Question about Taco Hardware & Accessories
What is taco error - Taco Hardware & Accessories
Need to replace a taco zone valve head
Should be able to swap them., or get a qualified tech. to do it.
Mar 04, 2014 | Taco 3/4" Gold Series Zone Valve 571
My Taco 006 circulation pump quit working. It make a vibrating noise and does not pump. I just bought it a year ago. Can you help.?
Usually when these motors slow down, they get hot and burn out.
You can try taking it off and cleaning with CLR, but normally when they stop working, they do not revive.
I am not sure what the warranty policy is from Taco, or if Taco has a parts list.
I think following link takes you to the Taco website:
You can contact them for warranty/parts information
Link below has information on recirculation systems with links to manuals and competitive products
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on pump/timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 10, 2011 | Taco 1/2" 006 BC4-TAC Circulator Pump/...
Diagram for a Taco 572
We were able to find some instruction sheets, including wiring diagrams for the Taco 555-573 series zone valves on the Taco website:
Hope this helps,
Oct 19, 2010 | Heating & Cooling
I bought a new house and the water heater has a circulating pump with a Taco 265 timer. No instruction manual so I can't figure out how to set the timer. You wouldn't happen to have a little instruction...
Maim website:
Main website Search for Taco 265-1 gives link to manuals:
Direct link to pdf manual:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Instructions show series of actions to set digital program
Press h key ...
Press m key...
Press Day key...
Press Prog. key to enter...
Sep 10, 2010 | Taco 265-1 / 563-2 Combination Analog 24...
Taco timers and Surge Protectors
Do they run at the same time? The two items consume
a lot of power. Check the voltage when they are turned on. If the voltage is below 90 Volts. The power surge at your Taco is great. Then, the surge protector could not
handle the current inrush that's why it's blown off. You
must install a surge protector that can handle the Taco
current inrush.
Sep 06, 2009 | Plumbing
Hardware & Accessories Logo
89 people viewed this question
Top Taco Hardware & Accessories Experts
deton8 von Splosion
Gene Haynes
Are you a Taco Hardware and Accessory Expert? Answer questions, earn points and help others
