How do you put it on speaker when answering a call
Why have i not gotten a response to my question
Hello Dustin
Because sometimes there is no answer! As I understand it, your Alero speakers in the back of the car don't work?
You put another speaker on the end of the wires and they worked.
You put another sound source into the car speakers and the speakers worked.
Stumped. That is an enigma. I would redo the connectors to the speaker.
Jan 21, 2016 | Cameras
Can I put speakers to my player
U Suck Answer My Question First scrub
Jan 16, 2015 | Audio Players & Recorders
Computer speakers put out static every 10 seconds with printer on.
Would you be so kind to answer the following questions so that I may better help you. Is the printer an all-in-one with fax capability? Is it a Wireless printer? Is the wireless feature turned on? When you state "speakers" are you referring to the all-in-ones' fax speaker or the PC / laptops audio speakers? Are any of the speakers external and are theywireless too?
Nov 23, 2013 | HP Photosmart C8180 All-in-One InkJet...
Have JVC 6008V A/V Receiver. No out-put from left-front speaker out terminals. Checked fuses, and all are good. R/F, and all other speaker out functions work fine.Switched speakers to make sure problem was...
make sure you're using the corresponding speaker inputs for speaker 1 (only) and turn off Speaker 2 on the bottom left corner near the headphone jack (it should be sticking out further then the speaker 1 button). hope this helps.
Aug 06, 2010 | JVC RX-6008V Receiver
The earpiece doesn't work on my Samsung Rugby. I can answer a call, but need to use speaker to hear the caller. The volume works fine.
Dear, your phone's head speaker is not working so you just need to go to a mobile phone repairer to change your speaker. Speaker is not expensive, If you want to change speaker yourself then its is not very difficult to change, you just need to put new speaker in the place of speaker.
Thanks
May 07, 2010 | Samsung Rugby SGH-a837 Cell Phone
No sound is working on my hp pavillion
Try running through the Sound setup wizard in windows. It should dynamically adjust the speaker setup providing you answer the questions correctly. # of speakers, type of sound etc.
G/L
Sep 09, 2009 | HP Pavilion dv9000z Notebook
The HTC Touch Diamond phonecannot hear caller when answering call
try hard reset, if it does not help, put it to service, it could be broken speaker
Jul 06, 2009 | HTC Touch Diamond Smartphone
Insignia speakers NS-22 not working
i would clean the ends of the speakers and make sure you try all of the plugs, you could be putting them in the wrong spot. also, go to their website and click on support they should have more answers to this you can even contact them with this problem. maybe the speaker cables are bad.
Mar 23, 2009 | Insignia Audio Players & Recorders
23 people viewed this question
 Grubhead
Grubhead
