Question about Cooktops
How to change centre hob trim on rangemaster110
Why dko all 4 hobs show L?
Gas or electric? What caused the change? My guess is the knobs were removed for cleaning and not reinstalled properly. There is a flat on the valve stem that must match the flat on the Knob when installed.
Jun 07, 2015 | Cooktops
Induction hob neff T4243 has cracked will I need to replace it
Did you crack your hob by means of impact or did it happen on its own accord?
I have a neff induction hob and has just cracked in 3 directions while cooking this evening. I am just trying to determine if there is a common fault with this neff product or I am just unfortunate. Mine is under warranty and have a engineer coming on Monday, so have the whole weekend with no hob as I have been advised not to use it.
Many thanks
Feb 28, 2012 | Cooktops
Glass on neff t4243 induction hob has cracked
hi,
is it possible to replace a cracked glass on my Neff induction hob?
where would I get the glass for my Neff induction hob replaced?
is it very costly?
the model number is t4483x2/09
The top of my halogen hob has cracked from top to bottom thro the centre is there any way of repairing it? it is a 5 ring creda rangemaster
you cant repair the glass but you can get the ceramic glass as a spare part. you will need the exact model number to get the correct part once done your hob looks brand new. if cracked through one of the zones you could chack there is no damage to element or themal cutout running across the centre of the element before proceeding.
Aug 22, 2010 | Cooktops
Miele KM 342 - I have burner - will ignite when knob pushed in but once release knob flame goes out
Hi dear.According to you're explanation,there is flame failure safety device in each hob.Please check the hob,there is one ignition plug & one prob next to each other.Please clean them up with hard brush to get rid of the cleaning chemicals(Like: CIF)residue.It's a sensitive prob becareful when you do this.Please make sure it sees the flame.As long as it feels the heat it'll let hob to run.If that's not work,you may need to change it.Please do this if you know what you're doing,other wise call service department.I hope that helps.Thanks.
Aug 07, 2010 | Miele 36 in. KM342 Gas Cooktop
Black hob top cracked in two places and small part
yes but costly.have u tryed home insurance accidental damage.
Sep 14, 2009 | Cooktops
Fagor hob touch control
Our hob has the same problem. I would really like to know the reason for this! Try using a rubber eraser instead of your finger - this works every time with our hob. Covering Up and Down arrows with the rubber, zeros it instantly just like using both fingers. Hope this helps.
Jan 28, 2009 | Fagor 31 in. VFA-78S Electric Cooktop
Hob not working
replace the hob. the f1 error is not sensing a temp change and if the burner is broke it wont sense it.
Dec 05, 2008 | Cooktops
Cooktops Logo
76 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
