Question about Refrigerators
The controls show E for refrigerator and 1F for freezer. It is a model# LFXC24726S. What is the problem?
4 Suggested Answers
EllaWatson25
  • 725 Answers
SOURCE: model MFS22MISBBB Refrigerator/Bottom Freezer
Have you changed out the bulbs yet? That may be all you need to do to get the lights working again. Or the switch could be out. Call us for parts. 972-859-0929. Hope this helps you! Ella
Posted on Aug 26, 2009
machinetech7
  • 1344 Answers
SOURCE: Frigidaire side by side freezes in the Refrigerator side
The temperature control thermostat, alson known as the colds control thermostat has gone bad and basically isn't converting electrical/temperature signal properly and needs to be replaced
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Posted on May 17, 2012
Testimonial: "thinks alot, after 24hrs it staying at 39f so its working now i don't know why but she all fixed the only thing i did was turn it off for a min and turn it back on. "
  • 195 Answers
SOURCE: my kenmore refrigerator / freezer (model #2539338710 mfg: 4/95) won't get cold enough. The freezer & the refrigerator are both @ 49 degrees with the controls in the freezer & refrigerator
HI JOHN.both at exact same temp.sound like your motor is not running due to failure or relay or overheating due to con/fan ;cond/unit blocked or again motor.check these first good luck Ali
Posted on Jun 29, 2012
Had Er and 1f on panel. Pulled drawers out and removed ice from the back of freezer compartment, errors still show. Is there a reset button or did the ice cause a problem with fan motor?
Probably defrost problem. Evaporator, which is behind inside back wall of freezer, will have to be completely thawed. Then a determination will have to be made which of the 3 defrost components are bad. Those components are defrost heater, defrost thermostat, and defrost timer or control Board.
Sep 12, 2017 | Refrigerators
What does Er 1F mean on the ice maker display
LG Refrigerator Error Code Er 1F or Er IF
The ice maker fan is not working properly. Try defrosting the freezer first before trying to replace anything.
Jun 29, 2017 | Refrigerators
The control panel on my jenn air fridge model # jfc2089htb is not responding and I cannot adjust any setting. Fridge is stuck at 44f and freezer -1f
A simple reason could be the control panel is locked (child/safety lock) - look for a small lock symbol in the display.
Oct 30, 2016 | Refrigerators
I have a Kenmore Elite Refrigerator that has ER 1F on the display. Where can I find a manual with error codes or can you tell me what this means?
Hello Ken;
My name is Peter. I am a retired field service refrigeration technician.
The 1F code means there is a communication problem between the control board and the freezer fan.
Your freezer fan my have failed or it my be blocked by ice build-up.
So, It is one of these parts:
1.) Freezer fan motor
2.) Defrost heater
3.) Defrost timer.
You did not provide a model number so I can not provide you with parts numbers.
Although, I am retired, I do maintain a small customer base. If you live near Glen Burnie, MD, call me 443-306-1362
Dec 15, 2014 | Kenmore Refrigerators
Error message Er 1F
Maybe this will help. i would check fan first and see if ice has built up in fan.
https://www.youtube.com/watch?v=a4MdwuoN3jc
May 26, 2017 | Kenmore Refrigerators
May 16, 2012 | Frigidaire Refrigerators
LG Refrig LFX25960SB
The service manual with the codes is available at:
LG LFX25960 Service Manual
"ER IF" show a problem with the ice maker fan motor.
Nov 06, 2008 | LG LFX25960 Bottom Freezer French Door...
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
