Question about Samsung Washing Machines
Samsung washing machine main controller board model sw55v3
hondo73162
  • 132 Answers
SOURCE: I have a GE washing machine model #WWSE5240GWW the
have you checked the belt, it could be loose or broke
Posted on Oct 28, 2009
beltronic205
  • 1474 Answers
SOURCE: washing machine stopped mid cycle there is no
Could be mains switch/ Door interlock dead?..If you have multimeter you can easy check..
Posted on Nov 12, 2009
  • 343 Answers
SOURCE: main circuit board faulty
SE is 'sensor error' This could be anything from a loose wire to a faulty Hall sensor or even a main board failure......You probably need an LG technician. Your machine sounds like it's worth repairing.. Get quotes.........Good luck...Nomess
Posted on Jun 02, 2010
Testimonial: "thanks so much for your help"
KevinWhite
  • 1902 Answers
SOURCE: Simpson esprit650 Washing Machine. Main
Hello & Welcome to FixYa
Please click here if you want to buy this part. Please get back to me if you have any other questions.
Kevin
Posted on Mar 08, 2011
  • 6277 Answers
SOURCE: need a new main control board for a XQJ85E top
Sorry but this Forum does not supply parts, part numbers, prices or other details direct; it's just made up of ordinary guys and gals, probably at home, from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
Spares Suppliers
You will need to type into your search engine/web browser '(make model number) washer spares' and you should be presented with a number of sources from which you can order. Alternately you could try telephone directories for spares suppliers but I would think the former would be more successful.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Jun 07, 2011
My Samsung DC68-20425B washing machine motherboard is faulty. Pls I need where I can get it.
$70 from a place like Repair Clinic/ Make sure you have the right model. I wonder what diagnostics brought you to the conclusion you need a new main board?
Samsung Washing Machine Circuit Board Timer Parts
Samsung DC68 20425B washing machine motherboard Google Search
Feb 02, 2018 | Samsung Washing Machines
Model wf361. What is causing e3 error?
e3. Drive motor tach fault. This means that the tachometer is not regitering any motor movement when it should. Main reasons for samsung: motor control board fault. Tachometer fault. Motor fault. Also check wireing from motor control board to motor. But this issue is not common at all with samsung.
Feb 15, 2016 | Samsung Washing Machines
What is the meaning of 4Eerror code in samsung SW55V3 washing machine
When the pump keeps running, you have a 'slow drain problem'. The machine knows it should empty in a certain amount of time. If it doesn't it runs the pump all the time. You can usually reset it by just unplugging it and counting to 10 before reconnecting.
It is usually caused by blockages in the filter or in the pump itself.
http://landersappliance.com/Blog/ArtMID/1641/ArticleID/43/Samsung-Washer-Service-Problem---slow-draining
and this video.
How to Diagnose Washing Machine Drain and Pump Problems
Jan 09, 2016 | Samsung Washing Machines
Samsung touch screen washing machine does not display anything
the processors power supply has prob failed
can you post the exact model so we can look up the manual
and further confirm the issue
however sounds like the controller board moreover the main mpu psu has issue or similar its not a simple hose etc fault this
Mar 05, 2015 | Samsung Washing Machines
Samsung b1445v front load washing machine will not pass prog. 8 even when empty, then code ue
This is an error caused by the cycle advance which acts like a timer. The main control board can cause this issue. Diagnostic testing will need to be performed to determine the cause of this problem
Jun 05, 2012 | Samsung Washing Machines
Samsung washer machine error code dE
DE indicates a door lock error.
Either the door lock, wiring or main control board can cause this fault. The door lock is relatively inexpensive so it would be worth trying a new door lock first.
Check the wiring between the door lock and the control board. If a new door lock doesn't fix it and the wiring is ok you are only left with the control board.
Hope this helps.
Jul 14, 2011 | Samsung Washing Machines
No power Samsung WA8Ou3 washing machine
Possible that the main controller board is faulty if there is power supply to the unit. You can use a multimeter to check this out to confirm. Sometimes the power supply to the board can be faulty resulting in total failure of the board.
Feb 25, 2011 | Samsung Washing Machines
Washing Machines Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
