Machine won't run. Error code e49 - Washing Machines
    New Friend:
  • 12 Answers
Need model # or brand name
Posted on Apr 28, 2017
I have an aeg dishwasher showing error code 49 what is this and how do I fix it
Error code E49, generally speaking, at AEG dishwasher does not exist.
Dado
Jan 05, 2015 | AEG Dishwashers
Washer won't stay running error code DS
I am wondering if your error code is DS and not D5, which would indicate problems with the door lock assembly communicating with the control board. Essentially, the control board does not believe the door is closed and/or locked, so it shuts down the machine.
Oct 16, 2012 | Washing Machines
Error e49 on casio 130cr how to fix it
I have no information on error 49. Are you sure this figure is correct?
Aug 27, 2012 | Casio Parts Cash Register PC Desktop
I have a Toshiba RD-XS27KE DVD/VR. It does not perform any recording on the HDD - error code E49. I have deleted titles and it still does not record. What can I do ?
I fixed it by 1. delete all on HD drive (a function described at the end of your manual) 2. turn off your recorder 3. turn on your recorder 4. now should E49 not be vivible and recording function again
Jan 31, 2011 | Toshiba RD-XS32 DVD Recorder
Hi, I have an LG 1412RD washer dryer. I received the DE error message so opened the front to access the door lock and plugged in the electric socket which seemed loose. Now I am getting the OE message...
http://www.lg.com/au/support/product/support-product-profile.jsp?customerModelCode=WD-1412RD&matchedModelCode=NOT_MATCHED&searchEngineModelCode=WD-1412RD&initialTab=documents&targetPage=support-product-profile#
Owners manual above. LG washing machine error code – OEThe LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn’t pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
Apr 10, 2010 | Washing Machines
E49
Go to http://alldatadiy.com/ and buy a subscription for your vehicle. If you want to repair it yourself you will need this data. It is good for 1 year and has, testing and inspection guides, component locations, wiring digrams and a lot of info the DIY'er needs.  I am looking in all my code manuals and still do not see an e49. AIR is a system that puts fresh air into your exhaust so the emissions at the tailpipe are lower. It's an EPA mandated system. If you have to pass an emissions test in your state or county you will have to get them system woking properly. Check out alldata it is worth the 30.00.
Jan 01, 2009 | 1990 Cadillac SeVille
E49 code on cadillac deville 1990
Dante,
(Quote) I looked up code E49 and there is no such code.
The above quote is from my colleague named “txkjun”. With all due respect to him and his “Guru” status he is wrong. The code “E49” does exist, and it is an “AIR management system error".
At this time I would like to apologize for typing a word that didn’t belong in my response.
You see, when I said the code “E-49” “DOES NOT” exist I was responding to the answer that: “Txkjun” gave you.
I meant to say that the code “DOES” exist, but I simply typed in the word “NOT” by accident.
I'll get back to you with repair procedures in a few hours.
Thank You.
Peter.
Jan 01, 2009 | 1990 Cadillac Deville
::check engine like::E49::
If you really want to fix this problem yourslf then you will need to go to this site http://alldatadiy.com/ and buy a subscription for your car. It cost under 30.00 and is good for 1 year. They have test procedures, repair procedures, component locations, wiring diagrams etc, everything you will need. It is well worth the money. I looked up code E49 and there is no such code.  Do you know how ot pull up the trouble codes. Scan it again and tell me the correct code so I can help you.
Dec 30, 2008 | 1990 Cadillac Deville
Error code "loc" on GLTF2940ES0 washer
turn the selector knob so the machine comes on then press the "options" and "select" bottons at the same time for 3 seconds.
Oct 10, 2007 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
