Question about In Office Equipment & Supplies
I keep getting double lines when printing . I have aligned it, I have put in new ink cartridges and it won't print normal. This is the Canon MX 432
  • In Master
  • 5,318 Answers
Check your printer drivers, they may need updating.
Posted on May 12, 2017
  • 4 Answers
SOURCE: Press enter to align cartrige then I get printing align cartridge page.
Do rhe alignment
Posted on Jun 03, 2009
  • 8 Answers
SOURCE: 4315 Hp Printer will not align.
restart your printer like this: go to control panel>
performance and maintenance>administrative tools> services> scroll down until you come to print spooler, click on this then on the upper side of your screen you will see restart, click on it.
This should get you up and running. Shame on your repair man for not showing you how to fix the problem.
You could even try not aligning the cartridges, this will just cause your printer to spit out an alignment page each time you turn it on but still should go ahead and print for you.
let me know how if this helps.
Posted on Mar 14, 2009
  • 2985 Answers
SOURCE: HP 2210 xi printing problem - alignment
Try your question here
Posted on May 14, 2007
  • 417 Answers
SOURCE: alignment after new cartridge
Hi I think that you will need to clean the gold dots on the printer carriage or if not done so remove the blue tape from the cartridge or if you are trying to use refills install some originals as this may help.
Hope this helps'
Please rate me
Cheers J
Posted on Dec 31, 2007
  • 19 Answers
SOURCE: hp psc 750 won't print with new color ink cartridge
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
Posted on Aug 24, 2009
New cartridges, letters in misalignment and double struck words
What Causes a Printer to Be Misaligned? ' > ... > Setting Up a New Business Basics
A printer that has alignment problems will not print documents accurately. images and text ... Install new manufacturer's cartridges in the printer. If the cartridges ...
How to Replace & Align Canon Ink Cartridges ' > ... > Computers
Misaligned cartridges cause poor overall print quality by producing print lines slightly... Remove the new cartridge from its packaging and remove the colored ...
PDF]Stylus Photo R300 / R300M - Product Information ... - Epson Stylus Photo R300 Series - 1. Printer Parts ... asterisk (*). The printer also works with plain paper. Cartridge. Part number. Black. T048120 ... Letter. SCR1001. PremierArt Matte. Scrapbook Photo Paper for Epson. Letter ..... Unwrap the new inkcartridge. .... misaligned, align the print head (see page 11). Related ...[PDF]Epson Stylus NX430 - Quick Guide you set up your Epson Stylus® NX430 (see the Start Here sheet), turn to this Quick. Guide and ..... Load letter- or A4-size paper in the sheet feeder. 2. Press ... Use the following list when you order or purchase new ink cartridges: Note: We ..
Jan 05, 2016 | Office Equipment & Supplies
The printer doesn't print all the in their entirety. Some lines are fine but many are not.
Think you need a new print head which is a component in your printer. Canon ink cartridges just contain ink. HP, on the other hand, have ink cartridges with the print head built in to the ink cartridge so that every time you buy a cartridge you basically have a new printer.
Oct 08, 2015 | Canon PIXMA MX452 Wireless Office All In...
Prints with a double vision quality
Use the print alignment feature and follow the directions precisely. If the print heads won't align properly to get a clear image in the self-tests... get a new printer. It isn't worth repairing. If your cartridges are fairly full, buy another Canon that uses the same cartridges and install them on the new machine... keeping the unopened ones for spares. This will help defray the cost a little.
Apr 09, 2015 | Canon Pixma MX452
My x3350 double prints text. It will overlay each sentence on itself. When I print worksheets on excel every other vertical line will be double-printed. I've tried to uninstall and reinstall the...
This may be a cartridge misalignment issue. First try printing with the settings changed to black and white print only. If this does not work then print in fast or draft mode (this should print in a single pass with less ink. Normal or best quality is usually done by passing the cartridges over the line twice.
Run the cartridge alignment test and see if it can be correctly aligned.
It could also be that the belt that moves the cartridge holder is loose and so two passes of the print head are misaligned. This may not be repairable (at least not economically).
Feb 20, 2011 | Lexmark X3350 All-In-One InkJet Printer
Cartridge problem
Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Nov 19, 2009 | Canon PIXMA iP1600 Printer
Print Cartridge Problems
i have an mp170 all in one and when you fill the cartriges they dont show up as full cannon put a chip in the cartridge to con people into buying new ones try siting the cartridges in warm water for a few hours then blot the cartridge with tisue paper if it dont blot out the ink the cartride is finnished and you need a new one .To align the cartridge you flick through the menu on the printer not pc screen look for alignment page print this off then you have to pick the dark boxes on the sheet shade the bit next to it and put on your scan bed and click ok it should scan the sheet and reset the alignment
Jul 19, 2008 | Canon PIXMA MP180 All-In-One InkJet...
Stripes on Images only - Text OK
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
May 24, 2008 | Canon BubbleJet i560 InkJet Printer
Problem with Canon MP730
hi, i was having the exact same problem with my printer. and i also tried reinstalling the driver. after reading your post i decided to see if the printing problem occurred when i used the other colors, and it looks like it's only a problem with the black ink. i printed out a sheet with the text in red and another in blue and they came out perfectly. but the black grid that surrounded the blue text, still looked problematic.
so... that means that the black ink is the problem. i haven't tried putting in a new cartridge. did you say that your problem occurred after you put in a new black cartridge, or did you try putting in a new black cartridge and you still had the same problem?
May 06, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
55 people viewed this question
Top In Office Equipment & Supplies Experts
Level 1 Expert
Tygh Duval
Tygh Duval
Are you an In Office Equipment and Supply Expert? Answer questions, earn points and help others
