Question about iHome Audio Players & Recorders
How can I fix my volume on my Bluetooth headphones of ihome
Volume on my iHome is too quiet, fix please?
You an inline battery powered signal booster, they are cheap.
Sep 23, 2016 | iHome iBT60 Bluetooth Rechargeable Mini...
My iHome iBT60 has a low volume when connected through Bluetooth. I've tried connecting & reconnecting it twice, and it didn't work. Has anybody had success troubleshooting thi
Turn up the volume on your iPhone. Also, try connecting your iPhone or any other media player, e.g. computer, to the AUX IN jack on the speaker and see if the volume is higher for that connection.
Jan 01, 2015 | iHome iBT60 Bluetooth Rechargeable Mini...
Can Bluetooth still work if the ihome is not plug into an outlet? Like can you take it places and can it be portable
Bluetooth is a smart replacement for connection cables. Thought for very low power information (music) exchange. It will connect devices over a range of maximal 10 yards. (about 10 meters) If you were using a bluetooth headphone to listen music on your iPod, as soon as you plug in a wired headphone, the bluetooth connection will be disconnected, because your device only can serve one master.
I hope I could shine any light on your blue tooth.
Jul 08, 2014 | Audio Players & Recorders
My auvio headphones show a solid red light
Charge your headphones and while they are charging press the call button and the volume up button and you problem is solved. After that just let your headphones charge.
Jun 14, 2014 | AUVIO Bluetooth Headphones
There is little volume from the headphones but I can hear music coming from the ipod nano itself! How can I adjust it?
1 May be the headphone jack has not been inserted properly in the headphone socket. Try removing it and replacing it. OR
2 Check the headphone on any other audio device just to make sure your headphones are OK. OR 3 Press Menu, go to settings, go to volume limit and see that it is fixed to maximum. 4 OR press Menu, go to settings, go to clicker, press the center and fix it to headphones
Jan 27, 2010 | Apple iPod nano
I want to play a Zen V on an ihome (portable speakers)
there is a double jack wire that should have come with your ihome plug one end ito your zen head phone hole and the other end in the back of your i home thats how mine works idk about yours but it should work the same for all ihomes
Nov 01, 2009 | Creative Labs Zen V MP3 Player
Problems with Headphone and USB plugs
I share the same problem - I'm worried it's due to routine wear-and-tear on the jacks, so the connections are no longer solid. I hate to think I need to get it serviced for this. Usually buying a new cable has worked, but that gets expensive too... Anyone have a fix??
May 06, 2007 | Apple iPod nano
Top iHome Audio Players & Recorders Experts
Wesley Elsberry
Wesley Elsberry
Level 1 Expert
ray gallant
Are you an iHome Audio Player and Recorder Expert? Answer questions, earn points and help others
