Question about Jet Plumbing
My shallow well jet pump starts and stops regardless of whether water is running or not.The pump is only been in service for a couple of weeks. I did just install a filter.What could be the problem.
  • Renee Knafel-Bullock
    Renee Knafel-Bullock Apr 28, 2017
    your pressure valve is not the right psi setting or you have a pressure leak somewhere, probably a line, tighten it at the pump, or perhaps the water is leaking at the pump making it click on better check it out especially if its in the crawlspace could be flooding very slowly, but more than likely you have a leak of air somewhere in the line, like a drip somewhere outside faucet perhaps somewhere it is, also go to the turn vales that supply the water to the house and close them off and then run all the water from the lines from the farthest point in your house to the well the farthest away in other words oh and throw the breaker too after then when the lines are empty throw the breaker on first before turning on the flow valves, but of course don't wait too long see if the pump brings pressure to the house valves that supply check for leaks from the well pump to the supply valves, once the pressure is brought to the main supply its easier to see where the problem is.
    also atleast a gauge of 60psi is needed at the pressure tank too, the gauge could be leaking the pressure they are only 5 bucks know what you are doing before doing this gauge hope this helps
    Sergeant:
  • 278 Answers
Your pressure valve is not the right psi setting or you have a pressure leak somewhere, probably a line, tighten it at the pump, or perhaps the water is leaking at the pump making it click on better check it out especially if its in the crawlspace could be flooding very slowly, but more than likely you have a leak of air somewhere in the line, like a drip somewhere outside faucet perhaps somewhere it is, also go to the turn vales that supply the water to the house and close them off and then run all the water from the lines from the farthest point in your house to the well the farthest away in other words oh and throw the breaker too after then when the lines are empty throw the breaker on first before turning on the flow valves, but of course don't wait too long see if the pump brings pressure to the house valves that supply check for leaks from the well pump to the supply valves, once the pressure is brought to the main supply its easier to see where the problem is.Renee Knafel-Bullock Apr 28, 2017 Edit Delete
Posted on Apr 28, 2017
    Master:
  • 604 Answers
It is losing prime,air is getting into the system tighten all clamps if it continues,defective pump
Our goulds pumps j5s is running very loud after we replaced our sewage ejection pump last week. Could these problems be connected?
Those pumps last a long time. I do not think the problems are connected. I am assuming you are pumping water up from the pump. The pump has a check valve in the discharge that may not be closing. Cleaning that should solve your problem. Be sure water will pass through the discharge line into the drain.
Feb 05, 2014 | Goulds Pumps Goulds J5S Jet Pump Shallow...
Shallow water pump keeps stopping
new pump --not big enough for the job
old pump --motor windings problem, faulty start run capacitor
I suspect that as the motor is 1/2 hp if will run good when there is a need for water but under pressure the pressure switch is set to high so the motor overloads and gets hot
Mar 24, 2017 | RTO Wayne 1/2 Hp Shallow Well Jet Pump
3/4hp pump stalls before finally starting on 5th or 6th try.
Sounds to be a need for a new start capacitor. Have an electrician come out and chk it out.Good luck -ned-
Sep 16, 2009 | Flotec Corrosion Resistant Shallow Well...
Pump stopped working while pumping
Yes, most motors are thermally protected. It is usually bi-metallic, and resets itself.
--W/D--
Aug 08, 2009 | Flotec Corrosion Resistant Shallow Well...
Plumbing Logo
41 people viewed this question
Top Jet Plumbing Experts
Lawrence Oravetz
bobalix
Are you a Jet Plumbing Expert? Answer questions, earn points and help others
