Question about Ovens
W'house gas oven GXR650SNG. The oven bleeds heat from a gap at the top of the casing, above door, below panel. Never hot enough to cook. What's missing? A seal? Cheers
  • 487 Answers
You really need to have a professional look at this because gas stoves are nothing to fool with, can be very dangerous
Posted on Apr 28, 2017
How to change lower element in DeLonghi Airstream Convectio Oven
  • How to change lower element in DeLonghi Airstream Convectio Oven??
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Oct 28, 2017 | DeLonghi Ovens
    Oven won't heat flashes F2EO and 5D on
    List below does not apply to Whirlpool Models using the "Y" line in the products model numbers. Applies to models using 4 digit displays only.
    F0-E0 Analog to Digital failure
    Disconnect panel for 30 seconds
    Should the above error re-appears, replacement of the control is required.
    F1-E1 Defective ERC Replace ERC
    F2-E0 Shorted Keypad. Replace Keypad.
    F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
    F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
    F3-E2 Oven over heat Replace Sensor
    F3-E3 Cleaning Temp over heat Replace Sensor
    F5-E0 Door Error Check Door
    F5-E1 Door Latch Check Latch
    F5-E2 Door Switch Check Switch
    Below applies only to the two digit display models for the brands above.
    F0 Defective ERC Replace ERC
    F1 Defective ERC Replace ERC
    F2 Oven over heat Replace defective Sensor
    F3 Oven Sensor Open Check/Replace Sensor
    F4 Shorted wire or Sensor locate short and correct it or replace Sensor
    F5 Defective ERC Replace ERC
    F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground.
    F7 Shorted or sticking button Clean button or replace ERC
    F8 Defective ERC Replace ERC
    F9 Door Latch Error Check latch and latch circuit
    Mar 20, 2016 | Ovens
    The cooking is not even when cooking small items
    Often times this isn't something you want to attempt to rectify yourself. If you can find a way to deal with or adjust to this issue it will save you the cost of a repair visit. If the uneven bake is so severe that you cannot cook in the oven and you still wish to attempt repair by yourself you first need to identify which racks aren't cooking correctly and in which pattern is it uneven.
    For example is the rack uneven in overall color from top to bottom, meaning are items on the top cooking to quickly where as the items on the bottom are uncooked? Or is the uneveness lateral where the center of a single tray is over/under cooking or the edges of a tray are over/under cooking.
    Once you've identified your issues you need to locate your airflow louvers. They are usually located in the back right corner of this oven, it is where the hot air comes out of the heat exchanger chamber. You will notice there are gaps and there are fins. Adjusting the fins changes the way the air flows from side to side across your product, adjusting the gap changes how much hot air reaches the product.
    Lets approach side to side uneveness first. To compensate for the center of a tray UNDER cooking take the metal fin lined up with that tray on the RIGHT side and slightly bend it to the left, directing air towards the center of the tray. If the center is over cooking bend it to the right, directing air away from the center of the tray.
    For top to bottom uneveness you will need to loose the screws/bolts holding the fins in place and gently increase or decrease the gaps. Be careful here because if you loosen the screws too much the louver can slide out of place and make to large of a gap, potentially making things much worse. A good trick is to take a permanent marker and make a mark to where the louver was before you adjust it incase you need to put it back.
    If a single tray is too light in relation to the other trays increase the gap, if it is too dark, decrease the gap. Do this for each tray that is coming out uneven. Make small adjustments and then do a bake to check the results, there may be a lot of trial and error involved.
    If this seems overwhelming you're probably better off not attempting this because you can make things worse to the point where NOTHING comes out correctly, if that's the case call your local authorized service provider. Good luck!
    Jan 03, 2011 | Baxter BXA2G Stainless Steel Gas Single...
    The heating element becomes red hot,but the food doesn't appear to cook in an appropriate time os fashion. Any answers or suggestions
    The top of whatever food you're cooking should be in the center of the oven for the most effective cooking. Do you have the oven set on bake or broil? Broil is a direct heat method and if the food is on the lower shelf and the oven is set on broil, the food is not getting enough heat to cook it properly. Baking heats the lower element and the heat rises to surround the food. Broiling heats the top element and since heat rises, it is not getting down to the food to surround it and cook it.
    Nov 04, 2010 | Hotpoint SY36 Style Line Stainless Steel...
    GE gas oven XL44 JGBP29GES1WW not enough heat
    I suspect a faulty ignitor. It must draw a certain amount of amps to open the gas valve
    Jun 09, 2010 | GE Ovens
    Door does not close all the way when baking
    Hi!!! your door hinges are bad they need replacing..very expensive fix..So look around..Good luck..
    Jan 04, 2009 | Amana AEW3530DD Electric Single Oven
    My oven is a kenmore gas single, self cleaning oven about 8 years old. the oven will not light. the top of the stove is fine.
    Open the oven door and take the bottom panel off. you will be able to see it the hot surface ignitor starts to glow or not. Now turn the oven on and see if the hot surface gets red hot it not that is the problem. Should be able to get the part at a heating and air parts house or a appliance parts house. let me know what you find out. ken
    Dec 13, 2008 | Kenmore 30172 / 30174 / 30179 Gas Single...
    Gas oven won't heat
    You most likely have a defective oven bake ignitor.  Call an experienced tecnician.
    Oct 09, 2007 | Ovens
    Ovens Logo
    37 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    Are you an Oven Expert? Answer questions, earn points and help others
