jump" and come out of a thread guide or the takeup lever. Also, raising the presser foot releases the tension disks and allows the thread to seat properly.
Loosen the thread tension. Install a new needle. Also, some machines have a presser foot pressure adjustment that can be set lighter or heavier depending on the fabric weight. The Owner's Manual should have information. On older machines, it is usually a screw or button above the needlebar that adjusts the needlebar's spring tension. Newer machines would have a dial on the side or above the needlebar area.
Seam Puckering Industrial Sewing Thread Tension Coats Industrial
How to Prevent Puckering Sewing Machine
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0ahUKEwjwi5uQrJPLAhUW7WMKHcEQAwkQFggvMAI&url=http%3A%2F%2Fwww.amefird.com%2Fwp-content%2Fuploads%2F2010%2F01%2FMinimizing-Seam-Puckering-2-5-10.pdf&usg=AFQjCNF6q0Pk13ZU4Hb3o3RiAGBbL04l-A
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&cad=rja&uact=8&ved=0ahUKEwjwi5uQrJPLAhUW7WMKHcEQAwkQFgg1MAM&url=http%3A%2F%2Fwww.amann.pl%2Fpobierz%2Fprzemyslowe-nici-szwalnicze.html%3Ftx_abdownloads_pi1%255Baction%255D%3Dgetviewclickeddownload%26tx_abdownloads_pi1%255Buid%255D%3D265%26no_cache%3D1&usg=AFQjCNFeFwt_nN2Mj32Uvv6nCuVY3kM7eQ
Perfect Machine Tension Every Time Threads
http://makeitsew.biz/presser-foot-pressure
Parts of Sewing Machine Pressure Adjustment
Under Pressure Adjusting Presser Foot Pressure
Sewing Machine Pressure Settings for Machine Quilting
Feb 25, 2016 | Sewing Machines
How do I stop the needle thread on my industrial overlocker ef4B531. from breaking as soon as I start sewing. I think I have the threading right.
ensure the tensioners are not too tight, reduce the tensioner to see if this helps. depending on thread type nylon or cotton etc the tension needs to match to control the feed to the needle if it is too high the thread who stick and when the needle makes the next stitch it can break the thread.
I hope this was useful.
Feb 18, 2015 | Brother Sewing Machines
Manual for kenmore 158.19461
Loads of Threading Diagrams here....
Threading Diagrams for Industrial and Domestic Sewing Machines
one will be like yours...your manual ought to have a diagram too
Mar 17, 2014 | Sewing Machines
Brother DB2-B756-5 Industrial Sewing Machine
contact brother website and go to support and click on it
you'll see online support center there will be 4 boxes , choose
number 3 customer support , it has numbers on the box and click
on it, they have a live chat, try that
Feb 12, 2013 | Sewing Machines
Manual for singer 195KI industrial plain machine
How do you thread up and wind thread onto a industrial singer sewing machine model 195KI
Feb 05, 2013 | Sewing Machines
Need owners manual for singer sewing machine 20-13
User Manual: http://www.parts.singerco.com/IPinstManuals/20U.pdf
Parts list: http://www.parts.singerco.com/IPpartCharts/20U11_13.pdf
Service Manual: http://parts.singerco.com/IPsvcManuals/20U.pdf
You are probably out of time. But check to make sure you have the right needle and it's fully inserted first.
Good luck
Nov 03, 2012 | Singer Sewing Machines
SERVICE MANUAL FOR YAMATA FY8700 INDUSTRIAL SEWING MACHINE
my thread deeps bursting, tension is normal. what to do?
Sep 24, 2012 | Yamata Sewing Machines
Sewing Machines Logo
27 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
