Question about IBM Computers & Internet
How to open the battery compartment to change the battery on IBM Thinkpad laptop
len52155
  • 20 Answers
SOURCE: IBM ThinkPad 600E 2645 PC
the following data is from the hardware maintenance manual for the thinkpad 600 series and is readily available from http://www.lenovo.com/support
Symptom or error FRU or action, in
sequence
161
Dead battery.
1. Go to “Checking the
backup battery” on
page 12.
2. Backup battery.
3. System board.
163
Time and date were not set.
1. Set time and date.
2. System board.
173
Configuration data was lost.
1. Select OK in the error
screen; then set the
time and date.
2. Backup battery.
3. System board.
192
Fan error.
1. Go to “Testing the
computer” on
page 7.
2. Measure the voltage of
the backup battery. If
the voltage is not
correct, replace the
backup battery.
3. Fan.
4. System board.
Posted on Oct 10, 2008
SOURCE: IBM ThinkPad Model T30 Cooling Fan
That would be apreciated.
Posted on Nov 21, 2008
  • 2692 Answers
SOURCE: unlock ibm thinkpad
IF it  is a BIOS password ,Try taking  out the battery and shorting the BIOS terminals then reinstallign the battery or leave it out long enought  for the capasitors and memory chips to loose their charge.  Reinstall the battery and then memory of the pasword wil be no more. BIOS Brainwashing.
Posted on Jan 24, 2009
SOURCE: Change of CMOS battery in IBM Thinkpad 1400 2621
This battery is hidden under the keyboard slightly up and to the right of center of the keyboard. To get it out is a pain.
Start with the computer sitting flat, lid closed, lid latchs facing you.. just like you were getting ready to open and use it.
Spin it around, rear ports facing you. Right above the external video port, on the right hand side, there are two screws, at a diagonal UP from the port itself, very close to the bottom edge of the LCD. Remove them. There is a small notch between the screws, using a small flat-blade screwdriver, pry up in the notch and pop the platic backing free from the rear of the laptop. DO NOT open it more than a small crack, you are just popping loose a small plastic tab. Open it too wide and you will lock it closed again or break the plastics when you open the LCD lid.
Spin the machine around again, and open the LCD carefully as far back as it will go normally. Find the Power Button. The Power button is to the far right of a plastic 'strip, with 4 other buttons on the far left. There is a small clear plastic strip overlying this button 'tray'. Find the small notch in the bottom edge of the clear plastic strip, use the flat-bladed screwdriver, and gently pry up, popping the plastic strip out of the tab holes in the tray. Under this plastic strip is a black adhesive 'strip' that has a house, magnifying glass, etc. markings on it, and 'i Series' or somesuch printed on it.
Using a razor blade, peel up the black adhesive strip on the left and right ends of the button 'tray'. You will find two small silver screws. Remove these. Then using your screwdriver, or as I did, a dental pick, *gently* pry up the entire tray from the BACK edge of the tray, and by lifting up the left side of the plastic tray. You will have to work it out from under the edge of the LCD bottom on the left side. DON'T yank on it, there is a small cable attached to the bottom of it. You will be able to rotate it toward you and roll it over, exposing the small latch holding the cable in place. Its a small, press-fit latch like what holds a keyboard cable in place. You'll need to work it open by lifting the left and right edges till the latch becomes loose. Pull the cable straight out of the slot, remove the entire plastic 'tray', and set it aside.
On the far upper right of the keyboard there is a small metal tab holding the right upper edge of the keyboard. Reach around to the back of the computer, right-hand side rear, find the little square thumb-notch, and pull it out. The latch on the upper right edge of the keyboard should retract. Now, while lightly pressing down on the keyboard, push the keyboard away from you. It should slide backwards and the front tabs on the front keyboard edge will pop out of the slots. Lift up the touchpad area, popping up the bottom edge of the keyboard, clear of the plastics, then pull the keyboard slightly toward you. It should pop loose all the way around. DO NOT yank on it, there are 3 small cables attached underneath. You wil need to lift the keyboard up enough to reach the cables and pop the lockdown tabs loose, then pull the cables straight out of the slots they are in. The cable slots are attached to the motherboard, the cables are attached to the keyboard.
Removing the keyboard will expose a flat silver panel underneath. There are 5 screws holding down the panel, 4 in a 'box' configuration on the left, and a single one on the right, and several slide-tabs around the edges. Remove all 5 screws, then slide the whole tray to the right, while lifting up. The entire tray will pop up, with the video card heatsink attached on the left-underside of the tray. Set this aside. Directly in the middle of the big hole you now have is the battery. Its smaller than a standard desktop motherboard battery, looks like a small silver button. Gently pry up on the bottom-left edge of the battery, very carefully or you will break the plastic clips holding it in place, and pop it out.
All done. Reverese order to put it all back together.
Posted on Mar 12, 2009
Geekman
  • 32281 Answers
SOURCE: IBM THINKPAD AUDIO DRIVER
Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows XP or Vista device drivers for your model laptop,
Use this link :-
http://www.ibm.com/products/finder/us/finders?pg=ddfinder&cm_re=other-_-suprcn-_-download
Posted on Apr 08, 2009
If am booting IBM THINKPAD laptop computer an error code saying the system has been tempered with
Some access point such as the battery compartment may have been opened, causing the laptop to generate that code.
Nov 11, 2014 | IBM ThinkPad Computers & Internet
I need to change the CMOS battery on my IBM Thinkpad Type 2658 Is there anywhere I can go to see how to do it. There was a link on another site but I think it is very old and it didnt work
Hi
For change the CMOS battery in you laptop visit"http://www-307.ibm.com/pc/support/site.wss/MIGR-50626.html"this link and get the solution.
If my solution make you happy then give me the four thumb
Cheer
Jun 28, 2011 | IBM ThinkPad R32 2658 Notebook
HOW TO CHANGE MY CMOS BATTERY.DURING MY FORMAT MY LAPTOP WAS TURNED OFF IN THE MIDDLE
Turning off automatically in the middle of the installation of software are the heat commonly reason. Try cleaning your notebook by opening the casing and use paintbrush and vacuum. Put thermal paste just one drop on the top of your cpu or processor for better performance.
Then it again reformat.
Please rate me.
Nov 20, 2010 | IBM ThinkPad A21m 2628 Notebook
Need to replace internal clock battery
This may have been solved by now however...
REMOVE MAIN BATTERY... Before Opening any compartments!
The CMOS battery is located in the modem compartment.
Place the unit upside cown with the rear connectors facing towards you. It is the compartment on the right rear corner (i-screw to remove). It may be difficult ro open due to the modem labe sticking to the cover. Use care when attempting to pry door open.
Battery is CR1220 0.5in Diameter (Dime Size) (40mAh Rated).
Alan
Feb 22, 2010 | IBM ThinkPad 390X 2626 Notebook
I Have a IBM thinkpad t40 I got a new battery and I can't get the power to come on
first will the pc turn on with no battery and the plug in both the wall and the laptop ?
if yes then try battery again being sure the contacts are clear and the packing/ship[ping cover is off the battery contact area.. also make sure the shipping cover has not become jammed in the laptops contacts inside the battery compartment...
if NO then u may have a defective power supply inside your laptop - see a repair center.
Sep 16, 2009 | IBM ThinkPad T40 2373 Notebook
Need to change bios battery in old IBM Thinkpad
You meen CMOSbattery as I understand. for removing or chnging it you need to disaasamble your thinkpad here is instuction go to pg 75 to see where is battery.
Aug 12, 2009 | IBM Thinkpad I1400 2621 Planar TV...
Replacing Bios battery
Yes, You can change it yourself. The battery is located in the memory compartment on the bottom of the laptop. Do a search on Ebay for IBM 600e battery, they run about 3.00
Buddy
Corporate Computer
www.ccl-la.com
Jul 04, 2009 | IBM Thinkpad I1400 2621 Planar TV...
Starting ibm 600e
Hi there.
Errors 161, 192, 163.
All three of these errors are connected to the back up battery.
To resolve this problem:
1. open memory flap on base of laptop (small philips screwdriver required)
2. find the small connector with 1 black & 1 red wire coming from it.
3. disconnect above connector and gently pull the Red&black wires. The backup battery should just pull out from under the casing.
4. get replacement battery. Either
a. call IBM spares (07900 247 490 in UK) and ask for FRU:
02K6502. UK price is about £8 + £15 delivery + VAT.
b. if comfortable with soldering iron: Carefully open the packaging on the backup battery using a sharp knife.
Remove the solder tags from the battery (these are spot welded so need to be cut/broken off). Buy a new CR2025 battery from any computer shop, jeweler, or camera shop.
Using electrical tape, insulate all round edge of battery
Solder the leads onto the new battery - note polarity. Red wire to +, black wire to -.
Using more insulating tape, wrap battery so that all exposed metal is covered.
5. put new battery into laptop (reverse steps 1-3)
6. start up computer, error 192 has gone, but still shows 161, 163. Select OK.
7. reset date & time, and OK
8. when screen shows 'O / I' restart laptop using on/off switch at side.
Good luck and thanks for using FixYa!!
Mar 05, 2009 | IBM ThinkPad T21 Notebook
Boot sequence
161 and 163 error means you have to change your CMOS battery. open the laptop, change the cmos battery and you should be able to set the date and time.
after which you can access the bios by pressing F1 upon boot up and change the boot sequence after that
Mar 30, 2008 | IBM ThinkPad 380ED
Upgrading memory
Evening Skelton, Flip your laptop over with the battery compartment facing towards you. On the upper right hand side there is a compartment held closed with one screw. Remove the screw and flip up the compartment and you will see two DIMM sockets. Let us know if you have any other questions and please rate the posting.
Jan 11, 2007 | IBM ThinkPad A22m 2628 Notebook
Computers & Internet Logo
79 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
