My machine gives slight buzzing and display water inlet fault and it spin but does not wash. Please how do i resolve this problem
    Problem Solver:
  • 12 Answers
Need new inlet water valve not opening need to replace not fixable part
Posted on Apr 28, 2017
  • 209 Answers
SOURCE: Washing machine not filling with water not washing but will empty and will spin
like the anchor idea?, no sorry, this does sound like the water is not getting to the machine, so, when you turn the machine on does it make a slight buzzing noise, if so the fault is no water in the pipes to the machine (from the house), if no buzzing check the solenoids with a multimeter for open circuit (removing the 2 wires first) oh and the plug obviously / replace solenoid if needed, i am sure this will cure your problem, if so rate me please, thank you
Posted on Sep 18, 2007
  • 1073 Answers
SOURCE: Maytag Washing Machine Stops after wash cycle...
sounds as if you have abad contact in the timer
advance the timer to a different spin cycle and see if it spins
then bo back to where it stops
if it will spin in the other spin cycles but not where it stops the the timer will need to be changed
Posted on Apr 21, 2008
michiganfan9
  • 179 Answers
SOURCE: Kenmore model 22432100 - it won't drain or spin
sounds to me that something is stuck in your pump check the pump if you open the pump have lots of towels on hand the machine will not spin if it does not drain
Posted on Dec 29, 2008
  • 380 Answers
SOURCE: Samsung washing machine gives Low Water pressure
You get these messages turned off by fixing the problem.
Low water pressure is basically one of the valves is not letting water pass through.
1. Do as you already did and clean the inlet filters. Any kinked hoses?
2. Adjust the water pressure in the house. Is it too high or too low?
3. Replace the valves in the unit.
4. Main board.
Posted on Dec 30, 2009
blueextc3221
  • 15935 Answers
SOURCE: OE fault displayed on spin cycle LG 1019BD 10KG WASHING MACHINE
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 13, 2010
Washer will not spin
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Jan 17, 2013 | Washing Machines
I have a GE Profile Washing Machine with Fuzzy Logic
Since the fault was not mentioned I am giving a generic answer for possible faults.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Thank you for using fixya.
Sep 06, 2011 | Washing Machines
Intellowash WF-N7065DN, Spin + Wash lights blink and give contineous beeps
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Jul 26, 2011 | LG Washing Machines
Zanussi 1140m stops half way through wash cycle then displays error code E21.....works ok on stright spin cycle....filters checked and found to be clear
Jul 19, 2011 | Washing Machines
LG 7.2kg top loader washing machine The machine repeats the spin and rinse cycle about 6 times, and then gives a UE error code.
It is possible that the machine does repeat the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Jul 12, 2011 | Washing Machines
The machine is not spinning, the washing is just turning and getting very tangled. The display is not showing that there is anything wrong, but the washing is tied in knots and not spinning
Jun 29, 2011 | Washing Machines
My washing machine model: Fuzzy Logic WFT10C31EP. Problem: When I start the machine, water does not fall into the tub although water pressure from the source is excellent. Only spin is...
It sounds like the water inlet valve is not functioning like it should. It is supposed to open to allow water to flow in when the Control Board gives the signal to open. First, try cleaning the Water Inlet Valve Filter. Turn the water supply off and remove the Water Supply Hoses. You will see the filter inside the Valve. Clean it out, and reconnect the hoses. Try washing again. If no water flows into the machine, you will need to replace the Inlet Valve/s. Try running an empty wash with just cold water, and then try running an empty wash with just hot water. If neither are working, you may have a control board fault. If only one side works, replace that sides water inlet valve.
Feb 28, 2011 | Daewoo Washing Machines
I have a Bosch clasixx 1200 s express washing machine, When I select a program the machine buzzes but the cycle doesn't begin. The drain cycle works and the spin works. if i select freshen and rinse the...
Bosch clasixx 1200 This video will show you How to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
And don't forget to like us on facebook
Feb 26, 2011 | Bosch Classixx WFL 2066 Front Load Washer
Hotpoint WD62
try fuse on plug this may be gone, also the door interlock switch, try a light bang with fist near door catch see if this will do it, what i do suspect is the door inerlock is faulty, this is a safety device which locks the door when machine is in washig/spinning mode it aso stops machine working when you open the door, this is also a safety device, good luck al. xxxx
Jan 13, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Sep 18, 2007 | Washing Machines
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
