Question about Cell Phones
If I turn on aeroplane mode, will that stop roaming charges
    Master:
  • 923 Answers
Yes, I think so.
Posted on Apr 28, 2017
How do i turn off aeroplane mode?
hi there.
see if this helps you,if not go to the link at the bottom.
To work around this issue, follow these steps:
  1. Swipe in from the right edge of the screen, or press the Windows logo key+C.
  2. Tap or click Settings.
  3. Tap or click Change PC Settings.
  4. Tap or click Wireless.
  5. Tap or click an affected device to turn it on again.
How do turn off aeroplane mode Google Search
Nov 18, 2017 | Computers & Internet
Going to Canada. How to set my cell to avoid roaming, etc. charges?
Canada eh?
Two ways,
Set it to Airplane Mode, this turns off wifi and roaming
Go to Settings Carriers and turn off Roaming.
Have fun in our great country. :>)
Aug 27, 2017 | Cell Phones
My tablet wifi will not turn on i already try to hard reset it
has it got an aeroplane mode in the settings that might be on ?
or a manual switch that might put it in aeroplane mode.
Jun 15, 2016 | I-INC UniK Trio AXS 3G with Wifi 7.85"...
How do my mobile phone to on line it is showing off line ? and not woking as a phone?
try going to settings and either turning off your mobile data, or turning on aeroplane mode then after a coulple of minutes turn data on or aeroplane mode off
Oct 02, 2014 | Cell Phones
What to go in to find the airplane mode
Try FN + a button that looks like signal lines, the WiFi button basically, it should turn off aeroplane mode, I assume you're using Windows 8. You can also turn it off by pressing Windows Key + C at the same time to bring up the charms menu (the menu that appears on the right) press settings, click on the wireless section, turn off aeroplane mode at the top.
Mar 09, 2014 | HP Compaq Presario V6000T 15.4" Notebook...
How to turn off aeroplane mode
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Jul 27, 2012 | HTC Wildfire Cell Phone
8xx plantronics blue tooth will not stop beeping after a call. i powered off the blue tooth and beeps stops but returns after the first call
This issue may be caused by the network and not a defective headset. Changing your phone settings as listed below will in most cases stop the frequent ringing/beeping in your headset while in standby mode. You may want to check with your service provider before changing the settings listed below, as the following activity may cause additional charges on your phone bill. If you can, remove and re-install the phone battery. This should reboot the phone. Go into the MENU > SETTINGS > ROAM. Change roam setting to "ROAMING ONLY". Users will no longer get any Bluetooth headset rings/beeps unless the phone is actually ringing for an incoming call. This is a temporary work around since once the phone is turned off, the roaming setting above is reset. You will need to follow these steps each time you turn on your phone.
Good luck from Headsets Direct!
Apr 23, 2011 | Plantronics Voyager 835 Bluetooth Headset
My phone is saying digital roam mode when i make an outgoing call, how do i take it off so i can make outgoing call with no problem.
This is pretty much what you need to do. Just turn off all the roaming features. However when you roam it typically means you dont have service through Sprint so dont be surprised if when you turn off roaming capabilities your phone doesn't get ANY signal. Here's the link to your phones manual page 112 is about roaming.
Setting Roam Mode
Your phone allows you to control your roaming
capabilities. By using the Roaming menu option, you
can determine which signals your phone accepts.
Choose from two different settings on your phone to
control your roaming experience.
1. Press > Settings > More... > Roaming > Set Mode.
2. Highlight an option and press .
n Sprint Only to access only the Sprint network and
prevent roaming on other networks.
n Automatic to seek service on the Nationwide Sprint
Network. When Sprint service is unavailable, the
phone searches for an alternate service.
Call Guard
Your phone has two ways of alerting you when you are
roaming off the Nationwide Sprint Network: the
onscreen roaming icon and Call Guard. Call Guard
makes it easy to manage your roaming by requiring an
extra step before you can place or answer a roaming
call. (This additional step is not required when you make
or receive calls while on the Nationwide Sprint Network.)
To turn Call Guard on or off:
Call Guard.
2. Select On or Off.
To place roaming calls with Call Guard on:
1. From standby mode, dial 1 + area code + the
seven-digit number and press .
2. Read the message and press .
Note Call Guard is turned on by default on yourphone.
To answer incoming roaming calls with Call Guard on:
1. Press .
Data Roam Guard
Depending on service availability and roaming
agreements, yourphone may be able to access data
services while roaming on certain other networks. You
can set your phone to alert you when you are roaming
off the Nationwide Sprint Network and try to use data
services such as messaging.
To set your Data Roam Guard notification:
Data Roaming.
n Always Ask (default mode) sets your phone's Data
Roam Guard feature on. You will see a prompt that
will require you to respond anytime you access
data services while roaming.
n NeverAsk turns your phone's Data Roam Guard
feature off. Your phone will not notify you of your
roaming status when you access data services.
Touse data services when Data Roam Guard is active:
© When a notification appears informing you that data
roam charges may apply, press ROAM (left softkey)
to connect.
Note If the Call Guard feature is set to On, you need to
take extra steps to make and receive roaming calls.
Mar 08, 2011 | Sanyo SCP-2700 Cell Phone
IPhone does not connect to my mobile service provider.
I assume you have switched the aeroplane mode off again, (the reason for this function is to stop all network activity when you are on a plane)
If it is still not working after you switch the aeroplane mode off, go into settings/general and you will find a reset button at the bottom of the list.
Warning!.....you will lose all your contact info if you do this and possibly any applications you may have installed.
Sep 20, 2009 | Apple iPhone 3G
Cell Phones Logo
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
