Question about Whirlpool Refrigerators
How to level whirlpool fridge - Whirlpool Refrigerators
Fridge door not staying shut and dropping
Debbie, do you have your fridge leveled correctly. fridge should tilt back slightly to close the door.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://products.geappliances.com/appliance/gea-support-search-content?contentId=19144
How to Level the Refrigerator
http://www.lg.com/us/support/product-help/CT10000021-1396987943023-leveling
How To Level Whirlpool Refrigerator
May 27, 2016 | Max-Fridge Refrigerators
MY WHIRLPOOL WB360ME DOES NOT COOL
several things to look at,. the thermistors in fridge and freezer, the cold control thermostat, the freon level, the air damper flow control knob. is it closed all the way? is the fan running?
Mar 21, 2015 | Whirlpool Refrigerators
How do i level the fridge?
Use a simple spirit level to incline the fridge a little to the rear as the flow of water to the drain tank and also for the door to close by itself.
There are two adjusters on the front legs and this can be turned up or down as your requirement .
so looking at the spirit level the fridge level can be set and tilted slightly.
Sep 02, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
I think I have a water problem? I hear a clunking noise at various times from I think the right bottom of the unit. Water and Ice seem to be working fine.
Hi.
The clunking noise is the compressor. It usually means that one of the internal mounts that secure the compressor motor is gone. The whole compressor needs replacement.
First ensure that the fridge is at level. A not well leveled unit's compressor can make noise.
If fridge level is OK, call the Whirlpool customer service number listed on manual. The compressor has a long warranty. If the fridge is the one in question you may still be covered for the part.
Regards.
Ginko.
Mar 23, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Won't get cold
Check the refrigerant level.If the level is less then there will be no cooling effect in the fridge.Always maintain the level to keep it efficient.
Thank You
Sep 06, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Doors need levelled - motor runs very loudly but is silent when fridge door is opend - Can you send instructions as to how to level the doors?
the door leveling is controlled by the front legs on the bottom of the frige. make sure the frige is level first.
Oct 29, 2009 | Whirlpool GS5SHAXN Side by Side...
My fridge is not getting cold
low gas level in the system
Oct 16, 2009 | Whirlpool Refrigerators
Whirlpool fridge incessant buzzing
The knocking noise when cuts off , is a compressor internal motor support spring , broken . This does not mean the compressor is bad , only noisy for the rest of the compressor life , but should be covered under the 5 yr warranty . The gurgling sound is the refrigerant being pumped thru the system . The buzzing could be from the compressor also . My suggestion , would be to call a factory warranty company , to see if they can replace the compressor under warranty .
Sep 07, 2009 | Refrigerators
Water is dripping into the refrigerator from the freezer - I have a Whirlpool ET18UMXSW0
There is a drain line from the freezer to a pan beneath the refrigerator. If clogged will result in water escaping into the fridge. Water in fridge can also result if the box is not level, with the top tipping away from the wall. If the box is not chilling properly, then you have another problem with the defrost system.
Jul 12, 2009 | Whirlpool Refrigerators
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
