Question about Delta Saws
STILL DONT HAVE ANY FEED BACK ON THE DELTA BELT
DELTA SIDE KICK MITRE BOX MODEL K1346973 DRIVE BELT SPACING OF GROOVES 1MM 16GROOVES
efs_perpends
  • 1996 Answers
SOURCE: How do I change the blade on a Delta 10
Please see the instructions given for another similar problem post by clicking here
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Apr 21, 2009
  • 4234 Answers
SOURCE: Delta Side Kick table saw will not start,
If there is no response at all, check the circuit breaker on the motor. There is a heat triggered breaker there. That is the most common cause of this. If that is not the case, please update this and we'll look further.
Dan
Posted on Feb 04, 2010
puertobori
  • 7733 Answers
SOURCE: i have a delta 1836 drum sander and i had bought
In most models there is a button to align the belt, usually on the sides.
Posted on Oct 23, 2010
philwalker78
  • 608 Answers
SOURCE: Fox F36-522B table saw: The blade
Hi, there is no lever or knob adjustment as such but if you look underneath where the motor and blade shaft mount in the carrier you can loosen the mounting bolts and twist the carrier in the direction required to align the blade then re tighten them.1 mm out of parallel is only half a mm of twist. Hope this helps, regards Phil.
Posted on Aug 20, 2011
parkerjohn
  • 132 Answers
SOURCE: does the fan belt need
i believe on the 2.0 it needs to be double sided because the way its routed. you can not run the flat side of the belt against the ribs of a pulley. it will just chew it up
Posted on Sep 15, 2011
What is the pattern of the front drive belt
an engine /vehicle model with information of power steering and ac fitment would help. Basically the grooves in the belt go into the grooves of the pulley and any idlers run on the back ( flat) part of the belt. If you have grooves in the belt running over a flat idler pulley then the belt is fitted wrong.
Nov 13, 2014 | Cars & Trucks
Replace the drive belt
Do you mean replacing the cutter head drive belt?
With power off start the ribbed belt on the motor pulley, insert allen wrench into cutter head shaft. slowly rotate cutter head while feeding belt onto cutter head pulley. While rotating head, alternate between pulleys feeding it on one rib at a time. Softening the belt in hot water is NOT necessary to install the belt in this fashion.
Complements of
http://www.ereplacementparts.com/delta-22560-type-planer-parts-c-3275_3571_3579.html
Cheers
Billy of Hayward Delta 22 560 Type 1 Planer Parts
Sep 16, 2014 | Delta 12" Portable Planer Model 22-560 W/...
Planer problems
If you're looking at the planer from the infeed side, there's a belt guard on the right side of the head. Remove it and check the condition of the drive belt. If it's broke the motor will spin without powering the cutterhead and feed rollers. The drive belt is still available as part number 22-563 on sites like http://servicenet.dewalt.com/ and www.ereplacementparts.com. Just put your model number in their search box and find the drive belt in the breakdown.
Aug 01, 2012 | Masonry Tools
Delta 1313314 motor runs but blade doesn't turn
With this perticular motor I would suspect that the issue is a broken drive belt. The belt is located on the back side of the motor, behind the plastic end cap. The belt is a 10" long cogged belt and looks like a timing belt.
Jan 20, 2012 | Delta Saws
Td4112 which way does belt fit around drive and
check the drive it should have grooves on it. that means that the belt grooves should go around the drive and facing the drum. When you see the belt on the drum you should not see the grooves on the belt
Dec 31, 2009 | Zanussi TD4112W Electric Dryer
How do I change the blade on a Delta 10'' mitre saw Model 34-079? Thanks!
Apr 21, 2009 | Delta 79 803 3' Miter Table System
I need to change a dryer belt on GE model DBxR463EBoWW electric dryer we have the belt on but it is loose
First, make sure you are using the proper belt. For your model
DBXR4630WW that would be a part number WE12M29. Next, the grooves of the belt touch the drum. Now, looking at it from the front side, the belt goes from the left side of the drum directly to the motor drive pulley, then around the tensioning pulley, and then back to the bottom right back around drum.
Jan 21, 2009 | LG DLE2512W Electric Dryer
I am trying to replace the drive belt on my Kenmore front load washer, model 41747102700. The old belt just fell off and was laying on the floor of the washer. In attempting to replace it it seems as if...
The belts on front load washers are very tight. The trick to putting them on is starting the motor side first. Wrap your belt around the motor shaft then while keeping your fingers there to hold it in place, use your other hand to start pushing the belt on the larger pulley while you turn it. The belt is going to try and work back off the motor pulley while you are turning the large pulley which is why you have to keep your fingers down there to hold it on. The new belt will have several grooves on it. Make sure these grooves are all meshed in the motor pulley grooves.
Jun 17, 2008 | Washing Machines
Saws Logo
32 people viewed this question
Top Delta Saws Experts
Jim London
Jim London
Craig Butler
Craig Butler
Are you a Delta Saw Expert? Answer questions, earn points and help others
