Question about Refrigerators
How do you remove the freezer drawer on a Kenmoe refridgerator model number 795.72022.110? Its a double door up top with freezer on the bottom.
  • 3 Answers
SOURCE: sub-zero 550 reefridgerator top freezer bottom - refridgerator door not staying closed
Just a guess, but I would check the gasket on the door. They can go bad or get distorted and bunch up and cause the door to bind and not close properly. Also check that the fridge is leveled properly. Will the door close if pushed? Will it stay closed?
Posted on Jan 06, 2008
  • 370 Answers
SOURCE: Kenmore fridge and freezer not cooling
Check to see if there is any ice built up on the back wall of the freezer. If so thaw the ice and take the back wall out of the freezer. next check to see if the fan is running in the freezer (evaporator fan) This fan is what circulates the air from the freezer to the fridge. If it does run then you have a defrost problem (if ice is on the coils and back wall). Then replace defrost timer, heater, and thermostat.
Posted on Nov 20, 2008
  • 331 Answers
SOURCE: I have a ge french door refrigerator with two
Hi Laura,
The repair guy did what any repair guy would have done under a warranty situation such as yours... door gaskets. I presume he explained why he was doing what did ("why's" are important, ya know...). If he didn't, let me run through it real quick, OK?
Warm air holds moisture and cold air doesn't... that it in a nutshell. But what's important to note is that if there is an air leak inside your freezer you'll notice it just as you have, with condensation forming. This tells the repair guy that cold air is escaping and warm air is entering the freezer. The first place to look is the door gasket and that's why he replaced it. But now you know it wasn't the gasket, right?
So the repair guy didn't find the source of the air leak. It happens. The reason is that most "factory" tech's are trained on the fly and have the habit of not looking too deep into a problem 'cause they're warranty guys. They get paid whether or NOT a problem was fixed. See? Independent repair guys like me only get paid WHEN the job is fixed. So there's a GREAT incentive for me to get it right the first time, right? (I'm not "bashing" them. I'm just clarifying that warranty repairs are hit and miss at best.)
The thing you gotta think about is "How many places are there for cold air to escape and warm air to enter?" The answer to that question is "4". Yep. FOUR places that this can happen and each of them have to be inspected for evidence of moisture. They are;
1.) Behind the fridge where the ice maker water tube is inserted through the cabinet and into the freezer.
2.) Behind the fridge where the wire bundle enters the freezer compartment.
3.) Behind the fridge in the compresser compartment where the evaporator drain comes OUT of the freezer compartment.
4.) The door gasket.
Since your unit is still under warranty I certainly wouldn't expect you to chase these down for yourself. You should call GE again and have the repair guy come do this for you (print this out so you will have the above checklist). This is to protect your warranty, by the way. If you (or an appliance repair company NOT authorized to work on it) work on it, you run the risk of voiding the warranty altogether.
There's a product on the market called "PermaGum" (here's a link). It's used to seal air leaks such as this. When you talk to GE, try to insist that the tech have some on his truck when he arrives... I have the feeling that he'll need it because I suspect a leak is occurring in one of the top 3 areas I mentioned above (either that, or he didn't install the door gasket correctly in the first place).
As an aside? Just a tip/hint... I know that your fridge is new and all, but to KEEP the door gaskets like new for (almost) ever, use Vaseline on them. Yep, Vaseline. Open the fridge door, dab your finger into the Vaseline and smear a light (light) coat of it on the door gaskets all the way around. This will do 2 things;
1.) It'll keep the door gaskets from ever drying out.
2.) It'll provide a very good and air-tight seal when the door is closed. (air leak, Laura?)
There ya go! I hope this has helped you in your quest to rid you freezer of pesky condensation. If so, please remember to rate this as "It fixed my problem", OK? After that, you can mix up a Mojito and bask in the knowledge that you are a completely informed consumer when the GE guy gets there to finally fix your fridge.
Take care,
Posted on May 07, 2009
  • 4070 Answers
SOURCE: Water is pooling in the bottom of the freezer
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer
Posted on Nov 16, 2009
Testimonial: "THANKS... it's all defrosted and cleaned out and will wait to see what it does tomorrow after it's all back up and running again !! Thanks !"
  • 2694 Answers
SOURCE: I can't remove the freezer drawers from my Whirlpool Gold Model # GI5FVAXVB02. Called the company and they couldn't help me.
you have a blocked drain,try this,pull out the machine,unplug it,remove the bottom panel,lie on the floor and with a light look up or feel around,there's a nipple that's there that the water drains out of or drips through,i've been removing the nipple,running it under water to clean it,but it has to go back,if you don't put it back you'll have problems,this keeps the warm air from getting into the freezer,before you put it back on get a hair dryer and melt out the ice,just heat up the back freezer wall and then pour hot water down through the back wall,if the water drains out you don't have to take the freezer draws and racks out,they changed them all around and i can't explain how to do it and if you pull it out and don't line the two wheels up correctly the door won't close right,i mark them with a marker before i pull them out,it sucks to do and is very ridiculous,you need a manual just to remove these parts,if this doesn't have a nipple on it and has a drain hose there you can try to clean it out from that end,you can get a piece of 1/4 in water line like they use for the water lines on the fridge,buy a piece and snake it up through the drain hose and then blow through it then flush water through the back inside freezer wall,slime builds up in the drain hose on all machines so once it's freed up it will drain,you might think that if you go from the back you'll push it up into the freezer and it will happen again it won't,once you hit it and free it up it will break apart and every time the machine defrosts the water will wash any parts that is still in there out.i'll try to see if i can find any videos on line for you to show how to remove the shelves and racks and then to line them up again but try going from the back first.good luck.
Posted on Aug 10, 2012
How do I get the doors off for moving
Hello Anita;
My name is Peter. I am a retired field service refrigeration.
I would be more than happy to tell you how to get the doors off.
I need you to provide me with a model number. There are top freezers, side X side, bottom freezers & drawer freezers. Removal of the doors is different depending on what you have.
Resubmit your question with the model number. The model number is on a sticker on the liner wall of your fresh food section
Nov 08, 2014 | Refrigerators
Removing samsung freezer drawers
There are 3 bolts that hold the bottom of the freezer door in place, if you remove them the door will fall to the floor then youmcan pull it off then you can access the drawer
Sep 07, 2012 | Samsung RFG237AARS Bottom Freezer French...
Top oven glass in door is broken (thermadore).
Your oven model number is usually located on the rim of one of the oven doors or on the frame oaround a door. Some ranges with bottom drawers have the model number on the frame behind the drawer.
Here is a tip that I wrote about replaceing your glass....
Mar 31, 2010 | Thermador C302U Electric Double Oven
Kenmore refrigerator with bottom freezer. freezer works,refrig does not. Can you help me find the problem .Also, bar between the upper doors gets real hot.
I had this problem. The Evaporator fan in the freezer was working but no air would be circulated from the freezer into the refridgerator. To test this you open the door of the freezer, and depress the door button(s) of the upper refridgerator doors so that the light extinqueshes in the refridgerator. This will engage the evaporator fan in the freezer. You can check to see if air is venting from the freezer into the refridgerator by feeling the holes at the top most part of the multi-air flow channel in the refridgerator. If air is comming out when the freezer door is open, close the freezer door and feel if air has stopped. If you have kept the upper door buttons pushed in on the refridgerator and now have the freezer door closed, you should still hear the fan running, but may have not air flow with the freezer door closed. The cause of this is the air return channel from the refridgerator to the freezer is either frozen or clogged. My return-air channel was not frozen but clogged by a residue from something that spilled inside of the bottom of the refridgerator. The return-air channel has two vents in the rear-bottom of the refridgerator that exit into the freezer behind the evaporator (cooling coils). You can't see it even if the back interior panel is removed from the freezer compartment.
The bottom line here is that if air is prevented from moving from the refridgerator, back down to the freezer, then your refridgerator will not cool, but your freezer will work just fine. You will not need to replace the fan, unless the fan is not functioning. You may need to check the dampener, to ensure that your multi-air flow channel is open - (allowing air to come into the refridgerator). The multi-air flow channel is easy to remove once all of the shelves are removed from your refridgerator. Only 2 screws holding it in (securing the center rack top and bottom). The top screw is located behind a small plastic cover that can be removed.
That's what worked for me.
Jan 12, 2010 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Frezeeer works fine. Refridgerator (top) does not
good morning,
with this unit there are two issues that could be cusing this...
check to make sure you can hear the fan in the freezer,
2nd check your back wall for frost, sometimes this model ices up in the air chanels, to know for sure you will have to remove both the walls and the back wall, it takes a lil time but it can be done with only a screwdriver,
once you get the back wall off look up in the corners, of the freezer, it there is frost or ice blocks , remove those and reassemble you should be ok
make sure the drawer is closing properly
Oct 23, 2009 | Amana ABB1927DE Bottom Freezer...
Whirlpool refridgerator-model#ETICHMXKOO4-We have
There is ice buildup in the drain and maybe under the seperator. Remove the back panel in the freezer and the botom floor of the freezer and remove the ice. Be careful of the styrofoam ducts. Eric
Aug 10, 2009 | Whirlpool Refrigerators
Tenants have broken every door shelf rack
For the GE refridgerator, the model GTS22 is an incomplete model number. That is actually the series number. Your actual model should be followed by 5-7 more letters, as in GTS22FBPBRWW. The full model number denotes dates, dimension, color, etc. You can find the full model number in one of two places:
A) Upper front left corner of the food compartment
B) Left side of the crisper pan on the food liner (with storage drawer open).
Once you find the correct model number, it is important to decide exactly which parts you need. Each door shelf comes in 3 pieces. You have two end caps (left and right) and then the front piece. For the bottom shelf, the end caps are different than the caps for the top and middle shelf. Also, do you need the dairy door and the butter dish? A schematic drawing can be most helpful.
When you know which parts you need, you can go online to or call toll-free 866-925-PART (7278).
Apr 07, 2009 | GE GTS22 21.8 Cu. Ft. Top-Freezer...
Water on the bottom shelf of the Refridgerator
Has the refrigerator got a wet inner back?
Ff this is wet, adjust it until this solid ice 'blobs', bt not encrusted, like in a freezer
The refrigerator may not be cool enough and the natural warm moisture allowed into the cool compartment when the door is open is condensing into fluid before it is cooling sufficiently to suspend the moisture as a vapour. If the cool compartment is cool enough, any warm air admitted ill be chilled before it is allowed to condense, keeping the refridgerator dry.
However, the only drawback is that you will have to monitor it to prevent the build up of excesive ice.
Also, whether the refridgerator is either empty of full willaffe the day to day operation.
Hope this helps.
Oct 20, 2008 | Whirlpool ET1FHTXM Top Freezer...
Sub-zero 550 reefridgerator top freezer bottom - refridgerator door not staying closed
Dec 25, 2007 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
