Question about Electric Health & Beauty
Finding help with jazzy electric wheelchair wont charge maybe fuses dont know where to look for them on this chair
  • 3 Answers
SOURCE: Jazzy 1200 power wheelchair is electrically
When you say inoperable I am assuming you are not getting a flash code on the joystick. I would check the wiring from the charge meter on the rear? console - you will see a yellow slug in the harness that has a fuse in it - check all the wiring from the meter as this can cause a 'power loss' problem. Of course, check the battery connections as well.
Posted on Mar 27, 2009
  • 40 Answers
SOURCE: My Jazzy won't move.
If your batteries are truly charge they should read around 24.5 VDC. And if the freewheel lever is engaged and you still have no movement your probably need to get into a service tech. Also check the circuit breaker on the chair.
Posted on Apr 03, 2009
  • 61 Answers
SOURCE: Somehow I have locked my Jazzy 6 Select Electric
Try This:
To unlock the power chair.
1. Use the on / off button to switch the control system on. The maximum speed / profile indicator will be rippling up and down.
2. Deflect the joystick forward until the control system beeps.
3. Deflect the joystick in reverse until the control system beeps.
4. Release the joystick, there will be a long beep.
5. The power chair should now be unlocked.
Hope it works.
Posted on Mar 29, 2010
  • 177 Answers
SOURCE: Jazzy 1113 ATS Indoor Power Wheelchair: the battery is fully charged but it wont move does...
Hi. Your machine probably has a fault, but I very much doubt that it needs reprogramming.
Are the free-wheel levers in the correct place? Is the machine displaying any fault codes, e.g. flashing LED's and what is the pattern or number of flashes between pauses?
Good luck. Neil.
Posted on Jun 01, 2010
  • 104 Answers
SOURCE: Jazzy 1113 Power wheelchair. Batteries are fully
I'd look for a loose connection, one battery bad could be it, but its not likely, you can still move it with low voltage, one low batt., could be joystick. You can get generic trouble codes off your joystick, and call the manufacturer, Pride, 1-800-800-8586.
Posted on Jul 10, 2012
Does jazzy have to be in certain position to charge it
I tell my customers to charge the chair with the joystick on! otherwise it should be upright in a drive position do not charge a chair upside down! I don't know why someone would do that but...
once the charger is plugged in the chair is inhibited from driving, so if it is plugged in it won't drive.
Strege Mobility
Jun 12, 2014 | Select Jazzy Used Electric Wheelchair
1143 jazzy wheel chair new batterys @ new charger still not charging
With a new charger and new batteries there can only be one other problem assuming all the wiring is connected properly. There is a 7.5 Amp in-line fuse hidden in a fuse holder off the charging harness. This fuse may have blown. I usually check this fuse first since it is usually the culprit and most difficult item to locate under the back cover. In rare cases the ammeter burns open and will cause the unit not to charge. After checking the fuse you can jumper one or both these items to see if it will charge and then purchase new parts. Hope this helps.
Apr 16, 2011 | Select Jazzy Used Electric Wheelchair
My jazzy select 14 keeps lighting up like its charging after its unpluged and the chair wont do anything
Can you tell if the lights are flashing a number of times then pausing slightly then flashing the same number again and so on? If not then check to make sure your not in "freewheel". The levers are behind each wheel If you are getting a flash code determine the number of flashes the codes should be in your user manual or goto and you can download a owners manual for that chair. Hope this helps
Aug 22, 2010 | Pride Mobility Products Jazzy Select 14 XL...
How do I know when the chair has charged? I see one red, two green, two yellow lights on.
If you have an off-board charger that plugs into the joystick there are two lights on the charger one red(power on) and the other yellow (turns green when fully charged). Plug it into the chair and if the light is green then you have fully charged the batteries. Now if you have the on-board charger the charger meter on the rear of the chair will resd zero when fully charged. Hope this helps ya
Aug 18, 2010 | Electric Jazzy 1115 Power Wheelchair
I think my charger isn't charging the batterys
Have someone check if the on board charger light is green after you have charged it all night. Most probably you have a charger problem and this will also create a battery problem since you haven't been charging them with a bad chargger. If medicare purchased your chair then you can find a repair service to repair your chair and Medicare will pay for most of the repair
Feb 10, 2010 | Pride Mobility Products Used Jazzy...
I have a Jazzy power chair on loan and there is no instructiion book. How do I recharge the chair? I know I plug it in but do nmot know if it is actually recharging, Thanks
Be sure to charge the chair at least 8 hours each time. If you use it charge it. If you charge it less than 8 hours than it starts taking away from the life of the battery.
Nov 12, 2009 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Batteries won't charge w/ on board charger-+
sounds like blown fuse which is at rear of chair. may be underneath rear cover. this fuse wont keep the chair from working, however, it will keep the charging from working.
May 29, 2009 | Invacare Supply Group Invacare Pronto M91...
My Jazzy select wheelchair does not run
you move the joystick and can hear something quicking in the motors
May 17, 2009 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
My Jazzy wheelchair will not charge or run
First have the batteries tested to be sure that they are good. Just because they are "new" doesn't mean they are good. Then with the batteries disconnected plug the charger in and turn the chair on. This will tell you if the charger is good.
If both of these are good then you have an electrical problem. You need to call a local tech.
Nov 13, 2008 | Select Jazzy Used Electric Wheelchair
Health & Beauty Logo
Top Electric Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
Are you an Electric Health and Beauty Expert? Answer questions, earn points and help others
