The lcd/led tv backlights are 3 volts each,so I wanted to know if you can use a 9 volt battery to test three of them at one time?
  • 16 Answers
SOURCE: 24 volt charging problems .2
A 12 volt battery is actually 13.2 volts fully charged. If you are reading 16 volts, you are probably getting extranious voltage from the system somewhere, especially if the vehicle is running when you check the voltage. The alternator will put out about 15-18 volts to charge the battery normally, and yours may put out 28-32 volts to charge them in series, but the batteries, when disconnected, should never read more than about 13.2 volts each. Typically, it will read about 12 1/2 volts when disconnected. COMPLETELY DISCONNECT BOTH OF THE BATTERIES. If you still read 16 volts when it is disconnected, you must have a bad meter because the battery can't produce that much voltage, no matter what. (Six 2.2 volt cells connected in series inside the case.) Put the meter on a known good battery on another car that is not running and see if you get the same reading. It sounds like the other battery is almost dead, regardless, and it sounds like your series/parallel switch may be malfunctioning. (That is the switch that puts the battery in series to run the 24 volt starter, then puts the batteries in parallel to run the remainder of the vehicle on 12 volts. This is all assuming that you have a diesel vehicle with a 24 volt starter and that is why you have two batteries.
Posted on Aug 19, 2008
SOURCE: No Start. OBDii Code P2305.
i have the same problem could someone please help ? its getting cold outside and i live 30 miles from my job.
Posted on Oct 27, 2008
  • 4 Answers
SOURCE: Low voltage output from inverter
I am thinking this a high impediance device problem and this is normal operation - the user manual of my inverter warns about use with high impediance devices - if not I am interested also...
Posted on Mar 03, 2009
SOURCE: will umc tv run on 12 volt battery?
yes you can plug this set straight onto a twelve volt battery it is designed for that purpose ie the motor home and campervan market ,i own one of these sets ,it is the best portable tvdvd ive seen so far ,hope this helps your query.
Posted on Jul 15, 2009
SOURCE: need to replace the 9 volt battery in my kenmore freezer chest.
The manual does not tell you where its at but the 9-volt battery holder is located on the lower left side of the freezer. There is a small panel about 9" off the floor and towards the front of the freezer (left side facing). cd6fa25d-9930-4b53-8883-c0ebcde8413d1.03.01
Posted on Sep 12, 2010
My Hisense TV doesn't work
If my memory serves me right 3 is no PMW signal from the main to the PS board, you can test that voltage and see if its around 3 volts
Jan 23, 2018 | Hisense Televison & Video
How do I determine if the problem with my LG TV is the LED power supply or the actual LED strips if when powered on, they flash and go black and the FlashLight test shows darkened images on the Screen
Chances are if it briefly comes on the backlights I mean the power board is shutting off because of over voltage or over current and some lamps are bad...On this set of yours if you try to test the strips you need to take into consideration these are 6 volt lamps not 3 volt that are used on most sets.
Dec 15, 2017 | LG Televison & Video
Can you use one 9 volt battery to test 3 lcd/led backlights at a time,instead of two double A batteries?
Two AA batteries are 3 volts (1.5v per battery). A 9 v battery is 9 volts. You are going to burn out your LED lights.
Semper Fi,
Apr 27, 2017 | Computers & Internet
LED TV - replaced power board but still no backlight? LED backlights do not seem to work.
yes the led backlight for whatever reason is not functioning and that is the root cause of your problem. Unfortunately to find a replacement led backlight is tough as the backlight is normally fixed with the lcd panel and has to match the voltage and all that stuff with motherboard. and if that doesn't match you might short the tv itself. this case is as good as getting a replacement lcd panel.
Feb 17, 2016 | Seiki SE50FY10 50-Inch 1080p 60Hz LED HDTV...
There is sound but no picture. No backlights but can see a picture in dark with flashlight test. LED panel # is D460D3-6Y43-COX. What part would I need to purchase? T
You have check the power supply first .To know how to check the power supply watch the following video. Normally led tvs power supply contains the led drive circuit too. Bot are integrated in the same board. The led drives circuit should have between 30 to 120 volts from the power section depending up on the brand and model number of the TV. If the the voltage is ok then you have problem with the Led driver section section. Either you can try to repair it or can buy a new power board.
Testing LCD TV Power Supply BoardsSTEP BY STEP
Oct 31, 2015 | SEIKI Digital SE46FY10 46" LED TV...
How do I properly determine the power supply of a parallel circuit of LED lights? I have 30 LEDS to wire into a large model. I know the individual LEDS each run on a 3 Volt CR2016 watch battery. I
You can go from 2 aaa'a three two D's depending on how long you want the battery's to last or project size. Depending on LED model 98% don't matter on the amps just the voltage. I was using 2 D's so you would have about 24 - 36 hour straight on time.. But if you could afford 4 of them for testing. Run four in line so the voltage will be 12 volts total and hook it up to your car battery and you should/would have a light for 6 months to a year and the LEDS should be just fine.
Sep 18, 2014 | Cars & Trucks
LG shows it will lose display in 3 seconds
hi the tv has detected a fault with the back lighting, now it could be a problem with the voltage to the back light or some of the leds in the back light have failed, it will turn off the back light when it finds a fault. behind the screen there is rows of leds on strips and they all light up when the screen is in use. and the main board knows they are lighting up by the voltage its using. when to many leds go out the voltage is too high so it will turn the back lights off to save them. also the same if the power board is not supplying the right volts. say the volts need to light the back screen is 64 volts and its only giving 62 volts the power is not right so it shuts down. same for if the volts go up to 64.5 volts it will do the same. hope this helps you under stand.
Jun 11, 2017 | LG 47 47LV5500 47 LCD TV
Televison & Video Logo
Top Televison & Video Experts
