Bipap shut down, shows error code E 49. Up plugged and restart same problem.
  • 1420 Answers
SOURCE: Rinnai RHFE 1004F Error code 49
A 49 error code is caused by the pressure switch either not proving or a bad component. Check the hose attached from the plastic elbow located behind the heater going to a small square pressure switch found inside the heater. It may have come loose or a mouse may have taken a bite out of it. Also while you are behind the heater, pull off the hose that looks like a vacuum cleaner hose and run the heater with it unattached. If it runs, you have a blockage in the vent. If not, take a flashlight and go outside to the vent. Look down the center pipe for any obstructions. If it still does not work, you may need a new pressure switch.
While the front panel is off the heater, cycle the heater to attempt a start. You want to make sure the blower turns. If it does not, check the wire connections to it. You may be looking at a bad blower. If it is turning but still does not start, we are looking at a bad pressure switch.
Let me know what you find, I may have a switch or blower motor that you can purchase.
Posted on Nov 01, 2007
  • 1776 Answers
SOURCE: lg washer shows up side down F E code
No, this is not the same as the LE code. The FE code indicates an overflow error or condition. The things to check out would be the drain and the drain line to make sure there are no kinks in it. The drain hose can get clogged with sludge and sometimes a hot wash with a 1/2 cup of vinegar will clean out the sludge. If that doesn't work, I would take a look at the pump to make sure it is not clogged with anything and that the pump impellers are good. Take a flashlight and look into the suction port of the pump. Look for any broken or missing impeller blades. If any are broken or missing or if the impeller will not move freely, the pump would need to be replaced. Hope this helped and best wishes.
Posted on Jul 31, 2009
  • 137 Answers
SOURCE: after start my machine shuttingdown
its a sanner problem, disconet the upper door and see if its work
Posted on Mar 05, 2011
SOURCE: hp color laserjet cm1017 mfp
Hp color laserjet cm1017 mfp 49 service error showing in disply screen and restart the printer
Posted on Oct 15, 2012
SOURCE: it showed "49 4C02 error.
my printer error 49.4c02
Posted on Apr 05, 2013
Fisher @ Paykel GW 712 washing machine error code 49?
My sister discovered her cold water was turned down,,however a plug or pinch hose could give the same code on fisher/paykel. Check your owners guide for your model.
Jul 27, 2015 | Fisher Washing Machines
49 service error ff04
your printer driver is corrupt or the files your printing are corrupt- most 49.xxyy errors are down to software external to the printer. not sure?.
disconnect the printer from all network points and cycle the power - when it is ready perform a path print test ( found under the diagnostics menu on the printer itself ) and you will likely find no errors ( if by some horror of horrors you do get 49.xxyy error then you will need to replace the firmware chip - Very Very unlikely) -
what to do--
remove the printer and uninstall from the workstation - reboot the PC - re install the latest driver for your operating system downloaded from HP website
re connect the printer - print away !!
Jan 28, 2014 | HP LaserJet 4600dn Color Printer
Respironics synchrony bipap error code 084
i alway get error 41 while using respironics bipap avaps what should i do please sujjest me some thing.
Nov 15, 2013 | Respironics BiPAP Synchrony Blower...
Aug 15, 2011 | HP LaserJet CM1017 MFP All-In-One Color...
I have a 1995 Cadillac Sedan Deville with 109k miles. I bought it new, and it's been without any major problems. Now there is a consistant engine shut down problem after driving or at idle for 7 minutes...
I have a similar issue with a 94 DeVille. Runs for a while then shuts down. Fuel pressure is good (I drove around with a pressure gauge attached and it still shut down with no drop in pressure). I've replaced the idle control and ignition module - no improvements.
I too have code P012 showing which to (potentially) the crank position sensor - which I can't seem to locate.
Any luck on your issue?
Sep 07, 2010 | 1995 Cadillac DeVille
Samsung mobile phone error codes 3d010017
my mobile phone SGH-U708E will shut down without any reason suddenly while making a phone call, it will show the error code"3D010017" after restart it.
Aug 06, 2009 | Samsung SGH-t219 Cellular Phone
My computer won't shut down it just keeps restarting
The most common shut down problem is that the system will reboot rather than shutting down. In most cases, the reboot is triggered because Windows XP is designed to reboot after a critical failure. To stop windows from rebooting in case of a failure, you need to take the following steps:
Right click on My Computer, Select Properties, Click on advance tab, Click on Settings under Startup and Recovery, Uncheck the option Automatically Restart under System failure, Click Ok twice and try to shutdown the pc. If it shows any error code then let me know
Nov 24, 2008 | Toshiba Satellite M65-S809 Notebook
Can't What displayed error message means
49 error normally means that the information sent to the printer is corrupted clear the print que shut down printer and restart. If problem still there then shutdown the printer then remove one of the additional memory turn back on if still same problem repeat removal of the next memory replacing the one you have just removed and so on. After you have done this and you are still getting the problem then it is 99% certain that the printer system firmware is corrupted or the formatter control board is faulty.
Thanks J
Jun 07, 2006 | HP LaserJet 9500n Printer
