Question about Exercise & Fitness
Sole e25 motor error when plugged in. What are some troubleshooting techniques I can use to figure out the problem?
Motor error on Sole E25 S/N 5250880912022408
Where do I find the serial number on my sole e35 elliptical? Thanks !
E35 - Copied from E25 answer - on the front of the machine, right under the display, on the back side, there is a pyramid shaped piece of plastic wrapped around the middle bar. Pry it up with a screwdriver (if needed but it should slide), it should unsnap, and will reveal the mythical red serial number. And it should also be on the warranty registration card.
Sep 21, 2015 | Sole Fitness Sole E35 Elliptical
How can I correct error code 25 on an AEG OK-LAVAMAT 74640 update washing machine mean?
Family error code "E20" means difficulties in draining, but I never heard for error code E25 on this model. Could be : E21, E23 and E24 error code.
Dado
Aug 24, 2014 | AEG Washing Machines
Incline Error Message E3
If you wish to get some details; check the site linked here. Pull up older posts treadmill . http://electro-medical.blogspot.com/ Surf the site with patience.
Dec 23, 2013 | Sole Fitness Sole E25 Elliptical- 2013...
Motor error messege on E25 sole ellipticle
proceed according. God bless youDescriptionThis error monitors the treadmills power bit reading. Power bits indicate the relative time that themotor controller drive circuit is turned on. Therefore power bits is an indication of the amount ofpower the load is demanding from the motor controller. The treadmill software sets a maximumallowable power bit limit. Error 25 indicates that the maximum power bit limit is being exceeded.Possible Causes1. The running belt and/or running bed is badly worn.2. On treadmills utilizing an SCR motor controller, a leaky or shorted drive motor filter capacitorcould raise the current demand sufficiently to cause the error 25.3. On treadmills utilizing an SCR motor controller, a leaky or shorted drive motor inductor couldraise the current demand sufficiently to cause the error 25.4. A shorted or de-magnetized drive motor is causing the high power demand.Possible Remedies1. A clamp-on A.C. ammeter must be used to determine the amount of A.C input current beingdrawn by the treadmill under no load and loaded conditions. The current readings can beused to determine the condition of the running belt and/or running bed. These same readingsshould be taken on a similar unit with a known good running belt and running bed. Thosereadings can then be used as a benchmark for future use. Replace the running belt and/orrunning bed as required. Remember, many running beds are double sided and the bed canbe flipped over rather than being replaced.2. A clamp-on ammeter should be used to measure the A.C. input current at no load. The filtercapacitor should then be electrically isolated from the drive motor circuit. The drive motorleads must be kept intact so that the drive motor will operate with the filter capacitor removedfrom the circuit. The no load A.C. input current should be measured again, if the A.C. inputcurrent is significantly lower, replace the filter capacitor.3. Use the same procedure as in step 4 above, except remove and isolate the inductor from thedrive motor circuit instead of the filter capacitor.4. A known good drive motor must be substituted for the existing drive motor.
Apr 02, 2013 | RTO Sole Fitness Package F85 Treadmill &...
Where can I find the serial number on a Sole E25 elliptical trainer?
on the front of the machine, right under the display, on the back side, there is a pyramid shaped piece of plastic wrapped around the middle bar. pry it up with a screwdriver, it should unsnap, and will reveal the mythical red serial number.
Feb 08, 2011 | Health & Beauty
Hello I have the message E25 on my scanner. I'm unable to use it, do you now what that means? canon DR-6080
E25 is abnormalities in pickup motor. If you open the front/top cover, you can locate the motor, Pls check if the connections are okay. These motors are generally very reliable and don't fail.
S. Mohan, Chennai, India
Jan 20, 2011 | Canon DR-6080 Path-Through Scanner
MY CAMERA SHOW ME E25, DO YOU KNOW WHAT DOES MEAN
It stands for "Focus Lens Error", and is a failure of either the lens connection to the circuit board, or a mechanical failure within the lens itself.
Jun 24, 2009 | Canon PowerShot A70 Digital Camera
Agfa e25 scanner
Scanners tend to be made not to be dismantled,
So this is a problem you will have to figure your self or buy a new scanner
Dec 27, 2007 | Agfa SnapScan E25 Flatbed Scanner
Exercise & Fitness Logo
223 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
