Question about Hobart Dishwashers
Have a am15 vlt hobart dish machine .first issue was the fill solenoid would stay open .hobart said replace board replaced board and now it shows pd but will run its cycle at the end an e 1 code shows
  • 58 Answers
SOURCE: DD603 2 Drawer Flashing Fill Warning
poss water valve b4 i would consider a control
Posted on Mar 12, 2008
murdozzz2
  • 75 Answers
SOURCE: LXIH, ML #130017
hi there have you checked that the drain pump is pumping out the water fast ehough, sounds like you may have a blockage problem and the programe is timeing out ie. not draining within the specified time, for example 3 mins
Posted on May 02, 2008
  • 49 Answers
SOURCE: Programming the 00-749825 Control Board on a Hobart AM14C
That board comes with directions. if not go to hobart and have them copy you one out of a new boards box
Posted on Sep 30, 2008
bigg t
  • 640 Answers
SOURCE: what is p3 code on hobart am15 dishwasher
It means that the final rinse thermistor is bad.Your not getting 180 degrees---right?Its located on the booster and costs about $65.I work for hobart.Any ?
Posted on Jan 25, 2009
PapaSmurerf
  • 3 Answers
SOURCE: Bosch dishwasher cycle doesn't end
Try this link, http://www.applianceaid.com/boschDW.html for procedures for running self-tests on various Bosch models using the front door switches. Find your model and read and follow the procedure.
This remaining at '1' problem invariably relates to a 'heater fault' which has usually been traced to an open solder joint on the control board located behind the switches/indicator lights on front door. See pic here of open solder joint http://www.flickr.com/photos/zenzoidman/145089572/ In most cases, the heating element has not been at fault.
I got mine going again by resoldering the joint and saved ~$300 in parts & labour. If this is beyond your skill set, then replace the control board assembly, 266746, which is used on multiple Bosch models. See this page for more information if you want to try to DIY. http://www.appliancejournal.com/appliance-parts/bosch-appliance-parts/bosch-dishwasher-control-module-266746-37/
If this is still beyond your skill set, then call a tech & supply the Bosch model, serial number, and the results of the self-tests.
Posted on Mar 01, 2009
Water continues coming
Hobart ' Undercounter Dishwashers, Commercial ...
www.hobartcorp.com/.../commercial.../undercounters...
Hobart CorporationGlasswasher ... The LXe undercounter is ENERGY STAR® qualified, uses only .74 gallons of water per cycle and features new Smart Display technology to eliminate error codes. Loading... Highlights: Hobart undercounter dish machines are the most popular in the industry, keeping reputations spotless all over the world.
Advansys LXe Undercounter ' Hobart
Hobart CorporationGlasswasher ... The Hobart LXe Undercounter Dishwasher is designed to pack best-in-class cleaning power into a compact space, ... The Advansys LXe low-temp model features PuriRinse, a cold-water rinse that removes chemical residue, ...
[PDF]AM15 Technical Manual - Hobart
https://my.hobartcorp.com/kroger/.../AM15%20Technical%20Manual.pd...
Steam Booster, if used based on 20 PSI steam - 20 PSI water flowing. 130°F entering.... DRAIN AND OVERFLOW: Large bell type automatic overflow and drain ...
[PDF]Glass- and dishwashers - Hobart
Dec 08, 2015 | Hobart Undercounter Glasswasher w/Chemical...
Hobart am15 scrolls message drain and de-lime with a constant beeping??
It may have reached the number of cycles to trigger a delime warning. Either follow the procedure in your operator manual to delime, or go into the control board settings and either change or turn off the delime timer
Dec 04, 2013 | Hobart 29 in. AM15-1 Free-Standing...
Can i use a tankless hw heater to supply my hobart am15 dishmachine
Don't install tankless, because repairs, installation, operation, maintenance, replacement etc are expensive.
And the thing can be unreliable since you are connecting a computer chip and sensors to gas line, water line, electric line, and to a gas burner with vent to outdoors ... and each of these systems has problems on its own without a computer chip that can fail at the first electrical surge.
Otherwise call Rinni for specs.
1-800-621-9419
Ask about the 4 year warranty for residential installation.
Ask about deliming each year.
Ask about exposure to hard water, and water impurities, and water problems. Tankless cannot be exposed to more than 11 grains hardness.
Ask about recommended yearly maintenance requirement.
Ask why there are no service manuals, and how technicians know how to fix the thing without detailed service manuals.
Call around locally and see who services the thing, and ask if there are service problems.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 07, 2013 | Hobart Commercial Equipment Ventless Dish...
My hobart dishwasher am 14c will not go into cycle
Check the Door switch. If the screen shows FILL but don´t do it, check all fuses on control board.
Apr 09, 2010 | Hobart 29 in. AM15-1 Free-Standing...
No rinse cycle
If it is new, would you not call Hobart for a warranty call? 1-800-444-4764 to reach the nearest branch in Canada.
Seeing it's new it is most probably not programmed correctly. On the control board is factory jumper J5, short thse two pins and press ON on keyboard. when the display shows ty remove short. pressing select on the CB will change the options, pressing up arrow will incriment the change options. first setting is machine type= AS,second is id, hot/cold or plain AM15 only, select H,C,or P.
3rd is tc,auto temp control. The rest will not affect your condition. Press OFF on keyboard to save and exit.
Jul 03, 2009 | Hobart 29 in. AM15-1 Free-Standing...
HOBART AM15 DISH WASHER ERROR(E1)
After checking the service manual, I find no code for E1. There is a P1, or other E codes. Please list ML number.
Jun 14, 2009 | Hobart 29 in. AM15-1 Free-Standing...
What is p3 code on hobart am15 dishwasher
Jan 08, 2009 | Hobart 29 in. AM15-1 Free-Standing...
Error code E2 (with a picture of a wrench)
E2 means a problem with the fill. The wrench means to contact Hobart for service
Feb 27, 2008 | Hobart 29 in. AM15-1 Free-Standing...
Dishwashers Logo
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
