Question about Ricoh Office Equipment & Supplies
  • 4402 Answers
SOURCE: Installing print drivers for Dell M5200 Laser Printer
Posted on May 22, 2008
  • 5 Answers
SOURCE: problem in scanner when scan
Try adding the scanner's IP address in the scnhosts file in the TWAIN folder. Format is similar to the windows hosts file. You'll see a commented out sample entry, just modify that to suit your needs.
This may or may not work for you; we had it working under this configuration but then it stopped for no apparent reason. also note that scanrouter isn't supported under vista. Only advice I've been given so far is to revert to sending scans via SMTP - not ideal!
Posted on Jul 22, 2008
  • 118 Answers
SOURCE: Ricoh SP C811DN error sc549
unplug printer, wait minute, plug in, should reset.
check Ricoh website to trouble shoot if does not reset.
Posted on Apr 29, 2010
SOURCE: ricoh aficio mp 1600 L printer driver has been
E000002-0000 le code panne ci dessous
Posted on May 28, 2010
  • 903 Answers
SOURCE: my ricoh printer is showinf an error of sc440-2
sc440 on the CL7000 is a drum motor error. sc440-2 is specific to the color drum motor. The problem is either the motor itself, the drum gear position sensor, or one or more of the color photoconductor units. The photoconductor units you can replace yourself if you have extras -- see if that will clear up the problem.
If they don't, you'll need to contact a service technician to inspect (and replace if need be) the motor and sensor.
Please rate this solution if it was helpful. Thanks!
Posted on Sep 17, 2010
Ricoh Aficio SP C430DN - Print Data Error
Its you, change drivers, postscript on the printer? PCL 5C is what your are using?
Mar 31, 2014 | Ricoh Office Equipment & Supplies
Change language for Ricoh spc232
Printer Language?
If you have the driver disk, reinstall the printer using the other language. You do not not have to delete the old one. You can have both PS and PCL as printer options
Dec 30, 2013 | Ricoh Office Equipment & Supplies
Ricoh Aficio MP1600 Le
Is your Windows 7 a 32 or 64 bit? Which driver are you downloading? Recommend PCL5c...
Feb 10, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
Our copier doesn't copy and shows error message "unable to print..." we want to get it fixed, please help
The graphics is not initialized
because the graphics memory
was not reserved. This error
rarely occurs unless the printer
detects the memory failure.
Please note that
“RPCS”(RICOH printer language)
is the same worldwide
and does not need to be translated
Replace the installed memory.
Turn the power off, and then on. If the
message appears again, contact your
sales or service representative.
Oct 02, 2009 | Office Equipment & Supplies
Ricoh Adicio on a mac
Your machine requires the Postscript option installed in order to print from your Mac. The printer is printing gibberish because it cannot understand the postscript driver from the Mac. .
Jul 22, 2009 | Ricoh Aficio 2027 All-In-One Laser Printer
The print properties are completely software based and have nothing to do with the printer itself. You've had to have installed the wrong version of the print driver or your operating system is set to the wrong default language. I'm assuming you would know if you were running a foreign copy of Windows so I would uninstall the printer and then download and reinstall the English version from the Ricoh website.
Jun 10, 2008 | Ricoh Aficio CL3500N Laser Printer
27 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
