Question about Refrigerators
It is a fridge freezer with freezer at the bottom what should temp be set at
SparkGap
  • 363 Answers
SOURCE: ice at the bottom of the freezer
It sounds like the freezer has leaking door seals and air is getting in to the freezer compartment. Your temperatures are set about right. Regards
Posted on Oct 02, 2007
SOURCE: Freezer works great, as it should, but fridge is only keeping items room temp. I have the setting at the coldest setting: #7. What is wrong?
Here's what I did, I defrosted! I found out that the fridge temp is monitored and maintained by the freezer. Because we had a power outage one night, my freezer thawed while we all slept and then when power came back on, freezer re-froze but this cause an ice build up on the vent on the back wall of the freezer. Well, ice must have been in one (or more) vents, causing blocked air flow in my top half of the refrigerator. I turned the dial in the freezer to "off" which also shuts down power to the fridge half. I then unplugged the refrigerator, hauled all my food items into coolers, opened the freezer door and refrigerator doors and left them open for a little over six hours. I took advantage of this empty fridge and freezer and wiped everything down. After this time frame passed, I plugged the fridge back in, turned the freezer dial to my preferred freezer temp, and wah-lah! Within two hours I had a cold fridge and solid ice cubes in the freezer. I then put all my food items back into their appropriate compartments, and went to work. Bear in mind, a total 24-hour period is needed for the fridge to re-set itself, but still, after two hours the fridge was noticeably cold. Who knew, besides our parents' generation: DEFROST!
Posted on Sep 11, 2008
SOURCE: Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Posted on Nov 23, 2008
  • 686 Answers
SOURCE: fridge is warm even when i adjust temp. control.freezer is good.
if your fridge has 2 set of dials one numbers and the other letters than you need to adjust the dial that has letters on it. If the fan in your freezer is not blowing, then it won't force the cold air from the freezer to the fridge. Make sure fan blows then adjust the letter knob.
Posted on Feb 17, 2009
  • 2418 Answers
SOURCE: Inglis Fridge model# IRT184300, warm fridge, cold freezer
There is a fan in the top of the refrig that is not turning. Ck for that fan and pos. ice build up in between.
Posted on Mar 10, 2009
My kenmore top fridge bottom freezer in my cold garage is 22 degrees in the fridge and exploding soda cans
The temp setting for the freezer impacts that temp in the refrigerator. What is the temp setting? How cold is the room that it is in.
Feb 06, 2015 | Kenmore Refrigerators
I have an amana bottom freezer fridge. 3 years ago ,y freezer was frosting inside and the fridge temp was not getting cold enought. a repaiman replaced the thermostat. now the freezer is beginning to...
To fix up a frosted up vents, I had a control board replaced for $180. Then 6 months later, the bottom freezer frost up AGAIN. rather than dumping more money to fix it, I was about to buy a new fridge, but had a crazy idea: I disconnected the water to the freezer, bought plastic trays for ice cubes for $3 at walmart. Fridge has worked like a charm for 6 months. no signs of frost. Saved $1000's.
Dec 12, 2011 | Amana ABB1927DE Bottom Freezer...
Have a Whirlpool Gold fridge manufactured in 2000 according to the sticker inside fridge. Same sticker says model# is GT22DA or GT22DC. Freezer is working fine. Fridge part is not keeping food cold and in...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Dec 15, 2009 | Refrigerators
21' bottom freezer kenmore refrigerator-no ice maker-the fridge is super cold and freezes all my vegetables and fruit. We have cleaned the coils, cleaned the fridge, and it just keeps freezing. Fridge is...
Oct 02, 2009 | Kenmore 21.0 cu. ft. Bottom Freezer...
Refrigerator not keeping temp.
There is normally a fan in the freezer (usually removing the back panel from inside the fridge will show it [sometimes you need to pull the bottom panel of the freezer off] The panels are normally secured with phillips head screws.). If it doesn't turn, it probably needs replacing. Make sure the coils are not iced over. [unplug while removing panels, then plug back in... the temp will have risen in the freezer so the fan should come on right away].
Make sure that the "vents" in the freezer (bottom of the freezer - in the front back or both) are not covered.
Some fridges have a separate control for fridge temp, make sure that was not moved, or try setting to a colder setting.
Sep 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a brand new kenmore elit bottom mount freezer and the fridge part keeps freezing food. I have it set at the recommended settings. I have already replaced this fridge once because of the same issue....
Sep 21, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Internal temp of fridge and freezer are different from bottom top
Hi, Is the evaporator fan motor running in the freezer? Was the fridge setting any length of time unplugged before you got it?
May 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Mar 09, 2009 | GE GBS22HCR Bottom Freezer Refrigerator
LG LRBN20514ST Bottom Freezer Frig cooling problems
Set the temp to low not high and wait 24 hours to see if the temp has drop.Also make sure the freezer is not icing up anywhere.If it is please repost.
Jan 13, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
Refrigerators Logo
23 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
