Question about Normal Audio Players & Recorders
I need help with getting? my volume back to normal
I have my grandaughter tesoar tablet is frozen on the white screen with tesoar across the screen i need help
Hi, you need to do a factory reset!
First, turn your tablet off. Then, power the tablet back up by holding down the volume (either + or - ) and power buttons simultaneously. Continue holding the volume button until the screen says "Booting tablet in recovery mode." This will give you a picture of an Android. Tap the android, and you will be given a screen with several options. Move between the options with the volume + and -, and select with the power button. Go to the option for Factory Data Reset and select it. Scroll down to `the Yes, and then the tablet will erase its memory back to factory settings. Once it has completed, select Reboot Tablet Normally.
let me know how you get on!
Oct 18, 2014 | Tablets & eReaders
Samsung TV Version CZ04 volume reduces itself and whenever goes back to normal
Your volume goes down or up depending on the demand (number of viewers} viewing the channel at any given moment. That is mormal.
Nov 28, 2012 | Televison & Video
Turntable hookup to AUX or CD (no Phono input) only producing very weak sound, even at full volume
You are doing nothing wrong at all. It's just that as you say it has no phono input. Which means the sockets you have will NOT amplify the signal. So you need to buy a magnetic cartridge pre-amp and once connected to the aux the weak signal will be at the normal level.
Jul 11, 2017 | Pioneer VSX-818V-K Receiver
THE VOLUME DIAL (LARGE ROUND WHEEL) DOES NOT WORK PROPERLY. You turn it clockwise to get higher volume, the digital numbers go lower, higher, and not the way it should be. The volume doesn't increase or...
Some tuners denote volume as attenuation so zero means it is at full volume and -20 means it is 20 decibels or 20 percent etc below zero. Essentially, zero means it is not being held back while the higher the number, the higher amount of holding back.
I am not sure what you mean by the volume does not increase or decrease normally so you'll have to ask that one with more details and information to get something more on that issue.
Jan 17, 2018 | Sony CMT-HPX9 CD Shelf System
I have a GT-S5230, and da font size of my text messages has gone from normal to small, how can i get it back to normal font size?? please help
Go into the text and press your volume button up.
(The volume button increases and decreases the font size)
Oct 30, 2010 | Samsung SGH-S5230 Cell Phone
When turned on: srm450 has no sound, but all leds (power and signal) is normal. If I turn the volume up (near maximum) , the srm450 sound is activatet again , and peforms normally. I then turn volume down...
1 TAKE THE MAINS PLUG OUT
2 Unscrew the fixing screws on the back. (just the outside ones)
3 Take the back off and turn the amplifier circuit board to face you.
4 About 2" from the left and about 4" from the bottom you will see a sort of tab. pull it off gently and widen the 2 prongs slightly.
5 Put the jumper tab back on and re fit the amp.
Dec 26, 2009 | Mackie SRM-450 System
Stereo volume goes up itself
Funny huh? Actually, some aftermarket radios like Pioneer have a setting where it senses cabin volume and ups the radio volume itself to overcome cabin noise. I doubt this is your problem and belive the unit is really "mental" and needs repair/replace...
May 07, 2009 | Car Audio & Video
Sugden A48, one channel keeps cutting out. Sound restored by increasing volume but at low volume goes again.
The volume control may need to be cleaned. Find a spray cleaner made for electronics, relays, ect. and spray it into the volume control from the back side of it where it connects into the circuit board. After getting the cleaner into the volume control, work it in by turning the control back and forth over and over again. Do all of this with the power unplugged from the unit. After you finish cleaning the volume control, plug it back in and turn it on and then check to see if it is working normal. Volume controls can get oxidized and dirty after a few years and require cleaning. I hope this helps, let me know if you need any further help.
Dave
Oct 14, 2008 | Audio Players & Recorders
PROTECTION MODE
The unit may be experiencing an overload caused by a short circuit, internally or externally. Try disconnecting all the speakers, then turning up the volume. If nothing happens, connect one speaker at a time and turn up the volume to see if you get more sound. You may have a speaker that has shorted internally and this will help you discover the bad one. However, if when you have all the speakers disconnected, and the unit still goes into protection mode with the volume up, then there is a problem with the unit itself.
Hope this helps, and please rate my advice, good OR bad.
Feb 04, 2008 | Audio Players & Recorders
Speaker out?!
try the volume buttons on the left hand side
Sep 16, 2007 | Sony Ericsson Z310i Cellular Phone
21 people viewed this question
Top Normal Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Normal Audio Player and Recorder Expert? Answer questions, earn points and help others
