If you have selected the wrong cycle long Cottons one and realise half way through, how do you change and start a Quick Cycle
    Top Expert:
  • Washing Mach... Master
  • 51,494 Answers
Read you direction manual, we could only guess at what machine you have.
Posted on Apr 28, 2017
Have a WDL540 can you explain the symbols on the right hand side of the machine has mins and other symbols. Don't have an instruction book. A wash takes 2 hours at 40 degrees its too long.
Do you mean a Hotpoint Aquarius WDL 540 washer? The wash cycle timing is available in the manual on page 8 of the manual (see link below). A normal-sized cottons wash at 40 degrees C takes about 150 minutes (2 1/5 hours) if you have good water pressure and do not use too much detergent. The coloreds cycle is shorter (just under 90 minutes). The indicator lights on the very right hand side (in a downward slash pattern) give the cycle status information. The top light is wash, and the next one down is rinse. The rest are Spin, Dry and End of Cycle. See page 7 of the manual. The function buttons, below the wash temperature and drying time/humidity selection knobs, are from left to right: Super Wash, Extra Rinse, Mini Load, Slow Spin. These are given on page 9. The dryer dial gives you the choice of selecting a dry time from 40-180 minutes or by humidity. The humidity options are Iron (leaves clothes slightly damp), Hanger (ready to put away) and Cupboard (to dry heavy items like towels to a very dry stage). Note the dryer can't manage as large a load as the washer function does. You may need to split the load after doing the wash.
The manual for the WDL 540 is available on the product page: https://www.hotpoint.co.uk/appliances-1/washer-dryers-3/hotpoint-aquarius-wdl-540-p-.c-washer-dryer-white/F064656/ . The picture of the washer shows the function buttons when you zoom in on the control panel. The direct link to the manual is http://docs.hotpoint.eu/_doc/19512781900_GB.pdf .
I hope this helps.
Feb 02, 2018 | Washing Machines
How do I reset the washing program ? I tried to change the washing cycle and it would not run. Now I cannot return to the original washing cycle.
Unplug the power then plug it in again. Now select the program you wish to run and start it. Make sure the door is well shut.
Dec 03, 2014 | Washing Machines
The dial on the cycles never advances to the "off" position
The timer is shot. Replace it. Check around there are places that rebuild them, sometimes at half the cost.
Aug 10, 2014 | GE GTDL200EMWW 27" Front-Load Electric...
Kenmore ultra wash dishwasher
Replace control board.
Nov 15, 2017 | Dishwashers
How long is the burner heat cycle supposed to be for a 2007 kenmore dryer
"How long is the burner heat cycle supposed to be for a 2007 Kenmore dryer?"
That would depend on which dryer setting (permanent press, cottons, delicate, etc) you had it set on and the amount of time you had it set to dry. The time setting is really what determines how long the cycle will be. The other setting determines the amount of heat that will be needed for that selection..
Hope this helps ....
Mar 25, 2011 | Heating & Cooling
Reset wash cycle
Changing Cycles, Options and Modifiers
Not all Options and Modifiers are available with all cycles. Cycles,
Options and Modifiers can be changed anytime before HOLD TO
START is selected.
Options and Modifiers can be changed anytime after HOLD TO
START is selected and before the start of the selected Option or
Modifier.
To cancel a cycle and select a new cycle
1.
Select PAUSE/CANCEL twice.
2. Select desired cycle.
3. Select the desired OPTIONS.
4. Select HOLD TO START (for approximately 1 second) to
restart the washer at the beginning of the new cycle.
To cancel a cycle
1.
2. The washer powers down, the door unlocks, and clothes can
be removed.
NOTE: If the water level or the temperature is too high, the
washer will drain automatically before the door unlocks.
To change Options or Modifiers after the cycle has started
1.
Select PAUSE/CANCEL.
2. Select the desired OPTIONS or MODIFIERS.
3. Select HOLD TO START (for approximately 1 second) to
continue the cycle.
To drain the washer manually
1.
2. Select DRAIN/SPIN.
begin the drain.
4. When the spin is complete, the door unlocks. Items can be
removed from the washer.
Nov 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
On/off button & non crease button flashing
Sounds like the pump and sump hose is blocked,Check both out
Oct 29, 2008 | Hotpoint Aquarius WD63 Front Load...
Best temperature and spin cycle setting to wash cottons !
White cottons-Hot wash/Cold Rinse /high spin sycle
Colored Cotton Cold/Wash/Cold Rinse/ high spin cycle
Aug 21, 2008 | Hoover Washing Machines
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
