Question about Electrolux Washing Machines
My ewf10751 electrolux has working only with washing after i turning round it's knob. how to repair?
    New Friend:
  • 12 Answers
Change timer may be striped knob age of washer your model posted is wrong check again
Posted on Apr 28, 2017
Did anyone can tell me how to enter Electrolux washer Model: EWF1114UW0 service diagnostics mode ?
untitled5-2rgnvy5j4oifscmshudmmeh4-4-0.jpg The procedure is the following:
  • wake up the unit (with door light off and motor stopped)
  • move the knob 2 in the position 1 (for diagnostic mode)
  • press and hold both the buttons 5 and 9.
  • within 5 second the User Interface enters in the test modality (switch on/off led sequence).
  • Turn knob 2 in the position 8 (Last alarm display and possible reset.)
Dado
Jan 15, 2017 | Electrolux Washing Machines
EWF10751 won't turn on
same goes for my model. Power points are fine, fuse ok, but won't turn on.
Jan 16, 2014 | Electrolux EW1000i Front Load Washer
Ariston a1124 knob keeps turning
My machine stopped before/on the spin cycle and the knob was going round and round. I pulled the machine out, emptied the water and the washing and got ready to strip the weights out so I could get it out of the house and to the tip. I tried Jason Harris's tip and so far so good! The machine appears to be working normally. I have it on an empty trial wash. What a star that man is ! Julie
Aug 06, 2012 | Washing Machines
Chain is coming off after 5 mins work
The chain has too much slack.
Look in the manual
The chain needs to be tightened so that there is only a small sagging of the chain on the bottom of the saw.
Looking down at the saw there is a round knob just behind the saw blade.
Make sure the saw chain is in the guides.
Turn the knob counter clockwise to loosen and then clockwise to tighten the saw chain.
Jul 26, 2012 | Garden
Hi i have an indesit w 123s washing machine, that set to any program it doesnt move on it just does that setting,then if you turn the machine off and set it to end program you can reset to rinse and the...
hello try restting it before you bin it
  1. Turn the washing machine off with the on off button.
  2. Turn the selector knob to a dot, or any off position
  3. Turn the washing machine back on and watch for rapid flashing on the neon light
  4. Turn the washing machine off and select the new program (or maybe spin)
  5. Turn it back on and the new program should start
NOTE: Resetting the timer selector knob as shown above may stop the clicking round, but if your washing machine has a fault, the clicking round may return when your washing machine encounters the fault again. If your washing machine's program selector knob is clicking round on its own, then read the section above Washing machine stops with lights flashing hope it helps
regards
shaun
Mar 13, 2011 | Indesit W 123 Front Load Washer
I'm finding my electrolux inspire washing machine is stopping mid wash and beeping showing error code e20...Can you please give me any advice on what could be the problem. This happens about 2 out of 4...
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Feb 24, 2011 | Electrolux Washing Machines
When I try and turn it on it comes on briefly but then immediately turns off. Also the plug light and 3rd light to the side of round knob light up.
Check the dial setting. It should be on either the smallest dot or the one next to the smallest dot on the dial. If it still cuts off,your valve assembly (full bag control) is probably the cause and needs to be replaced. The best thing for you to do is take your vac to your Aerus/Electrolux shop for repair.
Nov 21, 2009 | Electrolux Epic 6500 Vacuum
I have a electrolux EWD124I washer/dryer and the timer knob is just going round after I've selected a wash programme until it reaches off position
Hi.
It sounds like a faulty electronic control.
Parts and wiring must be tested before replacing the timer board.
Regards.
Nov 13, 2009 | Electrolux Washing Machines
Zanussi washing machine drum will not go round at all
Tracy
The bearing may have siezed or you have something jammed between the drum and outercasing
Mar 23, 2008 | Washing Machines
Washing Machines Logo
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
