Question about Car Audio & Video
Need wiring diagram for all plugs in the back.Can't get audio
WIREING DIAGRAM FOR invision hmd 0701ax wireing diagram
invision hmd 0701ax wiring diagram, try
Oct 15, 2017 | Car Audio & Video
I need the pin (plug) wire diagram so I know where each wire goes in the plug that plugs in the back of the Pioneer FH-P6200
Jan 08, 2010 | Car Audio & Video
Wiring diagram
My fault meant this as a solution post....
What do you need the diagram for? If your installing the radio, you do not need a diagram you need to go purchase the wiring harness for your make and model and year car. Match the colored wires together to the ones on the back of the head unit then connect them, then that harness plugs into your stock car harness that your stock radio unplugged from. You also probly need an antenna adapter cable that just connects to your stock antenna cable to add length and then plugs into your aftermarket radio. If you need a wiring diagram because you are trying to open you radio and fix it because it is broke or something...good luck to ya. Hope I helped... :)
Dec 15, 2009 | Kenwood KDC-MP208 Car CD/ MP3 Player
2005 Neon SXT Stereo Wiring Diagram
2005 Dodge Neon Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink/Light Blue
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Orange
Car Stereo Dimmer Wire: Black/Yellow
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Jun 19, 2009 | 2005 Dodge Neon
Toyota original car audio 75400
You can pick up a Metra reverse harness from most stereo shopes and it will also have the wiring info you need.
Jun 04, 2009 | Metra Toyota Car 1987 2000 *Nic
Need the schematic for a Videoman JCS-701 rear camera monitor so we can wire a new plug for the back of the monitor. Someone cut off the old one.
facing the rear of the monitor, the two round 5 pin plugs on the left are the rear camera plugs on the far right four pin square plug red cable terminal 15 ign power... black cable terminal 31 neg battery... orange cable back-up lights... white cable to hopper lights.., I have a full wiring diagram for the system if you needa copy e-mail me at
Apr 29, 2009 | Car Audio & Video
Wiring diagram
Hi, Put "Vintage schematics" into your search engine and it will take you to a link.
Kind regards
Oct 14, 2017 | Audio Players & Recorders
Wire harness diagram will give you the cars wires, u may want to just by a harness adapter, cutting wires=bad
Nov 21, 2007 | JVC KD-S680 CD Player
Car Audio & Video Logo
23 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
