Im2520f error code c0500 how to solve - Office Equipment & Supplies
faeq8
  • 7 Answers
SOURCE: error code C0500
C0500: Warming-up Failure C0510: Abnormally Low Fusing Temperature C0520: Abnormally High Fusing Temperature Relevant Electrical Parts Fusing Roller Heater Lamp H1 Fusing Roller Thermistor TH1 Fusing Roller Thermostat TS1 Fusing Roller Heater Lamp Fuse TF1 Side Cover Interlock Switch 2 S3 Power Supply Unit 1 PU1 Master Board PWB-A
Step Check Item Result Action 1 Does H1 turn ON after the malfunction is reset? YES Check TH1 for contamination or installation. 2 Is there continuity across CN3-1 and 2 on the Fusing Unit end with CN3 (2P) disconnected? NO Check H1, TS1, and TF1 for continuity. 3 Is there continuity across 1A and 1B, and across 2A and 2B, of S3 when S3 is turned ON? NO Change S3. 4 Is the resistance of TH1 (across CN5-2 and 3 on the Fusing Unit end) infinity? YES Change TH1. 5 Is Fuse F2 on PU1 conducting? YES Change PU1 or PWB-A. NO Change the fuse. Step Check Item Result Action 1 Is TH1 installed properly? NO Install TH1 correctly. 2 Is TH1 dirty? YES Clean or change TH1. 3 Is the circuit across CN5-2 and 3 on the Fusing Unit end closed when CN5 (4P) is disconnected? YES Change
Posted on Dec 28, 2008
  • 7 Answers
SOURCE: I am getting an error code C0500.
Depends on the model of you Konica Minolta. The CO500 is usually related to fusing temp. It's possible that a power spike or a thunder storm that knocked out power to the building would caused this.
Posted on Jul 13, 2009
firecontrol7
  • 6168 Answers
SOURCE: error code c0500
C500 is a fuser code, the hot part of the machine, the fuser fuses the toner to the paper, so that the toner does not smear off. But to solve this must have the model number. As each series of machine has a different way to reset machine
Posted on Jul 25, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: My Oce im2520f is giving me an error code: C0500
The C0500 error code is a fuser unit error code. The fusing unit is the part that gets hot and "fuses" the toner onto the paper just before it exits the machine. There is a special reset procedure for this code so as to prevent overheat of the fuser. You will need a service technician to diagnose the problem in the fuser and then reset the code. Most common causes are blown thermal fuse, bad thermister or rarely, a bad heater lamp.
Good Luck and Thank You for using Fixya.
Posted on Mar 19, 2010
SOURCE: iMAGISTICS 2620 Error code C0500
How to reset malfunction code C0500 of a imagistic
Posted on Sep 20, 2011
HOW TO SOLVE ERROR CODE C0500 FOR KONICA MINOLTA 211
Error code C0500 and C0501 means Fixing unit's temperature abnormality.
How to reset these codes?
To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
http://servicekonicaminolta.blogspot.com/2012/03/error-code-c0500-and-c0501.html
Jun 14, 2017 | Konica Minolta Office Equipment & Supplies
C0500
May 01, 2014 | Minolta Di3510f Bizhub Copier
Machine give a coade c0500
The error code C0500 deals with the fixing unit temperature. I could be a blown fixing lamp or thermal fuse or thirmister. You did not give the model number, so I can not tell you how to reset the error code. Good Luck
Nov 02, 2013 | Minolta Office Equipment & Supplies
Imagistics all in one copier/fax/scanner im2520f. All is working except the scanner which is giving error code EA21F7.
Try restarting your printer to see if the scanner lense moves properly and not jammed next you need to download the latest driver and suite from manufacturer`s website which shall definatly solve your problem.
Sep 30, 2013 | Pitney Bowes 460-4 Toner for Imagistics...
How to reset error c0500
The error code means that the fuser is not warming up correctly. There is a small black rest botton on the main controler PCB on the back of the copier. You are going to have to take the back cover off, I believe in is four screws. Turn the power off and remove the back cover and find the small black botton, once you have found it, turn the copier back ON and press the botton and see if the error code can be rest. If it dose you are good to go... If not you may have to replace the fuser unit..... I did have a problem that was not solved with the fuser unit.. It turned out to be right side door switch... I would look there as well with the back cover off... Good Luck
Apr 04, 2012 | Minolta DiALTA Di183 Copier
The machine di251f is saying contact your technician with code error c0500 please help
error code c0500, checked lamp and thermo fuses, checked thermistor ok. reset machine
Jun 17, 2011 | Minolta Di251 All-In-One Printer
My Oce im2520f is giving me an error code: C0500. After about 3 minutes of giving me the error code, it beeps four times (long beeps) and then in shuts off. Anyone have any idea what it might be?
Mar 19, 2010 | Office Equipment & Supplies
Error code C0500
Jul 21, 2009 | Konica Minolta DiALTA Di200 Copier
IMAGISTICS 2620 Error code C0500
Feb 03, 2009 | Konica Minolta DiALTA Di200 Copier
Minolta di 2510 code c0500
lo ke pasa es ke mi copiadora ya no responde mas y me sale este error una averia "a sido detectada avice a su servisio tecnio y digalke el codigo c0500" ya no se ke hacer... ayuda por favor..
Jun 24, 2008 | Minolta Di2510 All-In-One Laser Printer
29 people viewed this question
jasbo
jasbo
