Question about Kitchen Ranges
My middle element of my flat top won't go the two outer rings still go
  • 146 Answers
SOURCE: Large Dual Element Is Not Working
Check the center ring. If it is open replace it.
Posted on Dec 21, 2007
Jimster
  • 240 Answers
SOURCE: Frigidaire glass top
You will need a wiring diagram and a multi-tester (volt meter, etc). Find the diagram for the elements, trace your wires to that switch, and check for voltage coming out of that infinite switch. If you have voltage, then its your element (85% chance its the element anyway). Good Luck.
Posted on Nov 05, 2008
  • 311 Answers
SOURCE: The inner right front element
inner element burned out. Either burner needs replacing or control switch is bad. Take out burner and see if coil has a break in it. IF not, then switch is bad. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 28, 2008
  • 37 Answers
SOURCE: large combination burner in glass top cooktop just
Yes it sounds as if you have control knob probs ..did it work b4 or is it a new cooker ?
Posted on Sep 06, 2009
milten1
  • 1304 Answers
SOURCE: middle section of element on smoothtop stove not working
yes you can
goto appliancepartspros.com
type in your model number
under the section top
you will find your part number...
when it arrives unplug the unit and remove the screws holding the top down under the froont lip
lif the lid and mark where your wires connect, remove the wires, and the two 1/4 scres holding the burner
sometimes 4
switch out the burner, and re plug all your wires
drop the lid and test
Posted on Oct 16, 2009
How do i turn the outer ring on for a dacor stove top
Pushing the button for the element will turn on the inner element at level 5. Before adjusting the level (so while the level indicator is still blinking) press the little circle on the right side of the controls for that element. The circle should light up. Now press the UP control for that element, and the level indicator should stop blinking. Now the outer and inner elements are both heating up. Adjust temp level to desired setting.
Jan 30, 2013 | Dacor Millennia ETT304 Electric Cooktop
GE Spectra Dual Burner not working.
the burner is faulty
replace just the upper part of the brner
or try to clean it
yourself
Sep 16, 2008 | GE Spectra JBP78 Electric Kitchen Range
How do we replace water heating element in bunnvpr series .Having problems getting element out of water tank.
You have to pull the top portion of the tank with the element still attached, look for the ring of bolts on the outer edge, careful not to damage the tank lid gasket when you lift it out.
Jan 19, 2011 | Bunn VPR Coffee Maker
Inner burner on duo element does not heat up. Seems dead.
This could be either the element itself or the switch that controls the element. Since the outer ring is working the issue almost always is with the element. The top can come up and the element replaced.
It is a moderate repair, so some technical ability will be required, the use of an ohmmeter is needed to verify the component that has failed. Let me know if you need more information.
May 06, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Middle section of element on smoothtop stove not working
yes you can
sometimes 4
Oct 15, 2009 | Kitchen Ranges
The inner right front element will not heat up on our Kenmore Elite ceramic stove top. The middle and outer elements on the right front work fine. Why is this happening?
Nov 28, 2008 | Kenmore Kitchen Ranges
I have dust under outer lens on my 75-300mm f/4 -5.6 III USM
Front element? You can remove this without alignment worries. The lens zoom mechanism tends to **** in the dust.
Have a look at the front element outer ring. There are 3 black screws. Remove these using jewellers screwdriver (y'know, a very small posi-drive one!). Remove this plastic outer ring. Now you can see three small silver screws, that are about the same size - when you try to unscrew them, they just rotate...
This is as they are not screws, but as mentioned elsewhere - they are plugs (if you notice, they are slightly under the casing. Get a small flat bladed screwdriver, and gently prise them out. Now you can just drop the front element into something sensible - like a microfibre cloth (give it a clean whilst you're there.
Get a rocket blower (NOT canned air), and blow away the dust, and you can use the microfibre cloth (or similar) on the small inner front element.
Then replace the outer front element - you will see where it drops into place - there are plastic guide tabs. Push back the silver 'screw' plugs.
Then screw back on the plastic outer ring and you're done - takes 20 minutes at the most.
Jul 02, 2008 | Canon 75-300mm f/4-5.6 III USM EF Lens
COOKTOP
its been my experience that the dual burner switch is far more likely the culprit, unless you can physiclaly see the outer ring is broken( visual inspection works wonders. as far as trying to ohm out i generally look at theelemnet itself (4 wires lead to the elemnt you can trace 1 to the outer portion of element, and 1 to the inner portion.WITH POWER OFF Iswithc those 2 wires and the restore power try element ad watch for outer ring to work inner ring no good. now i know its the switch not sending power. reset wires and order new switch
Mar 08, 2008 | Cooktops
Dec 21, 2007 | Maytag MER5765RAS Stainless Steel Electric...
Kitchen Ranges Logo
26 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
