Question about Minolta Office Equipment & Supplies
The master please help, error C0F30 minolta cspro ep 4000, what needs to be repaired or replaced or serviced, please help, thank ...
  • Minolta Master
  • 6,696 Answers
When was the last time the developer was replaced in the developer unit? If has been replaced, then you might have a bad ATDC (Automatic Toner Density Control) sensor Located right below the developer unit. If the developer was replaced when it was done was a vacuum cleaner used? IF so the static electricity from the vacuum clear destroyed the sensor, NEVER USE a VACUUM cleaner to remove the developer. Also when the developer was replaced, was counter cleared to tell the copier developer was replaced, the copier uses the counters to determine certain voltages for certain assemblies, if not image problems and codes can appear. Finally, was the F8 run after the developer was installed before ant prints or copies made? If not buy new developer and start over, counter is to be cleared first, then developer replaced, then F8 run.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on May 06, 2017
Eror c0f30 minolta cs pro ep 4000
replace the developer. if you have not done so already. run F8 after wards. was that done? bad ATDC sensor see if you can find one that is a serious Legacy machine
Feb 21, 2017 | Minolta Office Equipment & Supplies
Cspro ep 2030 minolta copying rough in the morning, but okay in the afternoon, solution please
Sounds like the warm up controls are not opperating properly. Or it is in a very cold environment. The "fuser" that provides the heat required to "glue" the toner to the paper may be defective, or the connections to it's controller or the controller is defective. Temporary solution may be to leave it "on" overnight to keep it as warm as it gets in the afternoon. Will take more electricity. But eventually it will need to be repaired, or replaced with a lightly used equivelent. It may be less costly than repair.
May 07, 2015 | Minolta Office Equipment & Supplies
C0f30 error minolta photo copy
When was the last time the developer was replaced in the developer unit? If it has been replaced then you might have a bad ATDC (Automatic Toner Density Control) sensor Located right below the developer unit. If the developer was replaced when it was done was a vacuum cleaner used? IF so the static electricity from the vacuum clear destroyed the sensor, NEVER USE a VACUUM cleaner to remove the developer. Also when the developer was replaced, was counter cleared to tell the copier developer was replaced, the copier use the counters to determine certain voltages for certain assemblies, if not image problems and codes can appear. Finally was the F8 run after the developer was installed before any prints or copies made? If not buy new developer and start over, counter is to be cleared first, then developer replaced, then F8 run.
Sep 29, 2014 | Konica Minolta Minolta Ep4000/ep5000...
Book Maintenance Copiers Konica Minolta cspro ep300
Exposure lamp the bright light under the big glass is burned out, try reset, by opening front door look to your upper left small access plate remove it this must be done with machine on. press the reset button if the code goes away OK. If not replace the exposure lamp if you can find one a very very legacy Minolta machine!
Nov 27, 2013 | Konica Minolta 1149-0291-01 Minolta Cs Pro...
What is Error C0110 for ep 4000/5000 cs pro
Could not find that code in the service manual how about C0000 or c-0010
Apr 18, 2012 | Minolta Office Equipment & Supplies
Here is the hostname cspro minolta ep 4000 error code c 0200 how can I do to do to solve this problem thank you for helping me and thank you for your assistance
Below the drum is assy. that houses two very fine gold plated wires that do two things since the paper goes between these two wires and the drum the first is transfers the image on to the paper from the drum, the second one prevent the paper from sticking to the drum. One is or both are bad, BROKEN? Remove the assy. and replace both. They are very fine and fragile do not lose the springs. If that does not work you might have bad ends on the assy. after a while the plastic breakdowns and allow the voltage to go to ground. The wire carry around 2000 volts during the copy process. None during power off :) Open close the front door resets the code.
Mar 07, 2011 | Minolta EP4000/5000 CS/PRO Copier
Máy photo minolta cspro ep
what is the problem? sir/mam
Jan 06, 2011 | Minolta EP4000/5000 CS/PRO Copier
How do i install my CSPRO 4000 printer to my computer?
The EP4000 is a Minolta analog copier. it has no computer connection.
Jul 02, 2009 | Minolta EP1083 CS/PRO Copier
Error code c0f30
SOLUTION: Check the amount of toner in the affected unit and if empty, check the alignment of the toner sensor actuator arm. It is possible that the arms may have been jarred out of alignment during shipment and fail to sense the low/empty toner condition. This in turn, causes the IU to drop below the proper toner-to-developer ratio resulting in C-0F3x codes. Once the actuator has been properly positioned, run ATDC toner supply until the T/D ratio comes back into the specified range.
hope that help
or try to reset the machine.........
Aug 06, 2008 | Minolta CF2001 Copier
41 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
